Old 07-29-2011, 10:52 PM   #586
cannon's Avatar
Trader Rating: 35 (100%+)
Most wil fit if you are using the optional spur gear mount plates (one with the screws)
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 07-29-2011, 11:05 PM   #587
texastc's Avatar
Originally Posted by VIP_SPEC View Post
I cant find a 80T spur anywhere! will anything other then the kit spur fit?
I use a 100 tooth 64 pitch, I would think any spur would work.
Exotek F1 Ultra
Exotek F1R
CRC Gen-X 10 LE
Kyosho Plazma F1
TC does RC
texastc is offline   Reply With Quote
Old 07-30-2011, 12:11 AM   #588
Pro10noob's Avatar
Xenon spurs will fit perfect
Kawada should fit also.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 07-30-2011, 09:28 AM   #589
Madulla's Avatar
I also use a 100 tooth 64 pitch spur and a 45 tooth pinion. Works fine, but i have the vertical motor mount. I am not sure I could tighten the motor down without it as the spur gear covers the screws.
On another note. I switched to use AE springs with the 4mm towers. What a difference. The car can turn!!! Back end is a little loose under power. Just need to setup the car better. Got the narrow rears coming, might stiffen up the front more. I just could never get the car to work with the 3racing springs. I am much happier with the car now. Best part is when I beat all the $400+ car guys it just tastes that much sweeter.
Hobbywing North America Team Driver
hobbywingdirect.com
CARCAR VP carcar.ca
Madulla is offline   Reply With Quote
Old 07-31-2011, 09:44 AM   #590
Can any one tell me what is the thickness of diff gear oil supplied in the diff gear set?
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 07-31-2011, 10:31 AM   #591
Pro10noob's Avatar
If i am not mistaken it is 2000.
regards Roy
l===/o\===l
Old 08-15-2011, 03:46 AM   #592
does 3racing sell the pink alum shock caps saperately? Thanks
cheapskate.brok is offline   Reply With Quote
Old 08-15-2011, 12:45 PM   #593
texastc's Avatar
Yes they do.
Exotek F1 Ultra
Exotek F1R
CRC Gen-X 10 LE
Kyosho Plazma F1
TC does RC
Old 08-15-2011, 05:32 PM   #594
Originally Posted by texastc View Post
Yes they do.
I tried to search for them them but they seem to only come with the sakura zero s kits and alum shocks. What i have in mind is to build the composite shocks for my Tamiya M05 where the shock caps are 1 piece, looks pretty brittle too. Prefer the two piece design.
Any leads? Thanks
Old 08-16-2011, 05:06 AM   #595
Thinking of getting a elect on road for fun to run a 17.5t with lipo.
Do i need to upgrade anything to run lipo?
what size lipos fits? would intellect 5000mah 40c fit?
what pinions are you guys running on 17.5? iv been reading you cant fit a pinion on 17.5 because the pinion will be too be for the motor mount
Also any recommended upgrades?
TEAM DURANGO CARBON DEX210 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
TEAM DURANGO CARBON DEX410 - POWERED BY TEKIN RS PRO/REEDY SONIC 17.5
TEAM ASSOCIATED B5 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
LiL_JaSoN is offline   Reply With Quote
Old 08-16-2011, 05:55 PM   #596
texastc's Avatar
You don't need to upgrade anything to run li-pos. Your 5000 should fit.
I'm running a 25.5 motor and I'm running a 47 tooth pinion. Don't know what you would need for 17.5 but I imagine smaller.
Is suggest buying the vertical motor mount. Makes motor install easier. That's it really. All I changed at first. I've slowly upgraded some of the plastic to aluminum parts. Rear bulkhead, front suspension mounts and the steering mechanism ao far. By the way, if you get the vertical motormount, you will have to switch the belts. Ling belt will go on right side and it will be in the way of battery mount. I nodded mine to fit so I could still use the mount, but you can still just tape battery in and should cause no trouble. It's a good car, and easy on the wallet.
Exotek F1 Ultra
Exotek F1R
CRC Gen-X 10 LE
Kyosho Plazma F1
TC does RC
Old 08-16-2011, 06:33 PM   #597
seems like i need the graphite top deck aswell if i switch to vertical motor mount.
Old 08-16-2011, 07:14 PM   #598
Madulla's Avatar
Not if you have a dremel or sandpaper. But the graphite does look good
hobbywingdirect.com
CARCAR VP carcar.ca
Old 08-18-2011, 06:36 PM   #599
Trader Rating: 44 (100%+)
Ok so I just got myself a 3 racing zero...for leisure as well as a little racing...I am rookie in on-road and will be running 17.5 no timing...what gearing should I go with?
I already ordered up a couple of spare parts(since I'm off road guy I may hit a thing or 2 lol)
T5M 7.5
22 3.0 7.5
SickWitiTRacing(Jayson)
NitroLuver is offline   Reply With Quote
Old 08-18-2011, 07:14 PM   #600
Madulla's Avatar
You want a FDR between 3.8 to 4.4 depending on your motor temps and track. I run 100/43 in my 17.5 TC no timing comes off at 145F. Depends on your motor and the motor timing you should come off at 140-160F.
But you will need the VERTICAL MOTOR MOUNT to be able to run a spur around 100 teeth to tighten the motor screws!!!
hobbywingdirect.com
CARCAR VP carcar.ca
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
