Old 05-14-2013, 08:27 PM   #2806
Thumbs up
Originally Posted by danny325is View Post
My zero finally has electronics in it and is painted.
First RC paint job in 20 years.
nice!
sonspit is offline   Reply With Quote
Old 05-14-2013, 09:53 PM   #2807
Originally Posted by pmac View Post
to make this a drift chassis without going to overboard. you need a locked diff in the rear and preferably a one way in the front.
if you want to get into the CS stuff that is going on at the moment you need to change the centre pulleys to get more drive from the rear than the front. You will also need to increase the steering throw. There are some youtube clips on this for the sakura zero.
the pure drift chassis are very different in the motor and battery placement so there is a lot of customizing required if you want to do the lot and is probably cheaper in the end to get a drift chassis.
Thanks for that I ordered a solid axle for the rear and a oneway for the front. As for the center pulleys which ones should I look at?
Sakuraszero is offline   Reply With Quote
Old 05-15-2013, 08:43 AM   #2808
Originally Posted by ta04evah View Post
ESC, basically a re branded version of the solid & reliable Hobbywing ver 2.1 esc
Motor, as stated above, very inexpensive and give the same performance as the big $$ brands
Program card, will allow you to change & adjust settings in the esc. Even though it says it's the "Turnigy" brand it will work with the above esc.
Cheers
Rob.
The ESC is back ordered. Is HobbyKing pretty good about restocking quickly? Or is there another ESC that would work well with that motor that's cheap too?
SuspiciousLlama is offline   Reply With Quote
Old 05-16-2013, 12:36 PM   #2809
danny325is's Avatar
HK is very spotty about filling back orders. some things are quick, some things have been on back order for months
Dan
Hamilton, NJ
"Auto racing, mountain climbing, and bull fighting are the only real sports, the rest are just games."
danny325is is offline   Reply With Quote
Old 05-16-2013, 12:46 PM   #2810
danny325is's Avatar
Default Gearing this bad boy
Ok, Gearing this car is a pain in the butt.
with the stock spur the MAX pinion you can fit is a 37t and the 37 didn't even fit right. too tight. (36 is real world) With a 37t FDR was at 4.108 I wasn't even breaking 110 degrees with a 17.5 blinky
So I got the vertical motor mount and 37t would not fit at all.
Changed the spur to a 78t(stock is 80t) and had to grind a bit of the vertical mount so the 37t would fit. Now FDR is 4.005 getting better.
I now have 74t and 75t spurs coming. I also have 37t diffs coming at well.
I also have 19t layshaft gears as well, but that is not direction i want to go.
Dan
Hamilton, NJ
Old 05-16-2013, 03:25 PM   #2811
Switch to 64 pitch gears. The 19 tooth pullys are also the way to go.
3Racing Sakura XI 17.5 TC
Formula Rabbit (FGX conversion) 21.5
STRC LCG 2WD Slash 17.5
Serpent S120 13.5
6376vette is offline   Reply With Quote
Old 05-16-2013, 03:33 PM   #2812
SteveM's Avatar
Trader Rating: 128 (100%+)
+1
SteveM is offline   Reply With Quote
Old 05-16-2013, 06:25 PM   #2813
danny325is's Avatar
What Spur/pinion are you running in 64 pitch? Right now I need to test a 3.7 -4 FDR for the courses i run.
I was trying to avoid 64p as I do alot of dirty parking lot running as well and 64p don't hold up well.
Dan
Hamilton, NJ
Old 05-16-2013, 08:42 PM   #2814
I'm running an 88 tooth spur. I have run a FDR from 3.8 up to 4.3 and have not maxed out the adjustment in either direction the 88 is a great all around spur for this car when using the 19 tooth pulleys and the stock 38 tooth diff. I have had the same spur in my car for months without a problem. as long as you adjust the mesh properly they last just fine.
With the 19 tooth pulleys and the 38 tooth gears your ir is 2.0 so a 44 tooth pinion is a 4.0 FDR. a 47 tooth would be a 3.74. I have only run up to a 46 tooth but the 47 should fit just fine.
Serpent S120 13.5
Old 05-17-2013, 03:28 AM   #2815
You need to go as small as 68-70t spur with a 32-34t pinion to get 3.8-4fdr i use 20t pulleys as the belts have stretched now
thefan is offline   Reply With Quote
Old 05-17-2013, 03:35 AM   #2816
SteveM's Avatar
I switched to the 19T layshaft pulleys from the start and ran 64P gears with a 92T spur and a 45T pinion giving me a FDR of 4.09 as a base and I adjusted from there.
Old 05-17-2013, 02:56 PM   #2817
I run a 65t spur and 47t (48p) everything else is stock. What fdr is that?
Old 05-17-2013, 04:47 PM   #2818
bakoo's Avatar
65/47 * 1.9 = 2,62
But which motor did you stuff in there? My 13.5T would go up in smoke in two laps with a ratio like that. I'm using the 19T pulleys to get the belts more relaxed, so with a 69T spur and 34T pinion my FDR is 69/34 * 2 = 4,06.
bakoo is offline   Reply With Quote
Old 05-17-2013, 09:24 PM   #2819
You sure that's right. I'm thinking you must be cooking motors very quick. A 65 tooth 48 pitch spur in achievable but not with that pinion ?
Yogi- is offline   Reply With Quote
Old 05-17-2013, 11:06 PM   #2820
He's doing speed runs not racing.
Serpent S120 13.5
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
