Old 03-22-2012, 11:51 PM   #1396
mingnon's Avatar
sorry about the crap pics, this is what i meant by filing off the lugs
---------------------------SMA The Home of GREAT Racing------------------------------
mingnon is offline   Reply With Quote
Old 03-23-2012, 03:29 AM   #1397
SteveM's Avatar
Trader Rating: 139 (100%+)
Why bother filing the alloy part when you're running the 20T center pulleys? I would have modded the stock plastic part instead.
SteveM is offline   Reply With Quote
Old 03-23-2012, 12:50 PM   #1398
mingnon's Avatar
i didn't have the stock plastic part, had 2 of the aluminium ones so just used one of them.
The filing allows a smaller spur gear to be used, larger pinion and a better fdr.
To give you an idea the local 21.5blinky class is running low 19sec laps (19.3/19.5)
The VTA class is also running 21.5 blinky, and running low to mid 20sec laps (fastest lap 20.249 last tuesday)
We have to get out fdr's close to our 21.5 blinky class cars to be competitive
Old 03-23-2012, 03:05 PM   #1399
malcnz's Avatar
All this talk about spools I may try it but how about a slipper spool is there anything that fits like on the TC6?
SCHUMACHER MI5 EVO/TEAM POWERS/SANWA/DX4R PRO.
SERPENT F110/TEAMPOWERS 21.5.
LOSI 22 2.0/TEAM POWERS 8.5
malcnz is offline   Reply With Quote
Old 03-24-2012, 05:57 AM   #1400
Does anyone know if you can use the standard shocks with the Tamiya rear tower mod?
thefan is offline   Reply With Quote
Old 03-24-2012, 06:59 AM   #1401
I put the ball diff in my fgx and really like the way it feels. Of course that is a rwd chassis. I haven't tried the diff in the s yet. If you are racing then stick with the spool up front. I'm using the gear diff with the aluminium cups and 80wt shock oil in the back and it works well.
3Racing Sakura XI 17.5 TC
Formula Rabbit (FGX conversion) 21.5
STRC LCG 2WD Slash 17.5
Serpent S120 13.5
6376vette is offline   Reply With Quote
Old 03-24-2012, 12:32 PM   #1402
malcnz's Avatar
I am but used longer shock ends to get some droop.
Old 03-24-2012, 12:33 PM   #1403
malcnz's Avatar
when you put the x1 rear arms on what parts do you need to do it?
Thanks.
Old 03-24-2012, 03:06 PM   #1404
wollow86's Avatar
Thanks.
Just the arms. But from memory if your using rear uni's you need the 44mm ones.
Supporting Aussie hobby shops:
- www.MRJRacing.com.au - - www.feralbatteries.com.au - - www.actionrc.com.au -
wollow86 is offline   Reply With Quote
Old 03-24-2012, 10:20 PM   #1405
malcnz's Avatar
cheers for that and have just ordered.
Old 03-25-2012, 09:54 AM   #1406
bronc4now's Avatar
Trader Rating: 40 (100%+)
Originally Posted by 6376vette View Post
The savage is built for abuse. I ran straight horns on my losi 8 and had no.problems however a on road touring car is a different beast. Its built for speed and performance more than impact bashing. Save yourself a headache and get a good servo saver.
Can someone recommend a good servo under 80 bucks for this ride ?
I'm looking into vta , I'm a onroad newbie. Thanks
RACE-BASH-CRAWL
Two many toys not enough time..
bronc4now is offline   Reply With Quote
Old 03-25-2012, 10:20 AM   #1407
SteveM's Avatar
Savox SC-1258TG or SC-1251MG
Old 03-25-2012, 03:53 PM   #1408
Would an FDR of 5 sound right for a 13.5 brushless?
Old 03-25-2012, 05:47 PM   #1409
competionpark's Avatar
Send a message via Yahoo to competionpark
Originally Posted by rsawyers9 View Post
Can someone help me out with vta gearing. I am going to get the 19t pulleys. What is the largest pinion that will work with the stock mount and spur? Should I just go 64p from the get go?
Are you running at Sir Gooney's in Knoxville? If so I would keep 48p if I could, because the spurs get eat up up there. Me and my brother, the beave both run Sakuras, and we were rolling in at a 3.5 FDR. I am at a 87/47 64P and so is he. Motor temps in the 150's on a hot day with a barely worn in drive train. Some go as low as 3.38 and some are around 3.8, depends on style and setup. Thebeave won with 24 laps last weekend with a virtually box stock car with only the vertical mount and spur gear changed. Its a fun car to run up there.
As far as the biggest gear tat fits stock, I think its either a 27 or 24, I can't remember. Either way, its not that close to what you would need for VTA.
competionpark is offline   Reply With Quote
Old 03-25-2012, 06:11 PM   #1410
rsawyers9's Avatar
Yeah I'll be running at Gooney's. This will be my first on road car so I'm sure I'll have some learning to do. I'll start at the 3.5 and go from there. Thanks for the info and hope to see you out there sometime.
Mugen MBX6R US | Novarossi P5 | 2058 | Savox |
rsawyers9 is offline   Reply With Quote
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
