Old 08-28-2014, 04:18 PM   #3316
anythinggas's Avatar
does anybody know the measurement between the inner front left and right bulkheads
Kevin Lehmer
www.debbiesrcworld.com
I would like to thank my sponsor...My VISA!
anythinggas is offline   Reply With Quote
Old 08-28-2014, 09:22 PM   #3317
inside 23 mm from inside to inside bulk head
anythingas thought you where selling your zero?
TeamThibault is offline   Reply With Quote
Old 09-22-2014, 04:55 PM   #3318
does any one know what is the part # to hex screws for the dif?
and what is the smallest 48p spur you can use (for 17.5)
Old 09-23-2014, 10:27 AM   #3319
(0000000000)'s Avatar
Rod, YGPM.
See you this weekend
My Original USER ID was 0000000000. But now it doesn't seem to work.
(0000000000) is offline   Reply With Quote
Old 12-20-2014, 07:48 PM   #3320
hi everyone,
new question, I am running a sakura on a 32mm rear foam tyre, the wheel rub the shock mount, anyway i can change either the offset of rim or add a couple of mm on the hub hex.
now it is 5mm stock one, where to get bigger ones.
thx
modelerbj is offline   Reply With Quote
Old 12-20-2014, 08:26 PM   #3321
azeroth's Avatar
Trader Rating: 20 (100%+)
3 racing has 6mm
Nitro is for Racing!!!!!!!!!!!!!!!!!!!!!!!!!
YA SMELL WATTs I BE STEPPIN IN????
Yes I race a Snake, VP, Radiopost,Protek,EDS,Matrix
Team Nitro RC Club Lynwood, IL
azeroth is offline   Reply With Quote
Old 12-20-2014, 10:13 PM   #3322
Trader Rating: 40 (100%+)
I saw on TQ 7mm Hexes Might help
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 12-20-2014, 10:14 PM   #3323
http://www.tqrcracing.com/shop/produ....asp?p_id=1394
Jason Deadman
Old 01-04-2015, 05:35 PM   #3324
ok guys im looking for some help
can some one please give me some tips on installing sway bars
are the bars not to move side to side
if you lift one side the other side should move up?
thanks
Old 01-04-2015, 08:28 PM   #3325
azeroth's Avatar
thanks
unforetunaly they will move side to side alttle unless you get the 2 collars from a ultimate or 2 collars and slit them yourself to control them and yes with shocks off and set screws adjusted correctly (free rotation but not movement) lift oneside other should move depending on how firm the bar is softest bar you may get it raise aways before other side moves i would howevr reccomend either the ulimate link arangement or using a short turn buckle in the link instead of the set screw to make it easier to tweek the swaybar
Old 01-14-2015, 05:10 PM   #3326
Hello everyone. What is the difference between a zero s and a xi sport?
jason w is offline   Reply With Quote
Old 01-14-2015, 08:52 PM   #3327
the zeros chassis is a little wider and the metal parts are harder to get
and im sure the zero s is going to be discontinue soon
Old 01-18-2015, 07:15 PM   #3328
can some one tell me the difference be between x02 arms and 25h arms are they the same size?
by the way sakura zeros s ppl I had a great day & finally! did my personal best of 23 laps and took second in b main missed first place by half lap.
Old 01-21-2015, 09:48 AM   #3329
Great work Rod! Keep up the good work.
I believe the 25H is graphite. It's a bit lighter, a little bit harder, but a little bit more fragile too.
Chuck
Old 02-04-2015, 06:19 PM   #3330
Do you change stock roll center on zero s? add more to the front and file down the rear?
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
