Old 09-27-2011, 02:36 PM   #676
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
Originally Posted by timmay70 View Post
Too bad... I am attempting to make it to USIC in Cleveland that week...
booyah.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 09-27-2011, 03:01 PM   #677
timmay70's Avatar
Originally Posted by seaball View Post
booyah.
I knew you missed me.
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Old 09-27-2011, 07:31 PM   #678
mingnon's Avatar
Originally Posted by Repulse View Post
I am new to both touring cars and drifting (currently just watching), and have been really interested in the Sakura Zero S. There are two tracks near me, one has drifting only, and the other has both. I have a couple questions going along with this. Is the Zero S a good platform for someone new to both? Would it be recommended for me to just buy one and swap tires, etc or buy two kits? As far as electronics goes, I plan on using a Tekin RS Pro and a Tekin RedLine 17.5 for touring, what would suggested for drifting? I run a Kyosho SCR in short course, but in the winter the only indoor track is drift/touring car.
Hi
going through the same process, have got Zero S set up for indoor carpet, heavy duty rear diff, solid front, standard spur, vertical motor mount and alloy bits, currently running Team Powers 3000kv, 60A esc running on Xceed 32 tyre.
Also love to drift, so bolted on a set of hard drift, and gave it a bash on the bitumen, only change made was pinion gear. It drifts remarkably well, almost on par with my tb03.
Unfortunately we don't have any indoor drifting, but i really think you may be able to get away with one car (initially).
---------------------------SMA The Home of GREAT Racing------------------------------
mingnon is offline   Reply With Quote
Old 09-27-2011, 09:37 PM   #679
Mignon,
Thanks for the info.
Repulse is offline   Reply With Quote
Old 09-27-2011, 10:34 PM   #680
mingnon's Avatar
Default Shocks
Anyone know of good adjustable (threaded body) shocks as replacements for kit ones?
Old 09-27-2011, 10:53 PM   #681
Pro10noob's Avatar
Yeah the Sakura Zero set.
You won't find anything cheaper and of a good quality as the 3Racing set.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 09-27-2011, 11:28 PM   #682
These are the ones that were suggested, and they are in stock at the moment.
http://www.tqrcracing.com/shop/produ...on_id=&pg_no=1
I read that, this is one of the items that I should get when I order my car, along with a couple other "must have" items.
Old 09-27-2011, 11:49 PM   #683
BCZero's Avatar
If you did want to go to other shocks, you need to get the +4mm shock towers, which actually makes it signifigantly more expensive than the zero shocks.
Stock: XRay T3 '12, F1: Tamiya F104v2, Buggy: Tamiya TRF201, SCT: AE SC10 4x4 FT, Radio: Airtronics MT-4
BCZero is offline   Reply With Quote
Old 09-28-2011, 12:53 AM   #684
off road god's Avatar
Hey BC,
Whats the deal with the 4+ shock towers?
WERKS RACING...PRO1RC...HEX CREW...BATTLEFIELD R/C...LOSI 2.0...JP PIPES...AKA,PROLINE TIRES...SPEKTRUM DX3R...JR SERVOS... PAUL CONWAY,TECHNICAL ADVISOR.
SAKURA ZERO S...NOVAK ELECTRONICS...MI SERVO...HPI PRODUCTS...FUTABA
off road god is offline   Reply With Quote
Old 09-28-2011, 02:03 AM   #685
mingnon's Avatar
regards Roy
Cheers for all the replies, saw them but wasn't sure if they where okay, hunting down a set now
Old 09-28-2011, 02:54 AM   #686
BCZero's Avatar
The 4+ shock towers basically jack the mount points up 4mm to fit the standard TC shocks - i.e TRF Tamiya, Xray, HPI etc - if you dont plan on using those shocks it doesnt matter, but if you already have a set its probably cheaper to buy teh shock towers at $20 than to buy new shocks...then again the sakura zero shocks are only about $20 anyway, so its individual choice really.
Heres a link so you can see what i mean:
bitDOTly/n809Yj - replace DOT with a .
Cant post links so used a shortener, but its just a link to 3racings site
Old 09-28-2011, 06:05 AM   #687
Originally Posted by off road god View Post
Hey BC,
the longer shocks provides more droop
cheapskate.brok is offline   Reply With Quote
Old 09-28-2011, 06:10 AM   #688
cannon's Avatar
Trader Rating: 35 (100%+)
Errr .. not really. We got 3 Racing to make the +4 towers and the reason was to allow the use of longer TRF style shocks with normal length springs
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 09-28-2011, 09:27 AM   #689
Madulla's Avatar
I needed the 4+ towers when I switched from 3 Racing springs to use AE springs(which are longer), I also use the -1 spring base. The towers are only needed when you use TC shocks or springs.
Hobbywing North America Team Driver
hobbywingdirect.com
CARCAR VP carcar.ca
Madulla is offline   Reply With Quote
Old 09-28-2011, 12:21 PM   #690
Default silver can
hello im looking for some info and yes im newbee to tc
we will be running on a small carpet track with silver cans
and need to know what i should start out gearing at?
80 spur 30 pinion?
does the stock springs work?
what extra parts should i order to keep the car on the track...no lhs around here
what should I upgrade besides motor mount?
thanks
urban is offline   Reply With Quote
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 05:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 10:21 AM
SEO by vBSEO 3.5.0
