Old 05-10-2013, 08:56 AM   #2791
We just built a Sakura S with a Mamba Max Pro setup in it. Playing around with it today I think we were hitting near 80-90mph. Mine (10.5T with 120A BHR ESC) does 65 and this Mamba Sakura was passing me like I was stalled. I paid no particular attention to alignment other than making the links the exact measurments as the build instructions. We are both running fairly large foam tires with 7mm thick hexes. All fluids are box stock.
Sakura Zero S/Traxxas Slash Ultimate 4x4/Stampede/UL-1 Hydro/ & Lots of flying things
cygnusx1 is offline   Reply With Quote
Old 05-11-2013, 12:57 PM   #2792
how many of you guys have done every upgrade on this chassis? is the cf better chassis then the stock chassis for carpet?
thanks
TeamThibault is offline   Reply With Quote
Old 05-11-2013, 10:52 PM   #2793
mmp with what motor/battery and gears?
sonspit is offline   Reply With Quote
Old 05-12-2013, 01:33 AM   #2794
thanks
I run carpet with foams. The stiffer the better and heavy-springs.
21.5 blinky
4.25 springs up front 4.5 back
Very little droop maybe 2mm at most
4.5 and 5 mm ride hight
2mm toe out
1mm kick-up at front
Alloy bulk heads and stiff top deck
Putty in front diff shock oil in the rear
37 front and 35 rear matrix carpet foams.
I've been looking at the stiff bottom deck.
Yogi- is offline   Reply With Quote
Old 05-12-2013, 05:26 AM   #2795
Stock pulleys, 30T pinion, and it's the Mamba kit 4-pole 5700kv. Running a 3S lipo.
Old 05-12-2013, 05:35 AM   #2796
EricW's Avatar
What are some of the common parts to have on hand for this car? Going to do some on road racing in an RCGT class and I'm not looking to spend $400+ for a touring car at this point.
Stickas are for straight up suckas......
**** "Luxury" ****
EricW is offline   Reply With Quote
Old 05-12-2013, 05:58 AM   #2797
Start from the outside and work in. Hub axle carriers, C-hubs, control arms, shafts..camber link mounts on top of the bulkheads. Basically anything that can get hit in a crash. Of course belts and pulleys aren't a bad idea.
Old 05-12-2013, 07:14 AM   #2798
A arms, steering knuckles, rear bearing carrier, front c hubs. these are the parts you are most likely to break. If the track has nasty walls get some spare front body posts.
3Racing Sakura XI 17.5 TC
Formula Rabbit (FGX conversion) 21.5
STRC LCG 2WD Slash 17.5
Serpent S120 13.5
6376vette is offline   Reply With Quote
Old 05-12-2013, 07:20 AM   #2799
thanks
For racing on carpet the stock chassis is completely capable. I did a full upgrade to my cars just for fun not to keep up. I got all of the aluminium first then went for the carbon fiber parts. The carbon chassis is a really nice upgrade but not necessary to be competitive. if you get one get the narrow chassis. I have tried both and the narrow chassis seems to handle a little better
Serpent S120 13.5
Old 05-12-2013, 07:27 AM   #2800
EricW's Avatar
Thanks for the info guys.
**** "Luxury" ****
Old 05-12-2013, 03:22 PM   #2801
Hey guys I'm interested in drifting instead of buying another drift chassis just wondering is it possible to use the s zero for drifting and if so what I need to change in order to do this?
Sakuraszero is offline   Reply With Quote
Old 05-14-2013, 04:10 AM   #2802
to make this a drift chassis without going to overboard. you need a locked diff in the rear and preferably a one way in the front.
if you want to get into the CS stuff that is going on at the moment you need to change the centre pulleys to get more drive from the rear than the front. You will also need to increase the steering throw. There are some youtube clips on this for the sakura zero.
the pure drift chassis are very different in the motor and battery placement so there is a lot of customizing required if you want to do the lot and is probably cheaper in the end to get a drift chassis.
Turnigy RWD SCT with 3000kv Hobbywing combo
Tamiya Nitrage 1/8 5.2cc Nitro Truggy
3Racing Sakura Zero 21.5T TC
3Racing Sakura Ultimate 13.5T TC
pmac is offline   Reply With Quote
Old 05-14-2013, 04:15 AM   #2803
thanks
i think the CF narrow chassis is a great chassis. it is just so much lighter than the FRP chassis. I think a total of 30 grams just in the chassis.
I found it to be more predictable in the flex characteristics as well so tuning became a bit easier.
I still believe the zero s has to be the best chassis for a beginner and i have slowly upgraded it to a full zero.
I'm looking forward to the sakura ultimate and XI sport to be released! they should both be pretty awesome.
Old 05-14-2013, 09:07 AM   #2804
Sweet.
Any heat issues with the mmp or 5700
Old 05-14-2013, 03:22 PM   #2805
danny325is's Avatar
My zero finally has electronics in it and is painted.
First RC paint job in 20 years.
Dan
Hamilton, NJ
"Auto racing, mountain climbing, and bull fighting are the only real sports, the rest are just games."
danny325is is offline   Reply With Quote
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
