Old 11-10-2015, 11:42 AM   #3391
Ist it worth double the price?
man1ac is offline   Reply With Quote
Old 11-10-2015, 11:51 AM   #3392
(0000000000)'s Avatar
Check out rcmart.
The Xi Sport is actually lower in cost than the Zero S.
My Original USER ID was 0000000000. But now it doesn't seem to work.
(0000000000) is offline   Reply With Quote
Old 11-10-2015, 12:47 PM   #3393
DirkW's Avatar
Cheaper than the Zero at rcmart, but not cheaper as the "TD 10" at Hobbyking. But still amazing value for a better car.
Dirk
Current cars: Yokomo BD7'16 | Yokomo BD7'15 | Yokomo YRX-12 | Xray X10 '16 | Yokomo YZ-2 DT | Yokomo B-Max4 III Factory | Kyosho Ultima SC6 | Tekno SCT410.3
Future cars (soon): Xray T4'17(8) | Xray X1'17(8) | Yokomo YZ-2 CA(DTM?) | VIP-Performance Vorlon/VTE
DirkW is offline   Reply With Quote
Old 11-10-2015, 12:48 PM   #3394
Yup.
Nothing is cheaper than hobbyking.
Old 11-10-2015, 12:50 PM   #3395
Here in Germany the Sport XI is about 130 bucks and the stuff via Hobbyking would be 80 without shipping...
Old 11-20-2015, 01:16 PM   #3396
Trader Rating: 21 (100%+)
I'm not sure if it's been mentioned here yet, but I just found out that the bulkhead covers for the Zero do not fit the bulkheads for the XI.
I ordered a set of aluminum bulkheads (front and rear) to upgrade my Zero. I was able to mount them to the chassis (one of the bolts on each bulkhead piece will not line up properly with the chassis, but the chassis can be drilled). But then I went to put the plastic Zero bulkhead covers back on and the holes do not line up.
And now everyone seems to be out of stock on XI aluminum bulkhead covers....I suppose I could order some plastic XI bulkhead covers though.
Still a bummer.
xjwolfpacker is offline   Reply With Quote
Old 12-21-2015, 05:02 AM   #3397
Ordered some XI bulkhead covers and modified the Zero top plate to fit.
Now my problem is that the belts are a bit too tight. I'm using the stock Zero S (522/174T?) belt. Does anyone know of any belts that are slightly longer that I can use instead? Need probably 178-180T, but anything longer than 174 would be fine.
Old 01-02-2016, 05:03 PM   #3398
I just decided to get the vertical motor mount (SAK-S17) and the upper deck (SAK-S16) required for the upgrade. What did you guys do with the battery stay/stop? I flipped the diffs and the front drive's belt can't get through because of them.
https://www.dropbox.com/s/w0aaewakt6...102_200816.jpg
Seanzky is offline   Reply With Quote
Old 01-02-2016, 06:29 PM   #3399
You have to modify /cut /dermal the battery stop. If you look back, somewhere Stevem has a post about it. Don't forget to add some more battery stops along that side. Most ppl just use a servo mount cut up with a fat screw head to stop the battery from moving into the belts
TeamThibault is offline   Reply With Quote
Old 01-02-2016, 07:39 PM   #3400
Thanks! I did read up on those and I got the jist of it. It's just that some of the old pictures were taken down and I didn't have a visual reference. Anyway, I jumped on it and ended up with this:
https://www.dropbox.com/s/ggzdhz10bd...102_223648.jpg
https://www.dropbox.com/s/qe2u6dwrcw...102_223710.jpg
https://www.dropbox.com/s/8rm7ayspmq...102_223731.jpg
I hope that tiny thing I ended up with in the center is enough to stop the battery from spilling over to where the belt is.
Old 02-25-2016, 09:08 PM   #3401
poeee's Avatar
Just paid under US$35 each (bought two kits) from hobbyking for their TD10's! Was from the Australian warehouse, and not sure if the sale is worldwide.
Scott Pocock | Geelong Radio Control Car Club www.grccc.org.au
poeee is offline   Reply With Quote
Old 10-02-2016, 06:57 PM   #3402
Well with my cf sakura zero s I finally did a new pb of 24 laps and miss the amain by 4 seconds. Was in second place then broke front spool on main.
Still a great day of racing
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
