Old 09-20-2013, 06:37 PM   #3121
6376vette
what sway bars do you use?
TeamThibault is offline   Reply With Quote
Old 09-20-2013, 08:35 PM   #3122
Originally Posted by doughboy-77 View Post
im shure that the looseness is me and it seems to happen on exit mostly my car gets loose over steering as i see the other racers make it all look easy nice tight turns straight on the straight aways im sliding on turns and all over the place on the straights im still learning but also think it helps to get a lil feed back on what i could be doing wrong or what i can do to get better we run on pretty fresh blk asphalt great traction and i have no sway bars .......thank you for any time anyone has offered im starting to think that maybe my hand eye skills are no good but im gonna keep at it even if i dont get to a pro level im just having fun with my son and new people but i still like to be competive w the class............. sorry about my spelling
I would run 2 degrees of rear camber and increase front droop by 1 mm. the camber will help maximize the tire contact patch and the increase in front droop will allow more weight to transfer to the rear when you accelerate out of the turn. the weight shift will help keep the rear planted. You could also try a slightly softer spring in the rear as well. try this and let us know how it works.
3Racing Sakura XI 17.5 TC
Formula Rabbit (FGX conversion) 21.5
STRC LCG 2WD Slash 17.5
Serpent S120 13.5
6376vette is offline   Reply With Quote
Old 09-20-2013, 08:38 PM   #3123
Originally Posted by TeamThibault View Post
6376vette
On carpet I am using the stiffest (5 stripe) on the front and softest (2 stripe) on the rear. for asphalt I go 4 stripe up front and 3 stripe in the rear.
Serpent S120 13.5
Old 09-20-2013, 09:38 PM   #3124
doughboy-77's Avatar
ok thank you fellas ill get back w ya on this
proud supporter of jakes rc pro am ,cco on road
doughboy-77 is offline   Reply With Quote
Old 09-21-2013, 07:07 AM   #3125
when i change over to alum Bulkhead Covers what size of washers do i use?
do i change my ball ends?
Old 09-21-2013, 07:21 AM   #3126
ta04evah's Avatar
1mm & 2mm washers will be a good starting point as this will give a few options eg 1+2mm washer = 3 mm, 1+1mm = 2mm. Probably could even grab some 3mm & 0.5 mm washers for added options.
Changing the height of the washers under the ball screws will change the roll center of the car.
You don't need to change the ball ends on your turnbuckles if that's what you're asking about.
Cheers
Rob.
BSR BT-4 / Turnigy / Hobbywing / Savox / Trackstar
Castle Hill Raceway Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 09-21-2013, 07:28 AM   #3127
when you put your c hubs on the front what side does the writing goes on front or back?
Old 09-21-2013, 07:36 AM   #3128
ta04evah's Avatar
To the front of course, one will have "4R" - for the right hand side, the other will have "4L" - for the left hand side.
Cheers
Rob.
Old 09-21-2013, 07:42 AM   #3129
so battery side will be right side?
Old 09-21-2013, 07:52 AM   #3130
ta04evah's Avatar
Yes.
Old 09-21-2013, 09:51 AM   #3131
can some of you guys post your carpet set up 17.5 binky
what would i use for springs? i only have stock ans cheap 3 racing set {purple (Soft) ,Gold (Medium) ,Blue (Stiff) ,Silver (Extra Stiff)}
med front soft in rear?
Old 09-23-2013, 12:31 AM   #3132
salze145's Avatar
is a good option to buy the sakura zero narrow chassis 13B/WO? what improvements brings to the car?
someone has replaced stock damper shafts for optional titanium?
thanks!
RGT R2 pro 10.5t - M05 pro mabuchi - TT02 13.5t - Vintage Asso RC10L
salze145 is offline   Reply With Quote
Old 09-23-2013, 08:19 AM   #3133
ta04evah's Avatar
thanks!
Click here for information on improvements with the narrow chassis.
Cheers
Rob.
Old 09-23-2013, 02:46 PM   #3134
salze145's Avatar
Cheers
Rob.
Thanks, I think that is what I need for my sakura!
Old 09-24-2013, 07:53 AM   #3135
trick25's Avatar
Trader Rating: 25 (100%+)
which Tamiya short springs work on the stock shocks.
and is anyone using them and if so which ones blue fr/yellow rear? yellow front and rear?
4wd bug-D413, 2wd ST-DEST210R, Blinky bug-22 2.0
Etrug-Tekno ET48.3 4wd SC-SCT410
trick25 is offline   Reply With Quote
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
