Old 11-04-2010, 03:38 PM   #1
Double P Racing's Avatar
Default Vintage TC5R Carpet Setup
Just started racing the Vintage class with a TC5R. Having trouble getting the rear end to stay hooked up. Every time I get out of the throttle the car breaks loose and spins around as I get back into the throttle.
Would appreciate any set ups or help of any kind.
Double P Racing is offline   Reply With Quote
Old 11-05-2010, 09:14 PM   #2
I run the box stock TC5r setup, and have had great success with it for the past 2 years
Myron "BATTMAN" Kinnard
Team Associated/Reedy/RockStar Paint, LLC
THUNDER JAM IX Snowbirds Warm-up
January 2017
Thunder RC Raceway
DARKSIDE is online now   Reply With Quote
Old 11-06-2010, 10:22 AM   #3
T Tom's Avatar
Trader Rating: 17 (100%+)
Are you using brakes ?
What is your drag brake setting ?
Above are two ways to break the back end loose.
T Tom is offline   Reply With Quote
Old 11-07-2010, 07:52 AM   #4
tryracinme's Avatar
Trader Rating: 1 (67%+)
Send a message via AIM to tryracinme Send a message via Yahoo to tryracinme
i was having the same problem with my tc4, i found unhooking the rear sway bar and putting the car on a tweak board showed major improvement
tryracinme is offline   Reply With Quote
Old 11-07-2010, 08:01 AM   #5
orgnoi1's Avatar
Trader Rating: 39 (100%+)
The front to rear weight transfer is off... you have a couple ways to fix it... easiest being to tighten up the front end suspension slightly and loosen up the rear... that will cause more transfer under power and allow for more traction.. the other option is to bring the ride height up slightly in the rear... you can do that by bringing the rear shocks more vertical... battery placement can also be moved slightly rearward...
Tons of options... I wouldnt do all of them... small adjustments mean you can keep an eye on its transition...
There are quite a few "setups" online... I would look for one that follows suit with the conditions and car setup that you are intending on using... and then tweaking from there...
Ross M. | RC Photographer
The Bashing Grounds | I-Lap Timing
The Cow Performance Company | Dogpile Racing
orgnoi1 is offline   Reply With Quote
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 01:43 PM
2009/10 Hurricane All-Star Carpet Series Kevin K Wisconsin & Illinois Racing 761 07-12-2010 07:27 AM
In need of a vintage Trans Am TC5 set up blackdog Electric On-Road 13 02-04-2009 03:02 PM
SEO by vBSEO 3.5.0
