Old 06-22-2013, 05:46 PM   #2911
brothainchrist0's Avatar
Trader Rating: 145 (100%+)
Oh shoot. I guess that makes sense. I guess I had them backwards. Sounds good! I might have to give it a try. Thanks man!
Mugen MRX5 - Ielasi Modified Engines/Matrix Tires/Savox Servos/Airtronics Radio
IGT Hobbies - The one stop shop for anything on-road and incredible customer service.
brothainchrist0 is offline   Reply With Quote
Old 06-22-2013, 06:04 PM   #2912
Double post. Sorry
Old 06-24-2013, 07:36 AM   #2913
Alright dudes, I'm having a hard time finding the right rear shock towers to move the body posts forward. All I can find is the xi towers in the +4 format. Can I use those with the stock length shocks? I just want some carbon fiber rear shock towers that I can use the stock rear shocks with and that I can findnon tqrcracing.com.
Thanks!
Kyle
Old 06-24-2013, 07:47 AM   #2914
bronc4now's Avatar
Trader Rating: 40 (100%+)
Yesterday my brother broke the chassis after a nice hit on some tube..the front screw point that holds the front suspension block. it was the stock plastic pc and it broke and the weak bumper didn't help ether. .
Any way looking for something better should I go with the c.f. chassis std ? Or narrow ?
Narrow has to use all 4 narrow suspension blocks right?
Any one else make somehing like exotech?
RACE-BASH-CRAWL
Two many toys not enough time..
bronc4now is offline   Reply With Quote
Old 06-24-2013, 03:35 PM   #2915
Go narrow cf. it uses the standard or narrow suspension mounts. I recommend standard mounts. my son runs a fully upgraded car on the narrow chassis and it is awesome.
3Racing Sakura XI 17.5 TC
Formula Rabbit (FGX conversion) 21.5
STRC LCG 2WD Slash 17.5
Serpent S120 13.5
6376vette is offline   Reply With Quote
Old 06-24-2013, 03:39 PM   #2916
Thanks!
Kyle
The +4 towers will not work with the stock shocks. they are designed for more traditional longer shocks. honestly I wouldn't worry much about relocating the shocks. there are much better upgrades to spend money on. If you are set on it I believe it is a tamiya 416 tower with the xi bulkhead covers. please someone else confirm this as I'm not 100% sure. never needed to do this to mine. car drives up front just fine as is.
Serpent S120 13.5
Old 06-24-2013, 06:21 PM   #2917
bronc4now's Avatar
Thanks ! I didn't want to buy new mounts.
RACE-BASH-CRAWL
Old 06-25-2013, 02:35 AM   #2918
Thanks a lot! I actually just found the right parts thanks!
Old 06-25-2013, 03:46 AM   #2919
wollow86's Avatar
I answered that a page or two ago with my hybrid. If you want to do it use standard xi rear tower and front bulk head covers from the zero. Moving the tower forward won't really do anything, except if you use both a zero and an xi (like me) you can make the bodies fit both chassis with no extra holes.
Supporting Aussie hobby shops:
- www.MRJRacing.com.au - - www.feralbatteries.com.au - - www.actionrc.com.au -
wollow86 is offline   Reply With Quote
Old 06-25-2013, 04:04 AM   #2920
The main reason for me wanting to move the tower is to avoid putting the rear body posts so close to the spoiler. I wanted to put them where they normally are on most other cars. I figured there wasn't going to be much performance gain from it but I'm ok with it. I just ordered the plastic front bulkhead cover for the rear and the xi rear standard shock tower.
Old 06-25-2013, 04:12 AM   #2921
wollow86's Avatar
Yep that will do it.
Old 06-26-2013, 02:18 AM   #2922
Any zero s Aussies coming down to Canberra for the ACT indoor titles ?
Yogi- is offline   Reply With Quote
Old 06-26-2013, 02:54 AM   #2923
ta04evah's Avatar
Yep, I'll be making the trek down there with my Zero's.
Not sure which car I'll use until I find out on Friday which car likes the surface the best, but most likely my zero s as it's a very gentle, versatile and easy car to setup & drive.
Cheers
Rob.
BSR BT-4 / Turnigy / Hobbywing / Savox / Trackstar
Castle Hill Raceway Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 06-26-2013, 05:06 AM   #2924
Cheers
Rob.
Hope I see you there. My setups working but there's always room for improvement. You may have some tips.
Old 06-26-2013, 07:03 AM   #2925
ta04evah's Avatar
Likewise, it'll be my first time there and first time running on foam tires since a long time ago.
My Zero S
All it needs is some CF shock towers, titanium turn buckles and the narrow CF lower deck.
Cheers
Rob.
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 05:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 10:21 AM
SEO by vBSEO 3.5.0
