Old 09-02-2011, 12:03 PM   #616
Pro10noob's Avatar
Where are you from Stef?
regards Roy
Originally Posted by Stef71 View Post
Hi, I've ordered a Sakura Zero S and a Ezrun combo with a 9t 4300kv motor. It's hard to get info about this kit in Europe, so I'm looking for your help. Can somebody tell me the FDR i should use with it. And by the way parts I should buy to make it run.
Thx
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 09-02-2011, 12:37 PM   #617
texastc's Avatar
Thx
Can't offer you an fdr for that combo as I run a 25.5 in VTA. But highly suggest the vertical motor mount first. I added aluminum bulkheads later on. Just because I stripped the plastic after a while.
Exotek F1 Ultra
Exotek F1R
CRC Gen-X 10 LE
Kyosho Plazma F1
TC does RC
texastc is offline   Reply With Quote
Old 09-02-2011, 01:21 PM   #618
Stef71's Avatar
I'm from the south of France, near Italy. After a few offroad rtr cars I'm try my first onroad kit. I was looking for a cheap entry level car and I've found that amazing one. Why do I need the vertical motor mount?
Stef71 is offline   Reply With Quote
Old 09-02-2011, 01:56 PM   #619
Pro10noob's Avatar
http://www.lmi-racing.com/index2.php
For parts in Europe.
Vertical motormount is for much better acces to your pinions.
Go for the alloy spurgear adaptor and 19 teeth side pulleys.
This will free up your drive train a lot and gives you a IDR of 2
You want to run a 9T motor??
Start with a FDR of 8 and start running the car.
Temp the motor at about 2 minutes run time and see what temp the motor got.
If you want to eliminate any fade stay below 65 degrees.
If temp is above it go lower on the FDR if it is cooler go a bit higher.
It also depends on what kind of track you are running.
regards Roy
l===/o\===l
Old 09-02-2011, 01:58 PM   #620
texastc's Avatar
It's easier to work with. More accessible.
Exotek F1 Ultra
Exotek F1R
CRC Gen-X 10 LE
Kyosho Plazma F1
TC does RC
Old 09-02-2011, 02:42 PM   #621
Stef71's Avatar
Thank you very much for your answers !
So, I add the motor mount and the gear adaptators to my wishlist :
I'll buy later the bulkheads
For the pulley is this the right one?(I'm not yet allowed to post links) :
SAK-07A Center Pulley Set 19T For 3racing Sakura Zero
Do I need to buy a pinion too?
Old 09-02-2011, 03:34 PM   #622
wallot's Avatar
kit comes without pinions as it depends on your motor choice and needed FDR ratio
DEX408 - Speed Passion Silver Arrow v2, LRP Dynamic 8
Dex410 V3 - Tekin RS Pro, 7.5t Redline
F1-09 - Tekin RS Pro, 17.5t Redline
Sakura Zero S - LRP Quantum, Saturn 20T
KoPropo Eurus
wallot is offline   Reply With Quote
Old 09-02-2011, 07:40 PM   #623
silvalis's Avatar
Trader Rating: 29 (100%+)
Does anyone know where I can get the spur gear washers/shaft (SAK06)? Everywhere seems to be out of stock...
silvalis is offline   Reply With Quote
Old 09-02-2011, 11:33 PM   #624
Stef71's Avatar
HTML Code:
According to your advice to get a 8 FDR with a 2 IDR I should use a 27t 64p pinion gear and a 108t spur gear or a 104t X 26t or a 100t X 25t, am I right?
Old 09-03-2011, 01:12 AM   #625
Stef71's Avatar
I looked everywhere around for you and the only one I've found is in great Britain on RC RACING UK's web site ...
Old 09-08-2011, 08:46 AM   #626
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
wrong thread
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 09-13-2011, 08:58 PM   #627
does any one have a setup for tight med. traction carpet track 17.5 stock
hotrod306 is offline   Reply With Quote
Old 09-14-2011, 03:33 AM   #628
LOSI123's Avatar
Trader Rating: 63 (100%+)
Do TRF Tamiya shocks fit on this car? or are there any parts needed to make them fit?
LOSI123 is offline   Reply With Quote
Old 09-15-2011, 02:13 AM   #629
the trf shocks have the same sice as the sakura one. big diffence between the shocks is only the price. the sakura shocks are cheaper and works also great.
gpmp is offline   Reply With Quote
Old 09-15-2011, 04:40 AM   #630
LOSI123's Avatar
thanks, Also does any one know if the sakura zero gear diff v2 SAK-65/V2 is smoother than the standard S Gear diff as the ones with the kit are super stiff and crap. Or if there is a better gear diff that fits rear.
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 05:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 10:21 AM
SEO by vBSEO 3.5.0
