Old 07-17-2004, 05:32 AM   #1
Blackwrench™'s Avatar
Default Good MR4TC set-up
Hey guys,
I just got this second hand MR4TC (belt driven). I'm not familiar with this chassis, and I'm wonderi'n if you guys could give me advice in setting this chassis. i can't find set-up sheets for this car in the net. and please consider availability of the parts.
Blackwrench™ is offline   Reply With Quote
Old 07-17-2004, 05:50 AM   #2
TryHard's Avatar
Default MR4-TC setups
Hi Blackwrench I have a set-up for a TC here, although I have just raced t for the last time (new car arrives next week).
You can find it here
Note there are a few special bits in it
1) rear camber links. Instead of being mounted on the shock tower they are mounted on the bulkhead screws (pic here)
This changes the camber profile, and roll centre at the rear. I found it gives a slightly calmer rear end, but it may be best off if you just run it off the upper and inside most hole of the tower for now.
2) Belt tensioner bar. I ran this bar to loosen the rear belt a bit, seems to work ok, but it's not vital.
3) Roll bars. I always ran the roll bars, even if they are only the softest option, as I find that they make a car quite stable, and easyier to drive.
4) One ways. The setup has front and centre one-ways in it. However this probably isn't vital, and it should handle fairly well with diffs in, however you won't have a much steering (in fact this is an area I fell the TC lacks compared to mordern cars, it has very low amounts of steering.)
5) Springs. Quick tip, run one rate higher at the rear, or if desperate the same rate. Never run a softer one at the rear, it makes the car push like mad. The setup I have there, has Associated Copper springs. To get them to fit with the blue alu shockers you need to remove the adustable collar, and place the collar from the plastic one in it's place. Otherwise you have to cut the spring down (AE springs are longer than the Yoko ones).
6) Shock ends. Note that the front shocks are using the short end, not the kit std long one.
The setup is genreally for outdoor on smooth tarmac, however indoor on carpet, I've found that going blue (yoko) springs on the front, and yellow (yoko) on the rear is the only change i really need to make. I did experiment with disconecting the roll bars too, however I was a little undecided if it was any quicker. (I was using Pit D20 wets on the carpet)
If you have anymore questions about it don't hesitate to ask.
MR4TC SD Drift Demon Australia Wanted to Buy 0 01-17-2007 12:03 AM
mr4tc sd littledog R/C Items: For Sale/Trade 12 09-21-2003 03:51 PM
Mr4tc-md CGR Electric On-Road 11 05-06-2003 07:12 AM
KX-ONE or MR4TC has to go scott R/C Items: For Sale/Trade 7 01-18-2002 02:25 PM
MR4TC PRO and MR4TC Sport f/s or f/t Rr31rR R/C Items: For Sale/Trade 2 11-04-2001 11:33 AM
SEO by vBSEO 3.5.0
