Old 11-11-2011, 04:19 AM   #766
Pro10noob's Avatar
Why do you need a longer front belt??
regards Roy
Originally Posted by 1101 View Post
hi there
whats the number of teeth on each belt.
I need to find some slightly longer for the front belt from (I have some from other brand of cars)
522 cant be right ??
http://racerlog.com/wiki/Touring_Car_Belts
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 11-11-2011, 04:32 AM   #767
cannon's Avatar
Trader Rating: 35 (100%+)
hi there
Why dont you simply count the number of teeth on each of your belts. Surely not that lazy
QUICK TIP ... divide by 3 and you have the answer
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 11-11-2011, 04:40 AM   #768
regards Roy
Front belt is far too tight. Was hoping to use a spare belt off my other cars.
I know, use smaller pullies. It bought the pullies when I bought the car, but didnt know I need all the other hop-up parts to run smaller pullies. garrh
Ok, looks like no other car uses belts this long
1101 is offline   Reply With Quote
Old 11-11-2011, 04:46 AM   #769
Pro10noob's Avatar
What other options besides the alloy spurgear holder?
It's cheap and eliminates wobble in the spur also and you don't need to open the spur holes to fit the plastic pulley adaptors.
regards Roy
l===/o\===l
Old 11-11-2011, 04:54 AM   #770
cannon's Avatar
Get the Sakura Zero belt for the real Sakura (Part no SAK-11) It is far softer and is far looser
The Zero S belt is a far lower quality
Old 11-11-2011, 06:13 AM   #771
orcadigital's Avatar
Trader Rating: 61 (100%+)
What is the part number for the Zero S belt? All I see is the one option SAK-11. I would be surprised if the company made a belt for the kits, but only sold the other belt separate. I am just surmising though.
Desoto Racing * Serpent America * Boca Bearings
"I was doing fine until about mid-corner when I ran out of talent."
orcadigital is offline   Reply With Quote
Old 11-11-2011, 11:58 AM   #772
FauxMako's Avatar
According to the manuals both the Zero and the Zero S use the same belts. SAK-11 on the front and SAK-12 on the rear. Since they share the same drive train, that makes sense.
You do need to get the alum spur gear holder to use any of the optional pullies. The plastic spur gear holder has the 20T pully permanently attached.
Mike
3 3Racing Sakura Zeros: Mustang Boss VTA // Lexus LFA USGT // MazdaSpeed 6 TC
Mini M03 & M05
Life is better with a soundtrack
FauxMako is offline   Reply With Quote
Old 11-11-2011, 02:38 PM   #773
I have one of these (bought for spares)
the Sak11 is differnet, its Bando brand. Markings on it are different as well. I'll give it a try.
I'll get that metal spur holder as well then. Zero-s kit part has a wobble, as mentioned above.
Old 11-11-2011, 04:11 PM   #774
cannon's Avatar
The bando belts are far higher quality and will stretch a little bit after a few uses. Unlike the full black belt that comes with the S
Old 11-11-2011, 04:13 PM   #775
cannon's Avatar
The S is a cheap kit so gets a cheap belt The option part is afr better quality
Old 11-11-2011, 04:30 PM   #776
No excuse for a kit belt that is basicly UNUSABLE by being too short
Leaves the kit almost unusable as is.
3racing could have easily put in a belt 2 or 3 teeth longer
Aprt from that one thing, would be the perfect kit for 1st RC car.
Old 11-11-2011, 04:51 PM   #777
cannon's Avatar
They do work .. they just take far longer to stretch. I know a lot of guys using the standard belt ... it just took longer to wear in
Old 11-11-2011, 04:56 PM   #778
texastc's Avatar
I never had an issue with the belt. Using stock pulleys and everything, just adjusted adjusters on the diff and was good. Of course its my first TC and I wouldn't have known any better anyway. Regardless, after 6 months I'm sure its stretched by now.
Exotek F1 Ultra
Exotek F1R
CRC Gen-X 10 LE
Kyosho Plazma F1
TC does RC
texastc is offline   Reply With Quote
Old 11-11-2011, 05:00 PM   #779
mingnon's Avatar
Run two of these, one for the young fella to bash/crash and learn and one for indoor i use
standard belts on both, never had any issues, plenty of adjustment available to make sure they arent to tight
---------------------------SMA The Home of GREAT Racing------------------------------
mingnon is offline   Reply With Quote
Old 11-11-2011, 05:14 PM   #780
pejota's Avatar
Does anyone know if 3racing offers anything other than a 4 degree hub? I thought i saw a 2 and 6 degree hub as option parts.
pejota is offline   Reply With Quote
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 05:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 10:21 AM
