Old 12-17-2011, 06:34 PM   #871
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Originally Posted by ozzy-crawl View Post
I have had a zero s for about 7 months, just blew the rear diff a few weeks back
There v1. Run it every week with 10.5 and boost/turbo
Replaced gears with v2 $5 fix
So the update between V1 and V2 is just the internal gears?
YR4Dude is offline   Reply With Quote
Old 12-17-2011, 08:31 PM   #872
ozzy-crawl's Avatar
Trader Rating: 14 (100%+)
The gears I got said v2 but I could not tell any difference between the v1
They may be slightly harder plastic or some thing ???
The original gears hold up well I would not worry about it unless you break one.
MST XXXD vip
MST FS-01d
Xray T4
Xray T3
AE Sc10.2 AE SCB
ozzy-crawl is offline   Reply With Quote
Old 12-19-2011, 05:24 PM   #873
Does the kit come with front and rear sway bars as standard?
kosmickid is offline   Reply With Quote
Old 12-19-2011, 05:34 PM   #874
No the kit doesnt come with sway bars...
One of the add-on options im looking into for mine at the moment... but questioning how much difference they will make, as mine already handles pretty well!
goldsworthy1 is offline   Reply With Quote
Old 12-19-2011, 09:03 PM   #875
Makes a ton of difference on mine but I am running the stiff chassis. My car is now more zero than zero s. Never tried them on the stock chassis but they have become a major tuning point for me. Given the low cost go ahead and get some. That can't hurt anything. I will add that if you are still learning shock and spring and chassis balance and set up then wait for the sway bars. Too much adjustability may be overwhelming.
3Racing Sakura XI 17.5 TC
Formula Rabbit (FGX conversion) 21.5
STRC LCG 2WD Slash 17.5
Serpent S120 13.5
6376vette is offline   Reply With Quote
Old 12-20-2011, 12:37 PM   #876
Thanks for the advice. I'm a noob to touring cars and will be running in 13.5t class at my club on Tarmac/asphalt. So I assume it will be ok to run without sway bars until I learn and get better at driving??
Old 12-20-2011, 07:19 PM   #877
yes you can run without sway bars without any problems. This will also allow you to concentrate on learning how to tune the rest of the chassis. I only added the bars after I understood the tire angles shocks springs and balance of the car.
Serpent S120 13.5
Old 12-20-2011, 09:09 PM   #878
spring71's Avatar
Smile
Sakura parts are restocked at TQ.
http://www.tqrcracing.com/shop/produ...t.asp?s_sort=4
FYI, Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
tq@tqrcracing.com
spring71 is online now   Reply With Quote
Old 12-21-2011, 02:01 AM   #879
Hey guys
i want to increase the steering angle of my sakura s for drifting.Are there any hopup parts fits sakura for this.I saw on some local forums some people chip the front knuckle arm where it meets the c-hub at the end but i don't want to do this.
Regards
erkutt is offline   Reply With Quote
Old 12-22-2011, 10:19 AM   #880
vti-chris's Avatar
Can this car handle the power of a brushless 7000KV motor?
We don't have rules here so we run whatever motor we like.
What would be best for it that won't need a spur/motor mount change?
What pinion gear should i use?
Xray/OS/Savox/Sanwa
Axial XR10
Sakura Zero S/Castlecreations
RCO
vti-chris is offline   Reply With Quote
Old 12-23-2011, 06:15 AM   #881
I got my Kit today...just in time for Christmas....excited!!
I did a search but couldnt find any guides to FDR and Rollout, Just need to understand the basics. In my class ill be running 13.5T brushless, could some suggest a 64dp Pinion and spur for tight and twisty asphalt track?
Old 12-24-2011, 04:03 AM   #882
BCZero's Avatar
Have a look at petitrc dot com.
They've got a lot of good setup sheets for the zero and a gear chart.
Once you have the gear chart, you can use a generic FDR calculator.
Stock: XRay T3 '12, F1: Tamiya F104v2, Buggy: Tamiya TRF201, SCT: AE SC10 4x4 FT, Radio: Airtronics MT-4
BCZero is offline   Reply With Quote
Old 12-24-2011, 05:12 AM   #883
vti-chris's Avatar
What size LIPO battery do we use on this?? Both capacity and size?
I will be ordering from hobbyking...how many C do we need to be OK with 6000KV motor and 100A ESC?
Xray/OS/Savox/Sanwa
Axial XR10
RCO
Old 12-24-2011, 07:13 AM   #884
SteveM's Avatar
Trader Rating: 126 (100%+)
My Zero arrived Friday and I had received my upgrades a few days earlier so I am set for Christmas.
SteveM is offline   Reply With Quote
Old 12-25-2011, 05:40 AM   #885
BCZero's Avatar
First up, size is 2S lipo.
Secondly, you'd want 20C or more preferably, however both discharge and the capacity requirements depend on what you plan to do.
I.e. for bashing, get the largest capacity you can afford. For racing, capacity is less important unless you run enduro style races, so a smaller capacity can be traded off against high burst discharge rate or C rating and weight.
Note if you do plan to race the Hobbyking batteries are not roar legal yet, even though Hobbyking claim a few of them are....
Good luck.
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 05:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 10:21 AM
