Old 08-18-2011, 09:30 PM   #601
sporadicidiocy's Avatar
My sakura should arrive tomorrow, what FDR should I run if I am to use a 10.5T no timing? My club currently runs mostly indoor on smooth concrete floor.
90% Sakura Zero: Reventon S V3.0 10.5T
Sakura Ultimate: GTB2 17.5T
F104 Pro: SXX V2 Trackstar 21.5T
F103 Chevronmodels 6-wheel conversion
sporadicidiocy is offline   Reply With Quote
Old 08-22-2011, 07:45 PM   #602
spring71's Avatar
Smile
Sakura Parts are restocked today at TQ RC RACING.
Click Here to see the restocked items.
Click here to visit Sakura Zero Parts Store.
FYI,Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
http://www.tqrcracing.com
tq@tqrcracing.com
spring71 is offline   Reply With Quote
Old 08-22-2011, 07:51 PM   #603
texastc's Avatar
Originally Posted by spring71 View Post
Sakura Parts are restocked today from 3racing.
FYI,Thanks.
Ooooooooh!
Exotek F1 Ultra
Tamiya TRF101
Tamiya TT02r
SpeedPassion LM1
TCdoesRC
texastc is offline   Reply With Quote
Old 08-26-2011, 10:34 PM   #604
LOSI123's Avatar
Trader Rating: 63 (100%+)
LOSI123 is offline   Reply With Quote
Old 08-27-2011, 12:25 AM   #605
Trader Rating: 44 (100%+)
FYI,Thanks.
I ordered some shiny bits for my zero s ordered monday and got em by tuesday TQ Racing does not mess around and the best part of the deal is you get free priority shipping with an order over $100 bux right now
T5M 7.5
22 3.0 7.5
SickWitiTRacing(Jayson)
NitroLuver is offline   Reply With Quote
Old 08-27-2011, 04:53 PM   #606
spring71's Avatar
Smile
Thanks for the compliments.
Yes, we are doing the same day shipping, orders before 3pm PST.
If you guys need any parts we don't have, please contact us tq@tqrcracing.com
Thanks.
TQ RC RACING
Online Shop
tq@tqrcracing.com
Old 08-31-2011, 07:26 AM   #607
LOSI123's Avatar
There seems to be 2 types of vertical motor mount available, do both need sanding of upper deck or graphite upper deck?
Also one of the vertical motor mount says version 2 and looks to have one less part, why? whats the best one to get?
And is the alum purple spur gear holder going to give me more spurs that will fit?
please help
Old 08-31-2011, 07:40 AM   #608
Pro10noob's Avatar
The VII is for the Sakura Zero without the S
Or if you have the narrow lipo chassis you can use that one.
The other is for the Sakura Zero-S with the stock chassis.
If you have the Zero(without the S) upper deck you don't need to sand anything.
Alu spur gear adaptor helps eliminate any wobble you get with the plastic spur gear holder and you don't strip thread as you do in the plastic one.
Also you don't have to widen the spur gear holes to make it fit.
regards Roy
please help
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 08-31-2011, 07:49 AM   #609
silvalis's Avatar
Trader Rating: 29 (100%+)
What is the biggest pinion gear you can fit in using the V2 vertical motor mount and stock 80t spur?
I tried putting a 35t pinion in with the stock plastic horizontal mount and it feels like it meshes way too tight... Plus I could only fit one screw in, not both.
silvalis is offline   Reply With Quote
Old 08-31-2011, 08:23 AM   #610
silvalis's Avatar
please help
I was looking at this myself.
It looks like the V2 mount (SAK66v2) for the regular Sakura only has the motormount/left side spur holder + top mount
The extra bit in the Sakura S mount (SAKS17) is the right side spur holder thingy.
Dont know what the diff between the actual motormount is...
Old 08-31-2011, 08:35 AM   #611
LOSI123's Avatar
Thanks heaps guys, also is the optional white 20t centre pulley needed if upgrading from the standard Zero S spur holder/pulley, as the alum spur holder doesnt have a pulley on it as with the stock S one does.
Is there anything else i will need to run the alum spur holder on the Sakura S Zero, shaft the same etc?
Old 08-31-2011, 09:26 AM   #612
Madulla's Avatar
Yes you need the pulleys. 20T is stock, 21 will tighten it up, 19 will loosen the belt a bit. Just remember that it will change the FDR for your calculations unless you use the stock 20T.
The spacers don't come in the Zero S. Not sure if other washer sizes would work. I am going to put them on today.
http://www.rcmart.com/catalog/rc-sak...=595_1419_1467
Pro10noob... Do you think its worth upgrading to the aluminum bulkheads on the ZeroS? Its the only hopup I have not done. Just not sure what it would help improve, other than looks.
Hobbywing North America Team Driver
hobbywingdirect.com
CARCAR VP carcar.ca
Madulla is offline   Reply With Quote
Old 08-31-2011, 09:46 AM   #613
Pro10noob's Avatar
Don't go for the 20 teeth.
Take the 19 teeth as this will give you a IDR of 2.
This is much easier if you need to run a precalculated FDR.
It will free up your drive train a lot when you use the alu gear adaptor with the 19 teeth pulley.
This results in a smoother running car and less drag on the drivetrain and motor.
regards Roy
l===/o\===l
Old 08-31-2011, 02:46 PM   #614
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
you can also use 37T pulleys from a 416/7 diff, or the sakura gear diff. i've found that both reductions are required to get the diffs back to the neutral position, so that the diff height adjustment is more pronounced.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 09-02-2011, 11:00 AM   #615
Stef71's Avatar
Hi, I've ordered a Sakura Zero S and a Ezrun combo with a 9t 4300kv motor. It's hard to get info about this kit in Europe, so I'm looking for your help. Can somebody tell me the FDR i should use with it. And by the way parts I should buy to make it run.
Thx
Stef71 is offline   Reply With Quote
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
