Old 10-22-2013, 05:21 AM   #3181
Trader Rating: 40 (100%+)
Vta have strict rules on tires. check with your local track for the specific rules. Here we follow the usvta rules
http://www.usvintagetransam.com/
I don't run a servo saver for the sakura
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 10-22-2013, 02:13 PM   #3182
Originally Posted by TeamThibault View Post
so i never made it out to racing this weekend but i did get some time to work on my chassis. i took out the servo saver and used a solar 770 servo with out a saver and we will see how that works untill my xray saver gets in.
what tires do you guys recommend for vta?
thanks
I run mine without a servo saver and never had a issue with it. But now my 10 year olds using it I might go back to one.
Yogi- is offline   Reply With Quote
Old 10-22-2013, 04:12 PM   #3183
Just get the Xray hard bumper and never worry again
Jason Deadman
Old 11-03-2013, 12:26 PM   #3184
GP40X's Avatar
I have a Sakura Zero version 2 Vertical mount and a pair of 96 tooth sour gears for sale.
Sakura Zero S Turnigy TD10 parts
With the vertical mount you can go as high a a 51 tooth pinion with the 96 tooth spur gear.
Bill
"I used to be disgusted, now I'm just amused."
Team Qik
CustomWorks Outlaw Sprint Car
Xray T3 2012 USVTA
GP40X is offline   Reply With Quote
Old 11-03-2013, 04:22 PM   #3185
well this weekend was a lot better. i took out the servo saver and a lot of my problems where gone. now i can focuse on traction or the lac of
I guess my tires are very dirty and loss of grip.
TeamThibault is offline   Reply With Quote
Old 11-03-2013, 05:13 PM   #3186
ta04evah's Avatar
What type of surface do you race on? carpet or asphalt? and what type of tires do you use? foam or rubber and what brand/compound?
Cheers
Rob.
BSR BT-4 / Turnigy / Hobbywing / Savox / Trackstar
Castle Hill Raceway Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 11-04-2013, 04:16 PM   #3187
I race on carpet in older curling rink Track size is 48 x 70
3racing m03 springs soft in rear med in front
40 w in f&r
3 mm droop f&b
5mm ride height
jaco blue rubber
Old 11-04-2013, 06:08 PM   #3188
Been searching for a while. Looking for a good pinion/spur matchup w/ a 17.5T motor on a sakura XI Sport. There aren't many folk over there, so thought I'd ask here. Internal Gear ratio is 2.0, looks like the Zero S is 1.9 by some accounts and 2.0 by others. Will be running carpet, but not racing, just going on practice nights, unless my schedule changes. Don't know track layout as it's a new track. Also, can't really ask anyone there because it doesn't exits. Just want to order a different spur with the car if necessary...
Thanks in advance.
Cullen
simonseize is offline   Reply With Quote
Old 11-05-2013, 08:42 AM   #3189
Trader Rating: 91 (100%+)
Thanks in advance.
Cullen
The XI Sport is 2.0 internal gear ratio. For 17.5 you should be in the low 4's FDR. Do you run 48p gears or 64p?
Life moves pretty fast. If you don't stop and look around once in a while, you could miss it. -- F. Bueller
eddiemoney13 is offline   Reply With Quote
Old 11-05-2013, 09:11 AM   #3190
Just ordered the kit, so this is all theoretical. But FDR should be 4.0 for 17.5? I was thinking between 3-4 for 21.5T and more like 6.0 for 17.5T? I'm just going off what little I was able to scratch up and understand.
I'm going to run 48p, the XI S comes with 85T and I ordered an 80T. I'm hoping to find a pinion that will work. Any advice is greatly appreciated.
Cullen
Old 11-06-2013, 05:18 PM   #3191
Boosted 17.5 around 6.5fdr blinky around the 4.0 mark
thefan is offline   Reply With Quote
Old 11-06-2013, 05:57 PM   #3192
Did more research, you guys know your stuff. I'll be trying a 71/35 for an FDR of 4.0X w/ a Turnigy Trackstar 17.5T and HK Xrun 45A. By "boosted", I'm assuming timing? This ESC offers timing and launch parameters, but no turbo function. I wont be racing, unless race nights are nights I'm free. Just looking for a setup that will get me close to what others are running and maybe let me be competitive at an intermediate level. Am I on the right track?
I also have the kit supplied 85T and an 80T spur coming - ordered 30 and 35T pinions. Also have a 24T pinion laying around, which with 71T spur will get me 5.92 FDR.
Old 11-07-2013, 04:43 AM   #3193
salze145's Avatar
Small video of 2 sakura zero with unexpected ending...
+ YouTube Video
RGT R2 pro 10.5t - M05 pro mabuchi - TT02 13.5t - Vintage Asso RC10L
salze145 is offline   Reply With Quote
Old 11-07-2013, 08:50 AM   #3194
Default Here's what I did and it didn't take much
I've been running both a xi and a sport over a year now and I've learned that first and foremost check your belts, too tight and they will act like brakes and bring your rear around when you let off in a turn. Second, loosen they rear, lay the shocks quite a bit and tighten up front on the shocks, tightening up front prevents your front end from dipping when your in a braking situation or when you let off the trigger. Third and maybe most important is your car must be like a wet noodle and by that I mean no parts must bind what so ever and some items maybe loosened a bit to allow twisting and tweaking of your chassis. I can garruanty that I spent almost a whole year trying out a lot of variations of suggestions but this is what happen to me at the end of this years journey. Remember think wet noodle and try afore mention and you will start gaining power at the rear end and don't be afraid to do a stiffen the front. Also 40 weight on all shocks helps a lot. And it works on both asphalt and carpet.
Hope this helps.
Ol skool
Ol skool nitro is offline   Reply With Quote
Old 11-07-2013, 10:19 PM   #3195
Trader Rating: 103 (100%+)
Send a message via MSN to Texas Postman Send a message via Yahoo to Texas Postman
I'm curious, about what you mean..."tighten up the front." Shocks-up...down...tighten-up the spring tension...stiffer spring rates?????
Texas Postman is offline   Reply With Quote
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
