Old 06-29-2013, 01:46 PM   #2941
shadowracer24's Avatar
Box stock zero s from what I can tell, has no hopups on it. Honestly if they want more than say $175. for the whole setup pass it by cause it looks well used and would cost you more in the long run. If you intend to race with it the electronics in it would have to be replaced. No one uses that setup around here.
Richard Carpenter
SPEEDZONE Batteries Team Driver
BMI Team Driver
2014 F.E.D.S. Mod Sprint and Sportsman Late Model Champion
2013 FSERA World GT State Champion
shadowracer24 is offline   Reply With Quote
Old 06-29-2013, 05:07 PM   #2942
Originally Posted by basher88 View Post
Hi guys, need help here to decide whether to get this zero s or not, please kindly take a look of the for sale link and give me some ideas: http://www.rctech.net/forum/manila-r...-only-142.html. Sorry i just post the whole link and not only the zero cuz i don't know how to post pics here. I just wanna know if the parts of zero s in the pic a stock or upgraded one? And about the said Tamiya Sport Tuned motor, what can you guys say about it? Any advice?
Sorry am just getting into the touring scene so please bear with me guys.
Thanks a lot
Not worth worrying about. Just go to hobbyking and buy all you need for around 250 for the lot. Car $70,esc $30,motor $37,radio gear $40,battery $30, charger $30. If your gonna buy cheap gear, might as well get new cheap gear.
Yogi- is offline   Reply With Quote
Old 06-29-2013, 06:52 PM   #2943
Don't gorget the $60 charge for shipping... here's what id do if I could do it over...buy the kit from tqracing or some other in the USA distrubuter and buy electronics from HK...it seems smaller packages get to the USA quicker from china and you be able to start building the kit while your waiting...for the few dollars up or down in shipping cost I could already be building my kit.... instead my package is in limbo somwwhere and it has already been over a week since I ordered from HK...I'm expecting to be waiting for at least another week or two before I get my stuff... TTS
ttsquirrel is offline   Reply With Quote
Old 06-29-2013, 09:23 PM   #2944
Thanks a lot for the heads ups shadowracer24 and yogi, i'll take a good look at hobbyking and see what i'll come up with, cheers
basher88 is offline   Reply With Quote
Old 06-29-2013, 11:19 PM   #2945
Originally Posted by ta04evah View Post
Start out with your largest Spur gear & smallest pinion gear (80/22), run the car for a minute and check the temp of the motor, if the motor is not hot then go the next pinion up and repeat the process.
If the motor is too hot to touch, then you need to go to a smaller pinion or larger spur gear.
Cheers
Rob.
Thank you .
sonspit is offline   Reply With Quote
Old 06-30-2013, 03:00 PM   #2946
Trader Rating: 93 (100%+)
Default Vertical motor mount issue
I picked up a car that has the vertical motor mount installed, and access to the lower motor mount screw is a little difficult. Do you guys shave down the battery stays to get better access to it?
Life moves pretty fast. If you don't stop and look around once in a while, you could miss it. -- F. Bueller
eddiemoney13 is offline   Reply With Quote
Old 06-30-2013, 05:50 PM   #2947
sporadicidiocy's Avatar
I drilled a hole through it so I can use a long shaft driver perfectly straight. Any weird angles with the driver on the screw head might strip the screw and that's not something I want in that tiny space.
90% Sakura Zero: Reventon S V3.0 10.5T
Sakura Ultimate: GTB2 17.5T
F104 Pro: SXX V2 Trackstar 21.5T
F103 Chevronmodels 6-wheel conversion
sporadicidiocy is offline   Reply With Quote
Old 06-30-2013, 06:30 PM   #2948
Thanks. I'll try that. I've been removing the battery stays whenever i needed to get to that screw but that gets tedious after a while.
Old 07-01-2013, 12:36 PM   #2949
Turnigy TD10
Is this a clone, or an actual re-licenced Zero S made in the 3Racing factory?
http://www.hobbyking.com/hobbyking/s..._Car_KIT_.html
Sakura Zero S/Traxxas Slash Ultimate 4x4/Stampede/UL-1 Hydro/ & Lots of flying things
cygnusx1 is offline   Reply With Quote
Old 07-01-2013, 12:47 PM   #2950
Pro10noob's Avatar
Not a clone, just rebranded by Hobbyking as there car.
3racing still makes them but now for Hobbyking.
This because they now sell the XI sport as there entry level car.
Regards Roy
Originally Posted by cygnusx1 View Post
Turnigy TD10
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 07-03-2013, 08:59 AM   #2951
How is parts availability for this car?
Philippe
2WD Slash - Father and Son Project!
RC10 GT - Trying to get this baby running.
theace18 is offline   Reply With Quote
Old 07-03-2013, 09:37 AM   #2952
Parts seem to be readily available right now ,however the zero and zero s are being dropped and replaced by xi and xi sport...I don't know the part campatability between the older and newer models...maybe someone else can chime in....TTS
Old 07-03-2013, 09:56 AM   #2953
Trader Rating: 38 (100%+)
Yeah I'd like to know too! I can build a car with say $150 ish (with electrics) into it to use to practice with and not tear up my TC6, heck yeah!!!
don't take it too serious, they are toys....
vw addict is offline   Reply With Quote
Old 07-03-2013, 10:05 AM   #2954
Hmmm. That's interesting. I wonder how parts will be then since the Turnigy TD10 is just a rebranded version of the Zero S.
Philippe
Old 07-03-2013, 10:27 AM   #2955
Nothing is listed on Hobbyking's site yet as far as parts go....
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
