Old 07-12-2004, 03:35 PM   #1
s2's Avatar
Default Charger capacity read-out, affected by IR??
if chargers work out the capacity in a pack using a mathmatical equation (the dont actually count the individual MaH's going in) so does this mean a cell with a lower internal resistance will charge faster, and therefore apperar to have slightly less capacity? or am i totally wrong and IR only is a factor upon discahrge in race conditions?
s2 is offline   Reply With Quote
Old 07-13-2004, 03:28 AM   #2
As far as I know IR doesn't come into play until loads get higher than C. Charging should not matter. Higher IR will make the batteries peak at a higher voltage or that is an indicator, but does not change the capacity of the battery.
Our batteries are rated at C or 1 times the capacity. That would be 3300 Ma for one hour. We use that in 5 minutes or a little more. Lower IR lets the power out of the battery.
High IR would let you have 3.3 amps for 60 minutes, Low IR lets us have 33 amps for 6 minutes.
Charaging rate is C or as high as 2C (6.6) amps, so IR should have little effect.
David Root is offline   Reply With Quote
Servos affected by temperature Woof Radio and Electronics 3 12-26-2007 01:11 PM
LRP Pulsar Competition Charger - Please Read! 190mph R/C Items: For Sale/Trade 3 08-18-2006 07:46 PM
Battery capacity Iceracer Electric On-Road 4 04-01-2006 09:17 AM
Quaser Charger Recall, check your model to see if yours is affected corwin Canadian R/C Scene 0 09-17-2004 11:34 AM
When Will The Capacity End? RACER XXX Electric On-Road 29 04-15-2003 01:21 AM
SEO by vBSEO 3.5.0
