Old 04-25-2013, 10:44 PM   #2746
Send a message via AIM to zenitram Send a message via MSN to zenitram
i havent installed the servo mounts or the servo yet. i just screwed down the steering block and screwed down the one screw that goes from the top of the upper deck into the steering block. it only touches one side and it is pertty light. i think if i just lightly sand the bottom of the bulkhead and the top of the steering block it will be fine
AE b44.2
AE RC10T3
Traxxas Monster Energy Camero
zenitram is offline   Reply With Quote
Old 04-26-2013, 10:52 AM   #2747
Metalsoft's Avatar
Trader Rating: 69 (100%+)
Originally Posted by SteveM View Post
You must mean the Spec-R S1.
Yep that is what I meant, sorry for the confusion.
Also for the guys having problems with the servo, I simply drilled new holes and lined it up perfectly parallel with the top bulkhead. I got tired of messing with it. Made everything much better.
see attached.
Tamiya TB03 USGT - Custom Carbon fiber Chassis - Magoo Racing Inc....
Metalsoft is offline   Reply With Quote
Old 04-26-2013, 11:03 AM   #2748
That would deffinitly fix the issue but i dont want to go that extreme just yet. I think i have the wrong spacer in there so i am going to measure again and see if that works
AE b44.2
AE RC10T3
Old 04-26-2013, 11:45 AM   #2749
Metalsoft's Avatar
It is super easy not really extreme, you are simple adding two holes....
Plus you get the advantage of using a better servo saver and any servo you want without problems. It helps out with binding also.
Old 04-26-2013, 12:04 PM   #2750
Those are all very good points. Might have to dust off the drill press
AE b44.2
AE RC10T3
Old 04-26-2013, 01:43 PM   #2751
Originally Posted by sonspit View Post
got a new sakura s coming sat.
anybody ever run the lrp vector x12 3.0t brushless motor in these/ or at all in touring car? whats a good gearing? and are these motors any good? ( as far as speed, efficiency, and durability)
anyone?
sonspit is offline   Reply With Quote
Old 04-26-2013, 08:36 PM   #2752
how many sakura s do you own? what class's do run with them?
what class do you think it works best in
TeamThibault is offline   Reply With Quote
Old 04-26-2013, 09:27 PM   #2753
I own 3. Have raced vta usgt and 17.5 blinky tc. it works well in all of these classes. I like the xi better in tc though but they both run very well.
3Racing Sakura XI 17.5 TC
Formula Rabbit (FGX conversion) 21.5
STRC LCG 2WD Slash 17.5
Serpent S120 13.5
6376vette is offline   Reply With Quote
Old 04-27-2013, 03:59 AM   #2754
I run my Sakura S in VTA 2.5, and I like it.
gerrbear is offline   Reply With Quote
Old 04-28-2013, 06:23 AM   #2755
SteveM's Avatar
Trader Rating: 133 (100%+)
In case anyone is looking, I have my fully upgraded Sakura Zero S for sale with loads of parts at the following link.
Sakura Zero S - UPGRADED
SteveM is offline   Reply With Quote
Old 04-30-2013, 07:47 AM   #2756
Vertico's Avatar
Hey guys, I am super new to RC Cars, I mainly fly CP Helis at a local club.
I picked up a Sakura Zero S and am trying figure out my electronics.
I will only be driving for fun and do not need a competitive setup.
Can anyone recommend a good inexpensive motor and ESC to use with the stock gearing?
Vertico is offline   Reply With Quote
Old 04-30-2013, 10:07 AM   #2757
2nd Time Around's Avatar
Default options
check out brushlesshobbies.com or hobbyking.com i think the stock gearing is for a high speed motor so 3300kv 10.5t will get ya going
2nd Time Around is offline   Reply With Quote
Old 04-30-2013, 07:22 PM   #2758
Try the turnigy trackstar silver motors. they are cheap and getting great reviews. the turnigy esc is supposed to perform well too.
Serpent S120 13.5
Old 04-30-2013, 07:51 PM   #2759
Vertico's Avatar
Thanks!
Old 05-01-2013, 02:58 AM   #2760
Would a24mm belted tire fit
a 26mm rim?
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
