Old 05-15-2011, 05:44 AM   #436
Originally Posted by texastc View Post
I've read this thread front to back and I'm convince that I'm buying one. But I want to hear more on how it drives to convince me to buy it sooner rather than later. So let's hear it.
I've just finished my first big race weekend with the car. Im running 21.5 bl with no timing on the esc as per race rules with an orion pro stock motor geared with a 2.94fdr. I've updated quite a bit of parts being the following:
Narrow CF Lipo chassis
CF Top Deck (Soft)
Alum Bulkheads front and rear
Upgraded threaded Shocks (3racing Zero part)
Vertical motor mount
First off, iMO, the car handled really well. I finished 8th in the A-main up against a field predominantly made up of T3's. The car responds predictably to chassis adjustments which means to me that parts are relatively well machined and true. However when i did bin it i found that i needed to put it back on a set up board to get settings back into place more often than the Xrays. Aside from that i have no complaints. A lot of people on the track were pretty impressed at well at the level of the kit given its price.
Im not sure how it will respond running faster motors but for the class that im in at the moment it does just fine.
Mandirigma is offline   Reply With Quote
Old 05-15-2011, 05:50 AM   #437
Originally Posted by VIP_SPEC View Post
I just built the Kit,
What do you think of the kit springs?
any thoughts on going a little softer for silvercan?
The kit springs aren't bad...but saying that they arent that good either. It really depends what you are using them for. If its just for bashing around a track or parking lot it should do fine even for the silver can. If your thinking of racing a little the threaded shocks are heaps better so you can adjust your ride height more accurately.
Old 05-15-2011, 05:57 AM   #438
VIP_SPEC's Avatar
Was more referring to the spring rate rather then the dampers,
Thanks anyways
VIP_SPEC is offline   Reply With Quote
Old 05-15-2011, 06:13 AM   #439
Thanks anyways
The spring rate is 3racing 5.5turn spring so its middle of the road in terms of rate.
Old 05-15-2011, 12:59 PM   #440
Question for you guys--
How competitive is the Zero S versus better cars like the TC6, Xray, Tamiya, ect? The Zero S is almost 200g heavier than the other cars. Are there key upgrades that make the car better?
Thanks!
CTRJ is offline   Reply With Quote
Old 05-17-2011, 01:57 AM   #441
Default zero s
i built my kit with the 19 center pully. im going to run a 5.5 brushless motor and was wondering if anyone knows what pinion gear i should get?
jseiwert is offline   Reply With Quote
Old 05-17-2011, 02:03 AM   #442
Thanks!
Get the narrow chassis kit, alum shocks (you can fine tune your ride height), get the aluminium spur adaptor (you may need the carbon steel spur shaft and washer kit, and 19t/20t pulleys), get CVDs for the rear, get swaybar kits.
cheapskate.brok is offline   Reply With Quote
Old 05-17-2011, 08:25 AM   #443
Pro10noob's Avatar
Depends all on track lenght,if it tech or smooth,what esc your running.
You should start with a FDR of 7.5 and work your way from there.
Check the motor and esc temp every 5 minutes so you can find out if you need to gear down or up.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 05-17-2011, 11:50 AM   #444
texastc's Avatar
You guys that have raced with the zero S, are there any parts that you would recommend getting as spares. Like a arms or steering hubs? And os it true that xray parts work as replacements?
Exotek F1 Ultra Tamiya TRF101 Tamiya TT02r SpeedPassion LM1 and SP1 C main mainstay. Unless there is a D
TCdoesRC
texastc is offline   Reply With Quote
Old 05-17-2011, 12:08 PM   #445
Pro10noob's Avatar
You can use some Xray parts as mentioned before but only when you have them lying around.
When buying spares, Xray parts are more expensive then the original Sakura parts so i wouldn't buy them.
regards Roy
l===/o\===l
Old 05-18-2011, 08:25 AM   #446
Firefox's Avatar
Anyone in the US stock the Sakura Zero S and parts ?
Tamiya M05, Associated SC10.
Firefox is offline   Reply With Quote
Old 05-18-2011, 08:46 AM   #447
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
http://www.tqrcracing.com/
http://store.hkshobby.com/
i can't speak to the stock status at either place, but both are located on the west coast. i've ordered from both as well. the only complaint that i have/had was that hks had no way of alerting me that half of my order was backordered. so, i lost the short week in waiting for delivery before realizing that it was missing some quantities. not earth shattering.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 05-18-2011, 09:17 AM   #448
Hi, i read all thread and didnt find a answer...
I am interresting in buying this car to run on a out door asphalt track, using a 4.5 BL + Tekin RS pro with foam tyres.
I was wondering if the transmission especialy the gear diff. could handle such config? Anyone have tried anything similar?
CoCoLapin is offline   Reply With Quote
Old 05-18-2011, 11:05 AM   #449
over gear's Avatar
Trader Rating: 15 (100%+)
i ran a Tekin RS + 8.5t in a tight indoor high grip track... no problem.
over gear is offline   Reply With Quote
Old 05-20-2011, 12:26 AM   #450
over gear's Avatar
update of my Sakura S.
Thank you HKS Hobby for the parts support
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
