Old 01-03-2012, 07:46 PM   #931
Big Midget's Avatar
Trader Rating: 98 (100%+)
Do the parts interchange between the Sakura Zero and the Zero S.
I'd like to put the bulkheads and the bulkhead covers from the Sakura Zero on the Zero S?
I hope I'm not getting my cars mixed up?? Just wandering if the aluminum pink bulks would fit the Zero S?
Dee & Mee Hobbies
Fastlane Raceway-wwwfastlanehobbies.com
Topeka On-Road Racing-Jake's R/C Pro-Am Topeka,Ks
www.ZigPhoto.com,RickyRacer Lidz,Absolute Tattoo,Fuzzy Dice Decals
Big Midget is offline   Reply With Quote
Old 01-03-2012, 07:49 PM   #932
Originally Posted by orcadigital View Post
Mike's tocal track is also selling 3 Racing parts online as well (tisk tisk).
Hot Shots RC
http://www.hotshothobby.com/3Racing-Parts_c32.htm
I also know they are due to get a massive stock order this week of parts.
I will also add that HKS has been nothing but terrible experiences for me, and I would not recommend them in any way, shape, or form.
Agree with your comments on hks. 2 orders 2 major problems for me. One ended in a PayPal dispute before they would work it out. TQ , hotshots, and rc Mart get my business
3Racing Sakura XI 17.5 TC
Formula Rabbit (FGX conversion) 21.5
STRC LCG 2WD Slash 17.5
Serpent S120 13.5
6376vette is offline   Reply With Quote
Old 01-03-2012, 08:42 PM   #933
watzonee's Avatar
Trader Rating: 28 (100%+)
Google TQ rc racing.... He sells most if not all parts for the sakura.
watzonee is offline   Reply With Quote
Old 01-03-2012, 09:12 PM   #934
texastc's Avatar
Tqrcracing.com
Exotek F1 Ultra Tamiya TRF101 Tamiya TT02r SpeedPassion LM1 and SP1 C main mainstay. Unless there is a D
TCdoesRC
texastc is offline   Reply With Quote
Old 01-03-2012, 11:24 PM   #935
davenz's Avatar
hey Big Midget, yes the pink bulkheads and other parts do fit thr 's', they are all interchangable.
I purchased an 's' to be stable mate with my zero, and I also purchased the ali parts for it., I had no problems fitting the ali parts... Ive evn got the x1 steering system in both cars.
Dave
sakura zero - tekin rs pro/13.5 redline
sakura sero ( 's' with zero alloys) viper 21.5
davenz is offline   Reply With Quote
Old 01-04-2012, 12:05 AM   #936
mingnon's Avatar
Did the X1 steering go straight in or did it require mods? How are you finding it?
Dave
---------------------------SMA The Home of GREAT Racing------------------------------
mingnon is offline   Reply With Quote
Old 01-04-2012, 01:09 AM   #937
Just out of curiosity...
Has anyone got a mylaps transponder mounted in their car using the bracket that comes with the transponder?
Ive been looking at my car for about an hour and cant find a place to put the bracket that will make it easy to remove and change between cars in the future.
|Sakura Zero S Tekin RS Reedy Sonic 21.5T|
goldsworthy1 is offline   Reply With Quote
Old 01-04-2012, 01:48 AM   #938
wollow86's Avatar
You can use servo tape to mount the transponder directly or using the bracket. That's all I do.
Supporting Aussie hobby shops:
- www.MRJRacing.com.au - - www.feralbatteries.com.au - - www.actionrc.com.au -
wollow86 is offline   Reply With Quote
Old 01-04-2012, 04:31 AM   #939
BCZero's Avatar
Yes I've done a part for part conversion and they all fit fine.
Also, to the guys asking about leaking diffs, a tiny bit of ae green slime on the parts of the casing that meet the air will sort that out in no time.
Stock: XRay T3 '12, F1: Tamiya F104v2, Buggy: Tamiya TRF201, SCT: AE SC10 4x4 FT, Radio: Airtronics MT-4
BCZero is offline   Reply With Quote
Old 01-04-2012, 09:13 AM   #940
I use one of the screws for the upper deck. Use the one in the front on the servo side. The transporter can be mounted to clear the steering and the belt. It also has a lot of stuff around it so it won't get damaged even in a major crash. No need to use a longer screw. Kit screws are long enough.
Serpent S120 13.5
Old 01-04-2012, 09:33 AM   #941
Thanks for the advice...gonna redo the diff with different oil grade this weekend.
i just downloaded Sakura Zero manual and notice the rear is using ball diff + front is solid axle. Would that improve more feel & grip? Or is that mainly for experienced racer?
driftmeister8 is offline   Reply With Quote
Old 01-04-2012, 10:40 AM   #942
davenz's Avatar
Hey Mingnon, the x1 steering does fit strait into the zero/'s' chassis. but since im using the centre weights I did have to modify the top part of the steering,, there is a peice that sticks out the back . I cut that off , now I have clearance for centre weights without drilling extra holes.
I have also turned the servo 90* to fit across the chassis. I did have to drill extra holes for servo mounts.
I find it alot smoother and the car seems to turn in more direct.
What u see in the pics is not the finished result, you can see the peice i had to cut off, and now I have replace the connecting arm with the correct one. Also now i have a low profile servo mounted.
It gives plenty of room for electrics.
I forgot to mention. I am using the 's' bottomg chassis plate on the zero.
Old 01-04-2012, 01:32 PM   #943
mingnon's Avatar
Davez
appreciate the reply and the pics, think i may have a go at this myself.
Old 01-05-2012, 04:42 AM   #944
BCZero's Avatar
Lightbulb
I tried all the combinations and settled on gear diff in the rear with the solid axle up front, the ball diff just didn't feel as settled for me, but it's probably dependent on your driving style....if you get a really thick 100k+ diff oil in the front it will act close enough to a fixed axle any way, and then you still have the metal out drives, compared to the plastic ones that break easy on the fixed diff...I'm one break away from going back to 2 gear diffs.
Old 01-05-2012, 05:13 AM   #945
orcadigital's Avatar
Trader Rating: 61 (100%+)
Just curious, what is the purpose of converting to the XI steering rack? Is it just to orient the servo 90 degrees? I have not had any space issues with electronics, and just not understanding the benefit of the conversion?
I run 100k front, 2k back, and have been pleased with the results. I have another diff built with 800 I might try swapping in the rear as well, as I know some other drivers are running 700 in their Xray's with good results. I have a front spool, but the plastic outdrives do seem a weak point, and I am hesitating to use it.
Desoto Racing * Serpent America * Boca Bearings
"I was doing fine until about mid-corner when I ran out of talent."
orcadigital is offline   Reply With Quote
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
