Old 11-08-2013, 04:07 AM   #3196
Default I'm sorry about the terms I use still learning touring cars
Originally Posted by Texas Postman View Post
I'm curious, about what you mean..."tighten up the front." Shocks-up...down...tighten-up the spring tension...stiffer spring rates?????
Sorry about the term still learning touring cars but stiffer springs up front and the softest in the rear, I was using the 3racing 6.0 which are their softest in the spring kit they have and 5.5 in front but went to 4.75 in front. Changing spring rates is the fastest way to see what your car is doing on the track, that or moving the placement of your shock position. I raced recently on carpet and had my rear shock position 2 holes from the bottom and she started to really feel planted then also moved the fronts almost straight up and it got way better but I will say this that I had sway bars on and they were set at a medium position and stiff up front and soft in the rear.
Believe it or not, I ran asphalt last weekend and it worked on our track and felt better than every thing else I've tried. I'm really new to touring and it's waaay different than 1/12 scale pan and 1/8 nitro so touring really has me going in a mad scientist kinda way to find the right comb to work.
Hope this helps in any way.
Ol skool
Ol skool nitro is offline   Reply With Quote
Old 11-11-2013, 05:28 AM   #3197
I just purchased one of these cars, its actually a Turnigy (same car). I will be running a 17.5 motor and I am looking for a good place to start for a pinion gear. I will be using the stock 80 tooth spur and its 48 pitch.
csilve is offline   Reply With Quote
Old 11-11-2013, 12:00 PM   #3198
I just built the XI sport which purportedly has the same internal ratio, though I've seen it quoted as 1.9 and 2.0. I was shooting for a 4.0 FDR, which I achieved through using 71T and 35T gears. I was told I wouldn't be able to fit a 80/40 combo. I would grab a lower geared Spur.
http://www.arroyoc.com/index.cfm
simonseize is offline   Reply With Quote
Old 11-14-2013, 08:26 AM   #3199
brothainchrist0's Avatar
Trader Rating: 145 (100%+)
Hey guys, I have a bunch of parts for this car for sale. I replaced everythign on my car with aluminum and carbon fiber so I have all the stock parts for sale and a few aluminum extra parts I didnt mean to order. Let me know if you are interested.
Thanks!
Kyle
210-722-6891
Uploaded with ImageShack.us
Mugen MRX5 - Ielasi Modified Engines/Matrix Tires/Savox Servos/Airtronics Radio
IGT Hobbies - The one stop shop for anything on-road and incredible customer service.
brothainchrist0 is offline   Reply With Quote
Old 12-05-2013, 05:01 PM   #3200
Wow. I just found out that TQ racing had spurs gears as low as 65T in 48 pitch. now i can drop down to 3.611 using a 36T pinion. that is the biggest i can get in without rubbing. order made.
TT
ttsquirrel is offline   Reply With Quote
Old 12-09-2013, 06:24 AM   #3201
Default Steering knuckles
Apparently these are discontinued. I have heard Xray parts will fit. Does anyone know which ones will fit?
Old 12-09-2013, 09:29 AM   #3202
I just checked tq website...everything is still in stock...my 65t spur should be delivered today
Old 12-09-2013, 10:59 AM   #3203
Anyone know where to get the kit tires? They should be cheap and are decent on pavement for practice.
Old 12-09-2013, 01:59 PM   #3204
what is the tq website?
Old 12-09-2013, 03:21 PM   #3205
Tqrcracing.com
Old 12-09-2013, 07:00 PM   #3206
moparSRT's Avatar
TT
robinson has 48p spurs down to 49T
49 52 55 60 66 70 ...
moparSRT is offline   Reply With Quote
Old 12-09-2013, 07:51 PM   #3207
Holy crap!!.. I would have ordered from rrp...and I can't believe they are just up the road from me..I would have kept it more local...thanks for the info
Old 12-13-2013, 09:49 AM   #3208
azeroth's Avatar
Trader Rating: 20 (100%+)
how many of you guys have seen broken plastic bulkheads i have broke 2 already this year gonna change to the alloy
Nitro is for Racing!!!!!!!!!!!!!!!!!!!!!!!!!
YA SMELL WATTs I BE STEPPIN IN????
Yes I race a Snake, VP, Radiopost,Protek,EDS,Matrix
Team Nitro RC Club Lynwood, IL
azeroth is offline   Reply With Quote
Old 12-16-2013, 01:58 AM   #3209
Here is mine in Brazil.
Just playing with an ofna dm1.
+ YouTube Video
Sakura is 2S with 7.5t trackstar sensored motor. Original spur and 30t pinion.
sdrubow is offline   Reply With Quote
Old 12-21-2013, 12:20 PM   #3210
I purchased the 3 racing front one way to try on my xiS and installed, but the out drive cups appear too short and they move in and out of the one way bearings about 1/2 an inch. This can't be normal. Do I need longer cvds?
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
