Old 12-08-2010, 02:22 PM   #91
Overgear:
Nice pics, thanks.
So the S shocks are shorter than the original zero shocks?
Or just the springs?
Eat more possum!
Lees52 is offline   Reply With Quote
Old 12-08-2010, 03:41 PM   #92
over gear's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Lees52 View Post
Overgear:
Nice pics, thanks.
i believe both the S and regular Zero run a shorter shock body.
over gear is offline   Reply With Quote
Old 12-08-2010, 03:50 PM   #93
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
How on Earth did you tighten the motor down without the new motor mount and that spur/pinion combo?
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Old 12-08-2010, 04:40 PM   #94
over gear's Avatar
i only tighten the motor screw toward the front. the rear one, i tighten just enough that i can slide the motor front/back with my bare hand. Use thread lock. so far so good.
Old 12-08-2010, 04:41 PM   #95
Originally Posted by over gear View Post
i do have some hopups...
  1. alloy spur adaptor
  2. 19t pulley. (stock is 20t. 19t loosen up the front belt a lot.)
  3. 4mm taller front and rear shock tower. (the stock ones are design for short mini cooper springs)
  4. Tamiya servo saver
  5. Tamiya servo mount
  6. Tamiya shocks
Just wondering if you can provide me with info on the towers, spur adapter, and pulley.
bashslash is offline   Reply With Quote
Old 12-08-2010, 04:46 PM   #96
over gear's Avatar
Center Pulley Set 19T For 3racing Sakura Zero SAK-07A
Aluminium Gear Adaptor SAK-U05
Sakura Zero Front Graphite Shock Tower Plus 4mm SAK-35/4/WO
Sakura Zero Rear Graphite Shock Tower Plus 4mm SAK-36/4/WO
Old 12-08-2010, 04:46 PM   #97
Pro10noob's Avatar
Both car have shorter shock bodies like the Top Photon and the Team Magic E4
Check pics.
regards Roy
3Racing Sakura Zero S-eigen-autos.jpg   3Racing Sakura Zero S-eigen-autos-1.jpg
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 12-08-2010, 04:49 PM   #98
monkee's Avatar
really bummed mine hasnt shipped yet.
i paid hks hobby for it monday and i cant get any response from them.
any other hobbystore would have shipped it yesterday
monkee is offline   Reply With Quote
Old 12-08-2010, 07:33 PM   #99
over gear's Avatar
i just spoke to Alan from HKS hobby... he said he shipped all Sakura orders yesterday... did u check your email?
Old 12-08-2010, 08:21 PM   #100
monkee's Avatar
i did check my email.
i ended up getting ahold of someone there.. he stated (i think) that it was shipped and i should have tracking in my email.
i havent received an email from them that i can find. in my mail or my spam
im sure it will show up in the next 2-3 days
Old 12-08-2010, 08:26 PM   #101
Madulla's Avatar
Just got back from the track. Car ran great. Car would spin like a top at the end of the straight, no rear traction. Adjusted using different springs. I only had some longer spings with me so tried those, in the end I was right on pace with the other drivers. I did had problems traction rolling. I am waiting for my 3racing shocks and spring kit, hopefully they will help. I am so happy with the car that I am going to get another for my VTA. I am using the narrow lipo chassis.
Can't wait fo some people who know how to setup a car to help.
I did the same thing as overgear to get the motor in. But I got I everything in the right place, removed the spur and pinion, tightened the motor down, put the spur back in place and then slid the pinion into the right place. Thankfully the new motor mount will be here in a week.
Is the only way to remove the spur to take off the 8 srcews holding on the top deck and pull it up?
Madulla is offline   Reply With Quote
Old 12-08-2010, 09:26 PM   #102
zipp's Avatar
I dremeled a hole in my spur, just big enough for my hex driver to go through.
Take a look at the photo. it's kinda shoddy work but I was in a rush to get the car running it works well though, was able to tighten the motor screw properly. Note that i'm running a 106t 64p spur, which is about the same size as the original 80t 48p spur included in the kit.
I would've thought you guys shouldn't have any problems with the original spur though. it has several large holes towards the outer part of the spur which should allow you to stick a hex driver through from the battery side. correct me if i'm wrong, I didn't try the original spur at all, just basing this on visual observations.
zipp is offline   Reply With Quote
Old 12-09-2010, 08:55 AM   #103
Smile
What motor mount are you guys talking about? I see HKS has 2 different motor mounts listed. I went to the 3R site and they have the same 2 and a third one coming out soon.
Just want to see which one will resolve the issue that is being talked about so I can make a shopping list
Old 12-09-2010, 09:10 AM   #104
squarehead's Avatar
It's a crazy issue for any car today. To run higher turn motors, you use small spur gears. With spec cars using 21.5 or 25.5 motors, you use TINY spurs with no holes or potential space for drilling. You shouldn't have to, IMO. The stock motor mount blows chunks. Should have never been designed that way in the first place.
http://os.3racing.hk/products.php?products_key=5048
Makes the motor mount screws vertical instead of horizontal. A stock motor necessity unless you like unbalancing your spur gear by drilling wonky holes in them.
Everything depends.
Nothing is always.
Old 12-09-2010, 12:04 PM   #105
monkee's Avatar
with the stock spur, what pinion should i use?
ill be running a 17.5 novak system.
and they did ship my order.. i should have it soon
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 05:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 10:21 AM
