Old 07-10-2004, 10:53 PM   #1
j240z's Avatar
Default Best charger under $200 Pulsar Quasar Indi?
Well I made the mistake of buying an MRC Superbrain 969. In less than 2 months it has blown a channel. Well at least I still have 1 channel to charge my lithium packs with. Anyways, I want to get a better charger. I would need to be able to charge 1-8 cells or more NICD and NIMH. A discharge function is also a must. I've been looking at the Pulsar Comp, Reedy Quasar pro ,and the Indi 16x5. I believe thes are all from reputable companies and reliability is really important. What experience has everone had with these models. Are there other models out there I should also be considering...? I'm planning on getting a seperate charger for my lithium cells, which is why I got the superbrain in the first place.
Basically I just want a good solid charger for my car and receiver packs for less than $200. The CE T35 looks good, but too much $$ for me.
Any feedback would be great! BTW I have done a search on this topic on rctech and that is where I got the 3 models mentioned above as my primary choices....for now.
j240z is offline   Reply With Quote
Old 07-11-2004, 06:20 AM   #2
lastplace's Avatar
Send a message via Yahoo to lastplace
Take a look at the CE pitbull, nice little charger. I have 2 of the older models and they have never falsed peaked. You can pick one up for $80 to $90 used, there 2 or 3 on the boards right now. Next pick up a 15 amp power supply, I think there is one for $50 for sale right now.
http://www.hobbytalk.com/swap/showpr...1&cat=2&page=4
http://www.hobbytalk.com/swap/showpr...1&cat=2&page=2
You could save enough to buy another charger!
lastplace is offline   Reply With Quote
Old 07-11-2004, 07:11 AM   #3
kufman's Avatar
I would be careful around the Quasar Pro. They were recalled recently so you want to make sure you get one of the new ones or one that has been fixed (ebay be careful). Other than that, I think it is a pretty descent charger. My friend has one and seems to like it. I personally use the novak Millenium pro's. I have two of them and they work good for me. $140 at tower. search for part# 4490. The other two chargers I don't have any expierence with.
kufman is offline   Reply With Quote
Old 07-11-2004, 09:52 AM   #4
Send a message via AIM to rcguy2477
All are fine chargers, but i like the pulsar the most because of it's motor run-in feature which helps to tune motors, run in lathes, ect.
1989 Mazda Rx7
greddy t04b, megasquirt ecu, PlX wideband, 12x28x3 fmic, 50mm hks clone wg, ssqv bov, Safc, ss oil lines, walbro fuel pump, tubo intake manifolds, ssac exhaust manifold, 3" dp, 550cc primary/720cc secondary injectors, etc.
rcguy2477 is offline   Reply With Quote
LRP pulsar comp. 1 charger and Indi reactor 30 discharger... SCUBA STEVE R/C Items: For Sale/Trade 4 12-02-2005 04:29 AM
quasar or pulsar wanted dado11g R/C Items: Wanted to Buy 7 09-04-2004 07:58 AM
**WTB** Quasar or pulsar sport SuCioDiFiciL R/C Items: Wanted to Buy 0 02-17-2004 11:10 AM
Lrp Pulsar Or Reedy Quasar Pro KEITH Electric Off-Road 2 11-10-2003 09:54 PM
Quasar pro VS. pulsar VS.turbo 35 kevin2 Electric On-Road 20 02-13-2003 04:42 AM
