Old 02-20-2012, 07:22 AM   #1291
Xpress's Avatar
Originally Posted by rbsix View Post
I just finished building a sakura s and I found it's front belt is rubbibg against the chassis just under the steering assembly.. Any idea how to solve this?
By dmz_dx at 2012-02-19
That is the "tension" side of the belt. Pull the slack out of the belt and see if it still rubs? If it doesn't I wouldn't worry too much about it, but you can always dremel or sand a little material off of the chassis.
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 02-20-2012, 08:50 AM   #1292
orcadigital's Avatar
Trader Rating: 61 (100%+)
Originally Posted by kosmickid View Post
Is there a metal alternative for the plastic outdrives on the front spool? I've jut snapped mine with a light impact?
Tamiya makes them. I am not sure which chassis, but I know I have seen them. Just keep in mind, if you replace those with something harder, you will probably break something else.
I have gone through 4 plastic outdrives so far, and all on the same side, so I feel your pain. I just am not sure there is a better option, as plastic outdrives are a lot cheaper then anything else that could break instead around the axle.
Desoto Racing * Serpent America * Boca Bearings
"I was doing fine until about mid-corner when I ran out of talent."
orcadigital is offline   Reply With Quote
Old 02-20-2012, 11:24 AM   #1293
FauxMako's Avatar
Rotate the diff rings so the "dot" is flipped to the high side. If it's at 5 o'clock now, rotate it to 1 o'clock. If it's at 8 o'clock now, rotate it to 10 o'clock. That'll raise the diff up slightly and get rid of the rub while retaining the same amount of belt tension.
Edit:
Reverse that Dot should be on the low side, not the high side since the dot is on the thicker side of the ring.
Mike
3 3Racing Sakura Zeros: Mustang Boss VTA // Lexus LFA USGT // MazdaSpeed 6 TC
Mini M03 & M05
Life is better with a soundtrack
FauxMako is offline   Reply With Quote
Old 02-20-2012, 11:55 AM   #1294
Thanks for the advice!
kosmickid is offline   Reply With Quote
Old 02-20-2012, 02:36 PM   #1295
BCZero's Avatar
They are for the Tamiya TRF 416/417 chassis. But yeah, ppl ive seen use them end up breaking universals instead which cost more...
Stock: XRay T3 '12, F1: Tamiya F104v2, Buggy: Tamiya TRF201, SCT: AE SC10 4x4 FT, Radio: Airtronics MT-4
BCZero is offline   Reply With Quote
Old 02-20-2012, 08:07 PM   #1296
rbsix's Avatar
Edit:
I rotated the holder with dot at the bottom, then filed the chassis a bit..thanks for the replies.
rbsix is offline   Reply With Quote
Old 02-21-2012, 10:34 AM   #1297
ok i have this chassis ons its way, with the 19t center pulley & gear adapter u05
& vert motor mount
what other additional parts should i get? do i need any washers or bearings for the center pulley?
im running on a small carpet track with silvercan
urban is offline   Reply With Quote
Old 02-22-2012, 02:52 PM   #1298
Hey Guys,
Wondering if someone can help me.
Looking to replace the stock arms on my Zero S with the "Narrow" arms from the XI, and replacing the swing shafts with Universals... Has anyone done this? and know what size universal i would need.
|Sakura Zero S Tekin RS Reedy Sonic 21.5T|
goldsworthy1 is offline   Reply With Quote
Old 02-22-2012, 07:17 PM   #1299
rageracing's Avatar
Well the ole girl is officially done tested tuned and ready to race. Sunday will be my first race with the S in VTA. FDR is 3.88 temps after a full pack on the motor were 146 and 138 @ the esc. shortened the wiring on servo and direct wired the BL motor to the esc. she is smooth and quiet. I have never had a car run this free. probably because I have been running Off road. well now i have to buy 2 more for parts and maybe a USGT build. Thank you all for your input on this thread I have read it all and have taken all info I can to improve setup and driveability of this car. Now if my driving skills improve, we will be set.
Thanks Guys.
Pink just makes my car go faster!
~ RadioPost controlled ~ 3R SAKURA ZERO-S USVTA-25.5 ~ Tamiya M05 ~
~ Vintage-RC12L ~ OFNA GTP2 ~
rageracing is offline   Reply With Quote
Old 02-22-2012, 11:21 PM   #1300
Pro10noob's Avatar
Only use the narrow arm on the rear.
Front you need the universals of the Sakura Zero(44 or 46MM) and rear you need the 44MM because of the narrow arms.
And yes i have done it on my Sakura.
After this mod you don't need the narrow suspensionblocks anymore.
regards Roy
Originally Posted by goldsworthy1 View Post
Hey Guys,
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 02-22-2012, 11:25 PM   #1301
Thanks Roy,
Am only replacing the stock rear arms with the XI arms and the rear swing shafts with the Universals... Just wanted to check what size Uni's i needed.
How did u find your car handled after changing the rear arms?
Goldie
Old 02-22-2012, 11:33 PM   #1302
Pro10noob's Avatar
Handling was perfect but i also done the rear shock mod
Had the same setup on the Sakura as on the TRF
regards Roy
l===/o\===l
Old 02-22-2012, 11:35 PM   #1303
What does the rear shock mod involve doing?
Old 02-22-2012, 11:49 PM   #1304
Pro10noob's Avatar
Using front bulkhead covers and the shocktower of the TRF416X.
You get less flex in the rear shock tower so changes to the setup respond better.
You need to widen the holes of the shock tower where it mounts on the bulkhead a bit.
I mean i tiny bit.
This in combination with the Sakura X1 rear arms makes a rock solid car that responds beter to changes then the stock setup.
It also depends on what class your driving.
regards Roy
l===/o\===l
Old 02-22-2012, 11:57 PM   #1305
awesome thanks for your help mate!
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
