Old 02-28-2012, 04:57 PM   #1321
pejota's Avatar
Hmmmm... i'll have to mess with that sometime and see what happens...
Originally Posted by Theas1an View Post
I actually had it set at the one the book said but after I moved it wider it actually gave me more steering angle , very weird I know lol
pejota is offline   Reply With Quote
Old 02-28-2012, 05:22 PM   #1322
Originally Posted by pejota View Post
@Theas1an
Check the location of the ball stud on your steering knuckles. Per the instructions it should be in the hole closest to the rear of the chassis. That may or may not have an effect on your steering.
I've never messed with that adjustment so brighter minds than mine can tell you what effect it will have on steering.
Moving the ball stud on the steering arms will affect the Ackerman angle. The inside tire turns at a greater angle than the outside so the car can roll through the turns better. A straight up steering would cause the tires to turn at the same degree and scrub speed in the turns.
3Racing Sakura XI 17.5 TC
Formula Rabbit (FGX conversion) 21.5
STRC LCG 2WD Slash 17.5
Serpent S120 13.5
6376vette is offline   Reply With Quote
Old 02-28-2012, 10:07 PM   #1323
TheBeave's Avatar
I'm looking to get some parts for my car and noticed the shocks look pretty "cheap" from factory. I was thinking of upgrading to something like http://www.rcmart.com/rc-damper-comb...?cPath=389_390 Are these okay or is my money better spent somewhere else.
Blitz SCT, 2C, 17.5 Thunder Power
TheBeave is offline   Reply With Quote
Old 02-28-2012, 11:16 PM   #1324
Pro10noob's Avatar
Zero X1 arms are shorter.
You get a smaller trackwide at the rear and thus better rear grip.
regards Roy
Originally Posted by SteveM View Post
What is the difference between the standard Zero S rear arms and those from the XI?
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 02-29-2012, 05:27 AM   #1325
I cant open your link from my phone but the threaded shocks that 3 racing makes for this car are awesome. If you want to go with standard shocks you need to order the +4 front and rear shock towers. The sakura shocks and towers are shorter than standard. Again the sakura upgrade shocks are great but some people prefer standard style.
Serpent S120 13.5
Old 02-29-2012, 05:36 AM   #1326
Pro10noob's Avatar
Go for the 3racing shocks
It stays the same color and they are cheap and good
What Vette said, order the plus 4MM shocktowers with them.
regards Roy
l===/o\===l
Old 02-29-2012, 12:52 PM   #1327
Rolf92's Avatar
Here's mine!
Traxxas Slash 2wd Vxl | Hot Bodies Ve8 | Ofna Nexx8 | HPI MTDT | Sakura Zero S
Rolf92 is offline   Reply With Quote
Old 03-02-2012, 05:39 AM   #1328
SteveM's Avatar
Trader Rating: 134 (100%+)
Has anyone tried the new articulated swing shaft CVD's from Spec-R in their Sakura? I've seen them in a Tamiya 417x and they are incredibly smooth at extreme turn angles compared to stock.
SteveM is online now   Reply With Quote
Old 03-02-2012, 05:44 AM   #1329
I know two people who use them. Very smooth in the turns and they say worth the money. Be sure to get v2 though. v1 seems to break easier.
Serpent S120 13.5
Old 03-02-2012, 09:24 PM   #1330
Report from tonights test and tune..
wonderful car for the value, car kept up fine with all the other cars (TC6.1 , and a couple of X-Rays T2 and T3) no major complaints besides the shocks and steering was way too much (That was my fault though) had lots of help from the local track experts and the car by the end of the night was amazing (for what it costs) new upgrades coming soon , Solid Front Diff , New Shocks , ESC Tuning a little bit , using an Element by Castle Creations right now and with the Pinion and stock spur setup temps were consistently at 117 after 4 minute heat runs.
So far loving it , a lot better than my Sprint 2 and TC4.
If anyone is reading this thread and still contemplating on getting one.. get it you wont be let down for the price I promise.
Theas1an is offline   Reply With Quote
Old 03-03-2012, 04:16 AM   #1331
SteveM's Avatar
Would you know which part number? There are several versions out there and some include a 10x5x3 bearing to replace the 10x5x4 in the C-hub.
Old 03-03-2012, 06:38 PM   #1332
Hi guys,
I am a sakura zero S owner also. What would be a good setting for the rear camber, shocks that will make the car stable in tight turns? I still have a little slide on the rear. Please help or give suggestions for me to try.
Thank you in advance.
kikoy is offline   Reply With Quote
Old 03-04-2012, 01:39 AM   #1333
BCZero's Avatar
Originally Posted by kikoy View Post
Hi guys,
Best thing I did was get the softer tamiya short springs, they fit the std 3racing shocks... the yellow works best for me, but they soften up the rear end massively.
Stock: XRay T3 '12, F1: Tamiya F104v2, Buggy: Tamiya TRF201, SCT: AE SC10 4x4 FT, Radio: Airtronics MT-4
BCZero is offline   Reply With Quote
Old 03-04-2012, 04:23 AM   #1334
pejota's Avatar
Add a 1mm spacer under the rear, inner camber links. That helped me a lot.
Hi guys,
Old 03-04-2012, 04:52 AM   #1335
rbsix's Avatar
Default Spur gear mod
Waiting for a new spur seem like forever. So i modified a TA02 spur.
rbsix is offline   Reply With Quote
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
