Old 03-20-2014, 05:49 PM   #3271
Nego's Avatar
Trader Rating: 70 (100%+)
Originally Posted by SteveM View Post
Biggest downside is you lose front brakes, and when you do brake you can spin out. Upside is the car turns in on long sweepers much better. Not mant racers using a one-way anymore and most have gone to a spool or a gear diff with heavy diff fluid.
Tks Steven! What diff oil should i start with front and rear?
Project X 1/10 pancar,17.5GT,1/12 BMI Copper head.
Nego is offline   Reply With Quote
Old 03-20-2014, 06:02 PM   #3272
SteveM's Avatar
Trader Rating: 127 (100%+)
I run a spool in front and 2000wt in the rear. If you run a gear diff in front, you might try 300,000wt or higher to make it almost spool-like.
SteveM is offline   Reply With Quote
Old 03-20-2014, 07:06 PM   #3273
Nego's Avatar
Where can i get s front spool from?
Old 03-21-2014, 04:18 AM   #3274
SteveM's Avatar
3Racing sell the parts needed so you will need to buy several items. For some reason they do not sell a complete spool.
If you want a front spool, you need to purchase three separate items to assemble one.
  • SAK-02 - 38T white pulley
  • SAK-09 - Solid Axle Outer Joint (2)
  • SAK-08/PK - Front Solid Axle
Old 03-21-2014, 09:08 AM   #3275
hey stevem are you running sakura's again?
TeamThibault is offline   Reply With Quote
Old 03-21-2014, 09:10 AM   #3276
Nego's Avatar
got it thanks for the help Steve!
i got the 08,09 for TQracing still looking for thr 38T pulley.
Old 03-21-2014, 09:35 AM   #3277
SteveM's Avatar
No, I no longer have a Sakura sedan. I currently run a Schumacher Mi5, Spec-R R1, and a Tamiya TB-03.
Old 03-28-2014, 04:30 PM   #3278
Looks like part SAK-44 is discontinued. Can I use SAK-U105 instead?
DeltaRay is offline   Reply With Quote
Old 03-28-2014, 04:41 PM   #3279
Does anyone if X-ray body mounts work on the zero the front bumper ones
strrick is offline   Reply With Quote
Old 03-29-2014, 12:24 AM   #3280
(0000000000)'s Avatar
Yes they do. The rear ones will also work, though you need spacers if you want to mount the same rear body holes.
My Original USER ID was 0000000000. But now it doesn't seem to work.
(0000000000) is offline   Reply With Quote
Old 03-29-2014, 12:27 AM   #3281
Yes. I use the ultimate knuckles on the zero. They are a direct replacement. The c-hubs and arms also work. If you use ultimate/xi arms, you will need to change how the front swaybar is mounted (very easy).
Old 03-29-2014, 01:29 AM   #3282
ta04evah's Avatar
Ah thanks for that, I had also heard that xray & arc knuckles fitted on the zero.
What exactly needs to be changed for the swaybar if the ultimate/xi arms are fitted?
Cheers
Rob.
BSR BT-4 / Turnigy / Hobbywing / Savox / Trackstar
Castle Hill Raceway Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 03-29-2014, 09:04 AM   #3283
I have the basic Zero kit modified to accept the vertical motor mount. The new lipo battery I just bought will not fit under the upperdeck. Does Sakura make a battery mount system that will allow the battery to be mounted further away from the center line, or will I have to fashion something myself to solve the problem. Shimming the upperdeck is not a possibility due to interference with the vertical motor mount.
calvin is offline   Reply With Quote
Old 03-29-2014, 11:55 PM   #3284
Cheers
Rob.
Whereas the Zero arms have a ball that connects to the ballcup link of the swaybar, the Ultimate/Xi arms have a hole that connects to the ball end link of the swaybar.
Easy fix is to replace one ballcup of the swaybar with a ball end. So instead of having a connecting piece that is a pair of connected ballcups, it will be ballcup on the end connected to swaybar and ball end on the other end connected to arm.
Old 03-30-2014, 12:02 AM   #3285
You'll have to cut/trim the existing battery mount. I will try and post a photo tomorrow.
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 05:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 10:21 AM
