Old 07-17-2004, 06:03 PM   #1
j240z's Avatar
Novak Equalizer/discharger Q's?
I picked up a Novak equalizer/discharger (#4500) today. It's seems pretty cool. My question is, I put a pack on it and let it discharge per the instructions. I then let the pack cool off before putting it on the charger. The discharger was set at 0.9v cut off. Being a 6 cell pack x 0.9v per cell, the voltage should be somewhere around 6v total for the pack, right? Well the pack was reading 7.3v after the discharger...? Is this normal? BTW this is a GP 3300 nimh pack...?
j240z is offline   Reply With Quote
Old 07-17-2004, 06:25 PM   #2
...On any discharging device....The voltage cut-off is just for a split second.......after you trey a pack ,even if you bring the cells all the way down to zero volts...the second you disconnect them from the trey....the cells will re-bound to around 1.2 to 1.23 volts per cell......this explains your 7.3 volts (total pack voltage)..............The idea is to bring them down with the trey so that when they rebound they will as even as possible before your charge..........Hope this helps some............
1/8 Scale: Tekno EB-48.2... Tekin RX-8 GEN-2 W/2050kv... Airtronix M11-X Radio... HiTec HS-7954SH Servo...
1/10 Scale: Associated B-5(rear motor)...Tekin RSX Gen-2 W/8.5t... Savox SC-1258-TG Servo
Joe B is offline   Reply With Quote
Old 07-17-2004, 07:11 PM   #3
j240z's Avatar
Yeah, thanks, your info does help! So I guess this would be normal then...!
Old 07-18-2004, 12:05 AM   #4
Super Moderator
Grizzbob's Avatar
Yes, it's quite normal, the .9V per cell reading is only when there's a specific load placed on the cells. When there's no load, the cell's voltage will return to normal, but as soon as any load is placed on them again, it'll go back down FAST....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12
Go Pokes!!!
Grizzbob is offline   Reply With Quote
wtb: Much More discharger/equalizer Tater salad R/C Items: Wanted to Buy 1 08-01-2008 09:51 PM
Novak Smart Tray battery discharger/equalizer for sale. Lightly used at home not trak DustinR R/C Items: For Sale/Trade 3 03-17-2006 01:32 PM
Discharger and equalizer help Stevietd14 Electric On-Road 15 10-29-2005 05:04 PM
Discharger/Equalizer same thing??? nmt6789 Rookie Zone 3 07-23-2004 05:07 PM
Discharger and Equalizer F/S micros_rock R/C Items: For Sale/Trade 3 02-22-2004 05:12 PM
SEO by vBSEO 3.5.0
