Old 12-09-2010, 12:03 PM   #106
over gear's Avatar
Trader Rating: 15 (100%+)
Originally Posted by monkee View Post
with the stock spur, what pinion should i use?
ill be running a 17.5 novak system.
and they did ship my order.. i should have it soon
assuming you are running 17.5 non-boosted... u need FDR around 4.0... 80t/4 x 1.9 = 38t... you'll need a 38t pinion....
over gear is offline   Reply With Quote
Old 12-09-2010, 12:05 PM   #107
over gear's Avatar
Originally Posted by squarehead View Post
It's a crazy issue for any car today. To run higher turn motors, you use small spur gears. With spec cars using 21.5 or 25.5 motors, you use TINY spurs with no holes or potential space for drilling. You shouldn't have to, IMO. The stock motor mount blows chunks. Should have never been designed that way in the first place.
http://os.3racing.hk/products.php?products_key=5048
Makes the motor mount screws vertical instead of horizontal. A stock motor necessity unless you like unbalancing your spur gear by drilling wonky holes in them.
in Asia.... mod is a bigger class than stock... i don't think 21.5 even exist in Hong Kong or China....
Old 12-09-2010, 12:16 PM   #108
monkee's Avatar
Thank you. ill get a 38t.
can you explain fdr to me?
and how you came up with that i need around 4.0 of it?
i will need to use whatever info i get from this to figure out how to pinion my ta05
thanks much!
c
monkee is offline   Reply With Quote
Old 12-09-2010, 01:38 PM   #109
over gear's Avatar
thanks much!
c
FDR is the Final Drive Ratio. FDR = Spur/pinion x internal ratio. sakura internal ratio is 1.90.
from my experience, i run 3.5 to 4.0 for 17.5 . check the motor temp after each run... i try to keep it between 160-170F ...
as for the pinion, what's the cloest one to 38t you have in your pit box? 38t might be too big. Build the car first and see how much room u have. I think you might need a smaller spur.
Old 12-09-2010, 01:46 PM   #110
monkee's Avatar
so are you running a 43pinion?
or did you choose a different spur?
Old 12-09-2010, 02:30 PM   #111
over gear's Avatar
i use 64pitch gears. 88t spur, 42t pinion. FDR=3.98
Old 12-09-2010, 03:05 PM   #112
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
Thumbs up
Just so you guys don't have to do the math, with the various diff and layshaft pulleys available, you can get a bunch of different internal ratios with this car. I would guess some of the larger layshaft pulleys won't work because of the belt lengths, but that's a guess.
I have not tried them all, so I don't know if these belts will handle all of them, but here are the internal ratios for all of the pulleys:
  • 40T/19T: 2.105:1 GEAR
  • 39T/19T: 2.052:1 GEAR
  • 38T/19T: 2.000:1
  • 40T/20T: 2.000:1 GEAR
  • 39T/20T: 1.950:1 GEAR
  • 37T/19T: 1.947:1
  • 40T/21T: 1.905:1 GEAR
  • 38T/20T: 1.900:1 (stock)
  • 39T/21T: 1.857:1 GEAR
  • 37T/20T: 1.850:1
  • 40T/22T: 1.818:1 GEAR
  • 38T/21T: 1.810:1
  • 39T/22T: 1.772:1 GEAR
  • 37T/21T: 1.762:1
  • 28T/22T: 1.727:1
  • 27T/22T: 1.681:1
Some of those larger layshaft pulleys with a 38T diff pulley would be great for VTA or other spec-type classes to keep those pizza tin pinion gears off the car, but I don't see it happening anytime soon with those stock belt lengths.
I made a simple FDR calculator sheet in Excel similar to the one we used for VTA racing for all of the Sakura internal ratios and pulley options. input your spur and pinion combo and it will calculate the FDR for you. No frills, but it will find an optimal FDR if you are looking for a specific ratio.
doug
*GEAR marks ratios only available with the new 39T or 40T gear diff pulleys. Not available for ball or roller diffs.
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Old 12-09-2010, 03:51 PM   #113
I plan on just running in large parking lots with the stock car to start off with.
I'm planning to use a Tacon motor from hobbypartz since its a low cost motor. What KV rating should I use on this car for my use? Also what FDR should I shoot for? I will also be buying a range of pinion gears and spur gears for future use.
Thank you for the Excel spread sheet squarehead. It will come in handy.
bashslash is offline   Reply With Quote
Old 12-09-2010, 04:52 PM   #114
monkee's Avatar
how high are the front shocks/shock towers?
can any racing body fit on these nicely?
what are you guys using for a body
Old 12-09-2010, 05:07 PM   #115
A Ilievski's Avatar
Trader Rating: 39 (100%+)
  • 38T/19T: 2.000:1
  • 37T/19T: 1.947:1
  • 37T/20T: 1.850:1
  • 38T/21T: 1.810:1
  • 37T/21T: 1.762:1
  • 28T/22T: 1.727:1
  • 27T/22T: 1.681:1
doug
3 racing have released 40T pulleys for the gear diff as well, add that into the equation as well
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIG BEARINGS*
A Ilievski is offline   Reply With Quote
Old 12-09-2010, 05:18 PM   #116
squarehead's Avatar
LOL, one more setup that the stock belts won't fit.
Everything depends.
Nothing is always.
Old 12-09-2010, 06:14 PM   #117
CuLeX's Avatar
Thumbs up
Squarehead thanks for the FDR sheet.
CuLeX is offline   Reply With Quote
Old 12-09-2010, 07:41 PM   #118
squarehead's Avatar
Thumbs up
I updated the above internal ratio list, as well as the XLS file on my server. Keep in mind, the new 39T and 40T diff pulleys are only available for the planetary or gear diffs, and not ball or roller diffs.
Everything depends.
Nothing is always.
Old 12-09-2010, 10:50 PM   #119
-Bloody kiss~ two really good looking guys XDD
-vampire knight?
-not sure if higurashi will fit in this but it has really cute characters (but its a psychological/horror anime?? kinda like school days lol)
-kimi kiss
-fruit basket (manga is way better)
-loveless
damn.. i have some more but those were the only ones on the top of my head XDD
try looking them up on mangafox and onemanga.com ^
[URL=http://www.bluebarngraphics.com/long_island_web_design.html]Long Island Web Design[/URL]|[URL=http://www.bluebarngraphics.com/website_redesign.html]Website Redesign[/URL]|[URL=http://www.bluebarngraphics.com/]LI Web Design[/URL]
gran smith is offline   Reply With Quote
Old 12-10-2010, 12:03 AM   #120
PizzaDude's Avatar
@Over Gear
What batteries do they currentley run in mod?
It used to be 4cell (nimh) for TC which was unheard of in the rest of the world.
Do they run lipo or life f.e.?
Just curious.
I know 23t also used to be huge. But I really do not know what the switch Li-batt and BL did to the Asian rc racing world....
PizzaDude is offline   Reply With Quote
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
