Old 04-09-2013, 11:49 PM   #2701
Originally Posted by Nickerz View Post
I just started building my car today and noticed two things...
1. After tightening the Gear Differentials down, one seems harder to turn (when turning the "Differential Out Joint" - pg. 1 of the manual). Are these suppose to be pretty hard/tight to turn or are they suppose to move more freely? If I loosen all 4 screws they turn easily but then oil starts coming out so I'm guessing the screws are suppose to be tight.
2. (See Pic Below...) Anyone notice that the bottom ring of the Pulley snaps off kinda easily? When I was tightening down each half, they both cracked a little and I thought I broke it. I think I did but there is no break in the plastic. It's the end on the "Gear Differential Housing" that comes off. It can go back together but it needs to be glued as it will come off again. Just weird. Here's a pic of what I'm talking about...
I followed this page: http://os.3racing.hk/articles.php?articles_key=133 when building my last diff.
Anthias is offline   Reply With Quote
Old 04-10-2013, 06:16 AM   #2702
Trader Rating: 40 (100%+)
Originally Posted by sonspit View Post
if I set my throttle epa on the radio at half then calibrate the esc then max out the epa on the radio that would make my esc's endpoint 150%? thus create more speed
No the ESC only understands 0-100%
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 04-10-2013, 10:06 AM   #2703
Thanks! I'll check this out. I nice guy at my LHS helped me yesterday and told me about this link also! He disassembled and assembled one of my gear diffs and it works better but suggested I get a different kind of grease and it looked like the anti wear grease in the link. It's great to get help in this hobby and I'm glad I noticed it didn't feel right as the guy helping me said it was way to tight. I wouldn't have had a good start if I ignored it and moved on to the next step. I'll keep everyone posted how it turns out.
Nickerz is offline   Reply With Quote
Old 04-12-2013, 07:27 AM   #2704
Any body race there sakura on carpet with rubber tires, what setup changes would be needed?
thefan is offline   Reply With Quote
Old 04-12-2013, 09:24 PM   #2705
Anybody ever think of mounting 1 8 scale electronics (esc and motor) with more aggressive gears and more powerful batteries for high speed runs?
sonspit is offline   Reply With Quote
Old 04-12-2013, 09:55 PM   #2706
Coming from what to carpet? Carpet is usually high traction so high traction asphalt to carpet probably not much. low traction to carpet maybe springs, shock oil, a droop change and maybe differential tension or oil weight. in my experience the changes aren't drastic just fine tuning. personally I think its easier to tune for carpet.
3Racing Sakura XI 17.5 TC
Formula Rabbit (FGX conversion) 21.5
STRC LCG 2WD Slash 17.5
Serpent S120 13.5
6376vette is offline   Reply With Quote
Old 04-12-2013, 11:42 PM   #2707
Thanks it would be from high grip asphalt to carpet using 17.5blinky, i noticed your signature has 17.5 what fdr are you using assuming its blinky that is.
Old 04-13-2013, 08:30 AM   #2708
You shouldn't need to make too many changes then. just some fine tuning. I am running blinky on a small size track. maybe 50x75 and we are all running somewhere around 4.0 FDR. one guy tried 3.5 up to 4.5 and only saw a tenth of a lap difference. motor temps stay cool around 120f with a single cooling fan and almost full to full timing. I run a d3.0 and my son runs a ballistic. We are using sweep 32 tires with a track temp around 75 degrees f. some guys run jaco blues with great results. I ran a set of jaco tires and loved the extra turn in. just trying to use up my sweep tires before I switch.
Serpent S120 13.5
Old 04-14-2013, 10:52 AM   #2709
how many of you guys race zero s against other high end cars(xray ,tc6,417) and how do you make out? can you keep up?
i read some where that these cars tweek bad and then are hard to be consistent.is this tru?
are the chassis or parts too soft?
is this car only good for starting out?( beginners car only?)
can it be raced box stock? and keep up?
urban is offline   Reply With Quote
Old 04-14-2013, 11:50 AM   #2710
Lol. That's what the x ray associated etc. people want you to think. they are always amazed and sometimes upset that a box stock s can beat their $500 chassis.
They will tweak but they all tweak. the s isn't any worse than any other car. parts are just as good as any other. there a few upgrades that really can help but I would not call any absolutely necessary. just really nice to have.
the s can be fully upgraded to a full carbon fiber and aluminium ride just like any other chassis. I have 2 s models and an xi and they all run with all of the other chassis. I spend less time tweaking and tuning compared to the x ray and associated cars and still run right up front. We have a handful of these cars running at our track and they fit right in.
I wouldn't call it a beginners car by any means. it can be labeled as a grow with you car. as you master the basic car begin to add parts like threaded shocks and sway bars and let your skill grow with the car. too many options in the beginning can confuse a new driver and can become frustrating.
I guess the short point is that it is a great car that can run with any of them.
Serpent S120 13.5
Old 04-14-2013, 05:18 PM   #2711
It's my first touring car and I am totally impressed with the simplicity vs toughness and performance. My buddy saw mine, but went to a hobby shop and picked up an HPI Flux Sprint 2 and, although it's fast (top speed) out of the box, he is always battling handling issues, and reliability issues. I hit 65mph with my S this weekend and it is rock stable...except for the pebble that sent it into triple back flips when the wind got under the nose...
IMHO, for big improvements on the S, you need only good tires, and a setup station/tools.
Sakura Zero S/Traxxas Slash Ultimate 4x4/Stampede/UL-1 Hydro/ & Lots of flying things
cygnusx1 is offline   Reply With Quote
Old 04-14-2013, 09:27 PM   #2712
what do you guys do for the belt that rubs on the front?
TeamThibault is offline   Reply With Quote
Old 04-15-2013, 10:44 AM   #2713
raise up the diff to the high setting by rotating the adjuster 180 degrees
Jason Deadman
Old 04-15-2013, 07:19 PM   #2714
The carbon chassis need a slight amount of sanding to clear the belt properly. I never had a problem with the stock plate.
Serpent S120 13.5
Old 04-16-2013, 10:32 AM   #2715
Metalsoft's Avatar
Trader Rating: 69 (100%+)
I race against TC5's TC6's and two TCX and I always beat everyone except one guy that drive a TCX. The reason is not the car, he is simply a better driver than I am.
Tamiya TB03 USGT
Metalsoft is offline   Reply With Quote
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
