Old 04-25-2011, 09:01 AM   #391
JimmyMac's Avatar
Found it... This is what I'm talking about... You would have to change the axles too. Not unless if XRay has changed since the 09 version. I haven't raced since 09. Just getting back into the hobby.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 04-25-2011, 01:52 PM   #392
My resurgence in RC came when I found my old HPI RS4 Pro3 in the closet. I replaced the NiCad with a NiMH and couldn't make it fit and then proceeded to hose the whole thing trying to make it work. I bought a few used cars/rollers figuring I could piece something together and that has mostly failed due to my lack of knowledge and limited parts availability. I'm thinking the Sakura Zero S might give me the on-road bashing platform I am looking for without having to spend another $400 or buy another Tamiya.
In my efforts I bought a Castle Sv2 4600kV combo and 2S LiPos. Will I be able to drop that in along with a spare SR300 and one of the servos from my trollers and go or will I need anything else to make it go?
I read through the first dozen pages this morning and saw something about a LiPo chassis replacement? Do I need that? Is the vertical motor mount still a requirement along with a different top deck?
This seems like the perfect basher platform. I need something to put the Sv2 in!
coopasonic is offline   Reply With Quote
Old 04-25-2011, 02:12 PM   #393
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
Welcome back Jimmy! If you are not removing too much material, drill the outdrives to fit the XRAY bones. It's what I presently do to use them.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 04-25-2011, 04:00 PM   #394
is this car/parts sold in canada?
hotrod306 is offline   Reply With Quote
Old 04-25-2011, 05:47 PM   #395
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Originally Posted by seaball View Post
you should be fine. worst case, you can pull the gasket out, and use a 25x27mm o-ring in place, which will narrow the unit by almost 2mm. i'm getting right around 20mm between the inside bearing faces in stock form.
Where were you a few weeks ago? I was hoping to pit next to you all weekend
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 04-26-2011, 12:20 AM   #396
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Thanks guys. At least I can check the width...
Old 04-26-2011, 09:21 AM   #397
Madulla's Avatar
This seems like the perfect basher platform. I need something to put the Sv2 in![/QUOTE]
If you are just bashing then you don't need the Lipo Chassis, Vertical Motor Mount or Top Deck. They are good to use if you are trying to setup up your car for racing. Chassis for handling. Vertical Motor mount for changing gear ratios easier and the top deck to fit the motor mount.
Hobbywing North America Team Driver
hobbywingdirect.com
Madulla is online now   Reply With Quote
Old 04-26-2011, 10:51 AM   #398
Awesome, thanks for the response. Once I unload all the stuff I bought that was wrong, I think I'll head in this direction.
Old 04-28-2011, 11:54 AM   #399
Hua
Default Help needed
Hi guys, i'm thinking of getting a sakura S online because it doesnt sell in my LHS, so mostly will be getting it online...
1 question that i need to verify is, can TRf 416 front and rear belt able to fit sakura? i been searching in the web but cant find the answer...will appreciate if someone can help me out on this...thanks
Hua is offline   Reply With Quote
Old 04-30-2011, 06:56 AM   #400
Default upgraded front and rear shock towers
Im upgraded the front and rear shock towers to the graphite items that are 4mm higher i think...(sak35/4wo and sak36/4wo)
Has anyone else done this upgrade and noticed a considerable rise in their droop settings? On a hudy droop gauge i went from a 4 to a 7 front and rear. Im not sure if this is better or worse...
Mandirigma is offline   Reply With Quote
Old 04-30-2011, 07:14 AM   #401
Pro10noob's Avatar
Because of the other shock towers you get other droop settings as the tower is 4mm higher then the stock item.
I don't use them any more as i now use shorter springs so the car could get low enough.
Mind you mine is a Sakura Zero without the S but the priciple is the same.
I use TM springs and have plenty of room to play around with the ride hight and so on.
regards roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 04-30-2011, 05:06 PM   #402
regards roy
Yeah I figured as much because the towers are 4mm higher they sort of pull the arms higher up.
What are the advantages or disadvantages of having such a high droop setting? I have no issues with ride height but with these shock towers I cant adjust the droop settings to go lower than 7.
Old 04-30-2011, 10:55 PM   #403
Pro10noob's Avatar
Well it will get to the point that you can't adjust the car settings to your likings.
When riding with foam it is a different story
Don't get rid of the stock shock towers and use these with shorter springs.
It will let you get the right dropp settings jou want.
regards Roy
l===/o\===l
Old 04-30-2011, 11:42 PM   #404
Is the only difference between the HD 3Racing Gear diff and the std gear diff the material the outdrives are made of?
It looks like the Zero S comes with the HD gear diff, right?
Has any one else noticed runout or a wobble in their gear diff when installed in the car? Mine is enough to move the bearing/bearing holder in and out as the drive train spins. I am curious if the screws are perhaps not tightened evenly on the gear diff causing this or maybe the mold for the gear diff case is wonky like the plastic spur gear plates are...
Old 05-01-2011, 06:13 AM   #405
regards Roy
i went back to the original shock towers and droop settings and ride height were back to where i wanted them. I was lucky enough to meet the guy who sells the kits in oz down at the track today and explained to me that if i want to use the 4mm shock towers i should get a shock with a longer body and shaft (ie trf416 shocks)
just think its a bit weird that they sell 4mm shock towers and their own upgraded threaded shocks dont really work with them. Oh well...
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
