3Racing Sakura Zero S
#3151
so my next club race is this sunday.
so im going to change my droop to 6 and 5 in the rear ( i notice set up sheets for xi sport that all droop is at 6 for carpet) i will see what the # is with ride height+
change the camper to 1.5 and 2 in the rear
and im going to order ball difs....i notice that schumacher mi1 have ball dif in the front as well. so would that help me out?
#3152
If you're going to get a ball diff, make sure you spend a few extra $ and get ceramic balls instead of the plain steel ones. The ceramic balls will be less prone in getting flat spots on them if you have your diff to loose and it slips.
Cheers
Rob.
#3153
A gear diff with 500,000 wgt oil in it works very well at the front of a car, you get great acceleration out of the corners, along with being able to turn hard into the corners.
Cheers
Rob.
Cheers
Rob.
The ceramic balls will last longer but it takes more tension on the diff bolt to get the proper slip. either way it will work fine. Have a whole season on my steel ones and I'm not ready to replace them yet. plus the ceramic balls will wear out diff rings faster.
#3154
Looking from some experience with Zero S owners,
I am going to place an order for one in the next couple days. And i wanted to know what should i order along with it
I plan to run this in a USGT class.
So i would like to know the following--
Absolutely needed during build:
Spare parts(Common failures):
Parts i should upgrade soon:
Thanks!
Thanks!
#3155
buy xi sporty instead it has Universal Driveshafts ,spool,adjustable shocks.
for upgrades... metal Mounts
for spare parts the list could be long (just order a extra car)
Thanks!
Thanks!
jushhh now im going to order a xi sporty
#3156
Thanks!
Thanks!
Cheers
Rob.
#3157
Anybody know whats the biggest size pinion that will fit on the stock kit with stock 80T spur gear?
#3159
Thanks!
Thanks!
Upgrade right away.
Vertical motor mount
threaded shocks
64 pitch gears
spare parts are the same as any car. a arms, c hubs, steering knuckles, rear bearing carrier.
Upgrade soon
sway bars
carbon narrow chassis
steering rack
front spool
rear ball diff (if you get tired of the gear diff)
Everything else
#3160
#3161
Upgrade right away.
threaded shocks
64 pitch gears
Upgrade soon
sway bars
steering rack
front spool
Everything else
threaded shocks
64 pitch gears
Upgrade soon
sway bars
steering rack
front spool
Everything else
I notice you have one. Anything worth mentioning on it? IE same stuff as previous asked.
#3162
I actually have the original xi. it is my understanding that the xi sport is a combination of the xi and the new ultimate. Both the xi and the ultimate were offered as fully decked out touring chassis. a true sport version of the xi was never offered. I don't have any experience with the xi sport. sorry but im not much help with those parts. now tuning questions I can still try and help. basic tuning is the same regardless of the chassis.
#3163
well today the track change to very technical track and notice im having problems with my servo/servo saver....have to make it go straight before i can do any thing else. i was kinda doing all right but steering was giving me problems
#3165
agreed the kit one isn't very good.
