Old 07-16-2004, 05:04 PM   #1
Default Ideas for a new r\c car
I am looking for ideas for r\c parts that would resemble a real nissan skyline gtr with 773bhp, of course not as fast as the real car and not with all the same parts as the real thing. I need ideas for all parts for chassis and so on. I will list the real specs of the actual car so you guys can come up with ideas. The car can be electric or nitro powered and i don't want an RTR, I am willing to spend as much money as I can to get parts suggested. Any suggestions would be great. Thanks!
Specs of real car:
Engine: Nissan 2.6L RB26DETT Inline-6
Engine Mods: R33 Block; HKS (twin 2835 turbochargers, billet crank & rods, Drag crank damper pulley, forged pistons & rings, 1.2mm Drag head gasket, oil pump, oil cooler, in-tank fuel pump, valve springs,
Step 2 cams & pulleys, billet fuel rail, fuel pressure regulator, GT-aRt ported HKS exhaust manifold with twin external
wastegates, downpipes, Super Power Flow induction kit, Racing Pro R50 Spark
Plugs, two sequential BOVs, GT intercooler w/hard pipe kit, airflow meter replacement pipe, inlet/exhaust gaskets, Drag stainless steel exhaust system, Neo 10W40 engine oil); Bosch Fuel Pumps X2; Sumo Power (stainless
engine breather pipe, intercooler fan, de-cat pipe); Nismo (main crank bearings, cam belt, water pump and
thermostat); GT-aRt (block, cylinder, head & clutch modifications, ported intake plenum, oil baffles, catch tank & lines, fuel swirl pot); ARC Prestige radiator w/swirl pots & piping/head/plenum cooling kit); JUN main head stud kit; Trust sump extension; Sard 1000cc injectors; Goodridge fuel lines
Engine Management: HKS (F-Con V Pro EMS,Twin Power ignition amplifier, EVC IV boost contoller, GCC(Graphical Control Computer X2,AFR,knock sensor,fan controller); Nismo MFD2 computer (for stock video screen)
Drivetrain Mods: HKS(6-Speed H-pattern
dog-box, triple-plate dog spline-type clutch, front/rear driveshafts); carbon fiber propshaft; Cusco (1.5-way front differential, 2-way rear differential); Trust front diff. extension
Suspension: HKS custom drag suspension, Kansai front strut brace); Ikeya Formula (traction adjuster rods & camber correction kits, rear differential spacers & center roll adjusters)
Wheels,Tires,Brakes: (f/r) 10.5x18-inch Do-Luck Double-Six chromed alloy rims; Dunlop SP Super Sport Race Tires; (f)Alcon 6-pot progressive front calipers
380mm rotors; Pagid Blue Discs; (r) Pagid Black Brake Pads; Nismo brake lines, Neo(brake,transfer,differential and
gearbox fluid)
SkylineVspecr34 is offline   Reply With Quote
Old 07-16-2004, 05:24 PM   #2
lazyboy's Avatar
Send a message via AIM to lazyboy
r32,r33,or r34??? thats a must know also lol
lazy,the r34 is the AWD version
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 07-16-2004, 07:00 PM   #3
its an r34 if anyone doesn't know
Old 07-17-2004, 08:18 AM   #4
Wency_TA03R-PRO's Avatar
OFF road -- I go fro TC10GT..
On-road- I honeystly go witht he FT TC3.
Alternative YOKOMO.
Wency_TA03R-PRO is offline   Reply With Quote
Old 07-17-2004, 10:58 AM   #5
lazyboy's Avatar
no, i knew that is was the r34, i was just posting for ppl that didnt know or couldnt tell them apart FYI
lazy
Random Guy
FT B4
Trackside hobbies
Old 07-17-2004, 11:54 AM   #6
Talking
Old 07-19-2004, 06:40 PM   #7
Should I get a FT TC3 elecrtic or nitro?
Old 07-19-2004, 07:16 PM   #8
corvettecrazy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to corvettecrazy
nitro, will sound more like a real R34, and have a nice exhaust smell too
although since this is an electric section, you might want to do that.
corvettecrazy is offline   Reply With Quote
Old 07-20-2004, 01:36 PM   #9
thanks Wency_TA03R-PRO and corvettecrazy!
Old 07-20-2004, 01:45 PM   #10
what kind of .15 engine, battery pack, and 2ch radio should i get?
Old 07-20-2004, 02:33 PM   #11
we should have this moved into the nitro section since that is where this is headed.
are you looking to race or are you just looking to "bash" (drive around on your street)??
also do you hav a budget for this project. You can spend thousands or just a few hundred.
Old 07-20-2004, 03:40 PM   #12
i'll move it over to the nitro section, and I'm using it for racing and just fun riding around. My budget for it is no more than $1350.
Anybody got ideas??? yourtheman Painting, Designs, Graphics and Photography 0 02-17-2007 10:30 AM
any ideas SSmoked Electric Off-Road 3 01-20-2006 05:54 PM
Ideas Please Best ESC scottw Electric On-Road 13 01-05-2006 08:15 AM
ideas for new r\c car SkylineVspecr34 Nitro On-Road 14 07-24-2004 03:23 AM
