Old 03-14-2012, 12:56 PM   #1366
pejota's Avatar
I'll give it a try too and see what i think.
I also need to try 2* rear toe instead of 3*
All this is in VTA on medium grip, technical asphalt.
Originally Posted by kikoy View Post
I adjusted camber 2* front and 1* rear, also shimmed the outer ball mount for camber link. it helped in cornering traction.
Thank you again!
pejota is offline   Reply With Quote
Old 03-14-2012, 01:08 PM   #1367
Be sure to report your findings. Its always nice to hear what does and doesn't work on different surfaces.
3Racing Sakura XI 17.5 TC
Formula Rabbit (FGX conversion) 21.5
STRC LCG 2WD Slash 17.5
Serpent S120 13.5
6376vette is offline   Reply With Quote
Old 03-15-2012, 11:14 AM   #1368
rsawyers9's Avatar
Ok so I'm planning on picking this car up soon to run in vta. Are there any parts or spares I should get right out of the gate?
Mugen MBX6R US | Novarossi P5 | 2058 | Savox |
rsawyers9 is offline   Reply With Quote
Old 03-15-2012, 11:28 AM   #1369
Trader Rating: 39 (100%+)
A-Arms
C hubs
For upgrades to make your life easier the Vertical Motor mount and 19T Pullies
Also I would boil your a-arms and C-hubs to help with breakage
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 03-15-2012, 11:46 AM   #1370
SteveM's Avatar
Trader Rating: 125 (100%+)
Originally Posted by jdeadman View Post
A-Arms
C hubs
...and the alloy spur gear adapter so you can use the 19T pulleys. The stock upper deck also needs to be altered to fit the vertical motor mount.
SteveM is online now   Reply With Quote
Old 03-15-2012, 12:00 PM   #1371
what does boiling the plastic parts do?
www.serpent.com
www.comedycomposite.com
http://www.rc-ride.co.jp/
Titanium is forever...?
Operator27 is offline   Reply With Quote
Old 03-15-2012, 12:13 PM   #1372
helps to make the plastic more flexible and less brittle.
Jason Deadman
Old 03-15-2012, 12:16 PM   #1373
A-Arms
C hubs
Just buy the hard arms. They are tough to break.
Serpent S120 13.5
Old 03-15-2012, 01:31 PM   #1374
interesting, so is there a way to make them stiffer.
www.serpent.com
Old 03-16-2012, 03:30 PM   #1375
rsawyers9's Avatar
A-Arms
C hubs
Thanks. How about the gear diffs? Whats a good place to start with oil for the 25.5?
Old 03-16-2012, 03:45 PM   #1376
rageracing's Avatar
Im running traxxas 100k front and 30k rear. Once i laid the rear shocks all the way down. she got under control exiting the turns and entering the straights. this car will dive into a corner like a fat kid after the last piece of cake.
mmmmm cake
Pink just makes my car go faster!
~ RadioPost controlled ~ 3R SAKURA ZERO-S USVTA-25.5 ~ Tamiya M05 ~
~ Vintage-RC12L ~ OFNA GTP2 ~
rageracing is offline   Reply With Quote
Old 03-16-2012, 09:07 PM   #1377
RC Passion's Avatar
mmmmm cake
Good one!
RC Passion is offline   Reply With Quote
Old 03-17-2012, 01:55 PM   #1378
mmmmm cake
Try going even lighter in the rear. I'm using 80wt shock oil and the rear rotates very well. Especially from apex to corner exit.
Serpent S120 13.5
Old 03-17-2012, 10:38 PM   #1379
rageracing's Avatar
Ill give it a try tomorrow. let you know how she holds up!
Old 03-18-2012, 03:22 PM   #1380
So I bought this http://www.rcmart.com/rc-sakurazero-...=595_1419_1467 and now I cant get the rear higher than 4mm when the shocks are turned so much out that I have no more adjustment.
Anybody got any idea whats wrong?
Thomaseh is offline   Reply With Quote
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 05:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 10:21 AM
SEO by vBSEO 3.5.0
