Old 01-20-2012, 12:23 PM   #1036
davenz's Avatar
I dont use all of the battery holders, as you can see by the pics i use - in this case - xray servo mounts with some ball studs to hold the battery out away from the belts.
I have cut the rear block so all that is left is the rear peice that screws to the chassis, and then I have made a bracket to hold the battery in place.
davenz is offline   Reply With Quote
Old 01-20-2012, 01:19 PM   #1037
SteveM's Avatar
Trader Rating: 126 (100%+)
I like your idea of the servo mounts with ball studs. I am sure I have some Tamiya plastic servo mounts from my old M-03 that should work equally well.
SteveM is offline   Reply With Quote
Old 01-20-2012, 01:29 PM   #1038
davenz's Avatar
yes the m03 mounts work well. I am using them in my zero.
Old 01-20-2012, 02:06 PM   #1039
SteveM's Avatar
I found that I only needed the one post mount up front. The belt comes close to the plastic so I used the Dremel to shave it down a bit and to also rounded off the edges a bit just to avoid any possibility that the belt may fray. My lipo packs use the bullet connectors and when I put these at the rear of the chassis the battery leads act as the rear spacer.
Old 01-20-2012, 10:25 PM   #1040
Hey Davenz,
Are you running the sakura XI steering on your Sakura Zero/S? Is it a direct fit?
Thanks!
Jeff
cfijeff is offline   Reply With Quote
Old 01-20-2012, 11:27 PM   #1041
davenz's Avatar
Hey Jeff, yes I am running the x1 steering, and yes it is a direct fit. But I did find with my 13.5 I reverted back to the origional zero steering as I wasnt getting enough steering. I will need to do a bit more testing there.
Dave
Old 01-21-2012, 05:14 AM   #1042
SteveM's Avatar
Has anyone used the kit supplied treaded tires and rims either on an indoor carpet track or outdoors on asphalt?
Old 01-21-2012, 06:01 AM   #1043
I used the kit tyres on asphalt at my outdoor club meeting last week. It was -1 and track had ice in some places and I had no wets so I used the kit tyres. It ran really well and gripped reasonably well
kosmickid is offline   Reply With Quote
Old 01-21-2012, 06:18 AM   #1044
SteveM's Avatar
I might glue my set up and give them a try. Thanks.
Old 01-21-2012, 07:26 AM   #1045
nexxus's Avatar
Trader Rating: 296 (100%+)
Anyone know of a stockist in Australia of bits for this, I am building up my car and need a SAK-14 and a SAK-34PK and the only Aus store I am aware of, feralbatteries has none until after Chinese new Yr, usually I'd do an order via EMS from Hong Kong but with Chinese new Yr it won't even process for over a week and I'm an impatient persoN!
Awesomatix A800X / A800
nexxus is offline   Reply With Quote
Old 01-21-2012, 02:43 PM   #1046
I'm going to order the Hotbodies TCX lipo mounting parts for my narrow chassis to help mount them in, seems like a better solution than tape! Anyone tried it?
Old 01-21-2012, 04:50 PM   #1047
nexxus's Avatar
I just ordered the Exotek Lipo Strap, looks like a direct fit.
Old 01-21-2012, 07:29 PM   #1048
mingnon's Avatar
Nexxus
i use topgunrchobbies.com.au have never had a problem with bits, just had a quick look and it looks like he has the sak-34 in stock, and he is in Aus :-)
cheers
mattb.
---------------------------SMA The Home of GREAT Racing------------------------------
mingnon is offline   Reply With Quote
Old 01-21-2012, 07:35 PM   #1049
mingnon's Avatar
Do you have the part no's for this, will have a look as well. Have been taping the narrow chassis, and where i am (Aus) we can charge lipo in car which does save some hassles.
Old 01-21-2012, 08:17 PM   #1050
nexxus's Avatar
Originally Posted by mingnon View Post
Nexxus
cheers
mattb.
No Sak 14 though.
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 05:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 10:21 AM
