Old 05-28-2015, 04:00 AM   #3346
Hi all
new to forum and newer to RC touring cars anyhow I've just purchased a TD10 and a Trackstar 10.5 (3250kv) to fool around with. Have also purchased the 19t center pully as is recommended by a lot of people online.
My guestion is what would a suitable pinion be for the kits stock gearing apart from the 19t pully with the 10.5 motor?
I was thinking a 28 or 29 pinion?
icair is offline   Reply With Quote
Old 05-28-2015, 07:35 AM   #3347
(0000000000)'s Avatar
That is fine. It will bring your car down to about a 5.5 FDR, if using the 29 pinion and 19t pulley with stock spur gear (80t).
If you were racing, I'd recommend you get to a 4.5 fdr. But 5.5 will ensure that nothing fails.
My Original USER ID was 0000000000. But now it doesn't seem to work.
(0000000000) is offline   Reply With Quote
Old 05-28-2015, 02:39 PM   #3348
Thanks!
Old 06-11-2015, 12:05 AM   #3349
just bought the sakura zero s kit. I have not built it yet. I've been going through the pages for a few days now.
it sounds like that a stock spur and 38t pinion will give me close to 4.0 fdr but will a 38t pinion fit without any problems? I have a 17.5 motor.
thanks
legacygt777 is offline   Reply With Quote
Old 06-11-2015, 12:08 AM   #3350
also, do i need to buy a 19t center pully? thanks
Old 06-11-2015, 08:20 AM   #3351
Yes, a 19t pulley is recommended. The stock pulley on the Xi is a much cheaper option than going with the aluminum pulleys. Without the smaller pulley, you will find that the front drive belt iis very tight.
The vertical motor mount will alllow you to easily change gearing. You may also want to get a smaller spur gear, so that you don't have to buy a 38t 48p pinion (which is very large).
Old 06-11-2015, 01:02 PM   #3352
part of the reason why I bought the kit was it's cheap. can the car still run with a tight belt? I mean as time goes on, a tight belt gets looser. can I just stretch the belt? I'm a newbie with this car.
it says on another website if I buy the vertical mount that I need a graphite piece on top.
so will the 38t pinion fit? appreciate the help.
Old 06-23-2015, 12:47 PM   #3353
anyone have advice to keep this car going straight? I've tried a lot of things already and even bought a new servo.
Old 06-23-2015, 04:46 PM   #3354
Assuming that you mean the steering won't stay centered:
Step 1- Make sure that the steering is free by disconnecting the link to the servo.
Step 2- Most people replace the kit servo saver with an aftermarket one. The problem with the kit one is actually that the "cap" that holds it all together is slightly too short, so that when you tighten the screw it pinches all the parts together. Then if you bump a wall, the output part of the servo saver moves a little and doesn't spring back to center. A simple fix to this is to put the screw through the "cap", then put a 0.020" thick motor shim on the screw between the cap and the rest of the servo saver. This removes the "pinch" and allows the servo saver's springs to work properly.
Kevin Marcy is offline   Reply With Quote
Old 06-23-2015, 10:10 PM   #3355
thank you kevin. I appreciate your reply. I made sure step 1 was checked. I have a feeling it might be the servo saver.
Old 06-24-2015, 07:43 AM   #3356
Give yourself some front toe-out also. This will straighten out the car.
Old 06-24-2015, 08:19 AM   #3357
I thought front-out will give more car turning and less car straight? I need more stabilization of straight line driving.
Old 06-28-2015, 11:27 PM   #3358
just wondering if anyone has changed all the main parts to graphite (shock tower, main chassis, etc)? if so, was the performance better because it was lighter?
Old 06-28-2015, 11:33 PM   #3359
buy a new servo saver
stock one is crap...nothing but problems
TeamThibault is offline   Reply With Quote
Old 06-29-2015, 09:11 AM   #3360
I have few of these chassis and I'm more less a new driver and don't really notice the difference. But have fun finding cf chassis
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
