Old 03-28-2011, 10:02 PM   #376
Originally Posted by Mandirigma View Post
Hi All. Ive been lurking on this thread for a couple of weeks and will all the praise ive been reading on this site, ive gone ahead and taken the plunge and purchased a Sakura Zero S.
Thankfully there is a shop that carries it locally in my country and i got the item in two days. I am now three days into the build (I am taking my time doing two or three pages at a time every night) and am near completion. As everyone has already expressed I do agree that for the price that you pay for this kit, I am very impressed with the quality and fit of components. Granted its not as polished as the more expensive cars however you cant compare the two as they are more like apples and oranges. If someone wants an orange, you cant expect them to be satisfied if they get an apple.
I want to get back into RC racing after a 11 year hiatus so naturally im going to start in a novice class where 540motors are the control motors. Given the stock gearing what pinion should i be aiming for to get the perfect FDR? Also, what recommendations do people have for ESC's and batteries for the 540 motor?
Budget racing will be the course of the day for me so i will run the car as close to stock and really just start upgrading parts when i feel ive gotten the most i can out of the stock set up.
With the stock 80T spur I would try pinions from 27-32T-have a look on the 3 racing web site at the sakura zero page, they have a pdf gear ratio chart you can download.
jetski is offline   Reply With Quote
Old 03-29-2011, 04:53 PM   #377
Thanks for that. I will check it out.
Mandirigma is offline   Reply With Quote
Old 03-31-2011, 02:25 PM   #378
Thanks Madulla. Have ordered them.
also just recieved a fair few hop ups.
Front and rear aluminium bulk heads.
Vertical motor mount
Front and rear bulkhead covers
all front and rear suspension mounts
stiffer springs
Damn it....i got into this hobby so i would stop spending so much money on my 1:1 S14a........this is proving to be a fail!!!!
greens14 is offline   Reply With Quote
Old 03-31-2011, 05:35 PM   #379
Madulla's Avatar
Thats great...
I think the aluminum is just for the bling factor. I have thought of getting the bulkheads but put the money in the aluminum shock kit, narrow graphite lipo chassis, graphite upper deck and aluminum steering. Just wish there were more setups out there running 17.5 carpet so it wouldn't take me a whole season to set it up hehe.
Hobbywing North America Team Driver
hobbywingdirect.com
CARCAR VP carcar.ca
Madulla is offline   Reply With Quote
Old 04-03-2011, 09:30 PM   #380
Can someone give me the part# for the top deck you need that goes with the verticakl motor mount?
Bought the motor mount but didnt realise you needed a different top plate.
Old 04-03-2011, 10:48 PM   #381
Check out a site called gigspeed. unfortunately i cant post urls yet because i havent has enough posts. (www gigspeed com au)
They are based out of Melbourne. :-)
Shame they dont stock the parts for it too.
www.feralbatteries.com.au also stock sakura stuff, certainly has parts on his site. He has a thread under Australian Racing if you want to ask questions. Nice guy !
Steve
bigtree is offline   Reply With Quote
Old 04-05-2011, 06:54 PM   #382
Just if anyones interested, ive been playing around with my zero outdoors asphalt with foams(we race them down here) and its really goes well.
Heres my basic setup without getting to indepth..
35 shore front and rear. 30mm rears, 26mm fronts.
13.5 boosted btw.
Rear of car.
Hardest sway bar.(1.5mm I think)
0.5 degree camber
6mm hexes
14 pound spring.
40 weight 3 hole
6mm ride approx
front
1.3mm sway bar
1 degree camber
5mm hexes
17 pound spring
50 weight 3 hole
5.5 ride height
1 degree toe out
The key to foams on a electric tourer on the asphalt seems to be slightly harder springs and slightly lightly damped compared to a rubber setup.
And the hard rear sway bar helps to get the rear to rotate more freely as with 30mm tyres you have a big contact patch.
Eat more possum!
Lees52 is offline   Reply With Quote
Old 04-05-2011, 08:13 PM   #383
ian scott's Avatar
Trader Rating: 14 (100%+)
Default sakura zero
Hello have bought the sakura zero s kit Its the cheaper set with the normal gear diffs.Apart from the installing the motor and pulling have the car apart to replace the pinion its sits on the road good and easy to drive.My question is i am looking for some spur gear 78 76 tooth gears.Does any one have a website i can go to thanks
ian scott is offline   Reply With Quote
Old 04-06-2011, 07:20 AM   #384
spring71's Avatar
Smile
We have Sakura parts online. Also has spur gears.
Plese visit www.tqrcracing.com for more information.
Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
http://www.tqrcracing.com
tq@tqrcracing.com
spring71 is offline   Reply With Quote
Old 04-06-2011, 08:30 PM   #385
You want part SAK-S16WO-it is the carbon fibre upper deck
Old 04-10-2011, 08:20 PM   #386
Steve
If you are down under and looking for sakura s parts i found another website that has a more comprehensive list. Search for top gun rc hobbies on google.
they are based in NSW and can do special orders as well from the 3racing from HK as i think they are the official distributor of 3racing stuff in oz.
Old 04-16-2011, 08:14 AM   #387
Trader Rating: 19 (100%+)
How are these going so far?
Thinking about picking one up for something to thrash on the local track and drift a bit.
Is it possible to overdrive the rear in these?
Anything considered a must have out of the box (upgrades or whatever?)?
How much power can they handle?
Are the gear diffs any good?
Shimmy is offline   Reply With Quote
Old 04-25-2011, 03:13 AM   #388
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Can anyone tell me if the Sakura s gear diffs will fit in a T2 or T3 Xray? Or if not, could you measure the distance between the bulkheads or how wide the gear diffs are at the point where the bearings contact the outdrives on the inside? Thanks. I noticed they were 38 tooth and got hopeful...
Old 04-25-2011, 05:50 AM   #389
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
you should be fine. worst case, you can pull the gasket out, and use a 25x27mm o-ring in place, which will narrow the unit by almost 2mm. i'm getting right around 20mm between the inside bearing faces in stock form.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 04-25-2011, 08:57 AM   #390
JimmyMac's Avatar
Question though, I'm not totally sure, but how is the ball end of the XRay vs. 3Racing/Tamiya/Yokomo ball ends on their bones? I thought they might be bigger. Therefore the axles would not fit into the outdrives.? I'll have to search through my pics to see if I measured the bones...
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
