Old 03-20-2013, 12:26 AM   #2626
okay so i installed the vertical motor mount and the zero top deck, flipped the belts and modded the battery tray on my s. but i took it out for a run and it pulls to the left on throttle but tracks perfectly straight when its free rolling. can any one help me with this?
sonspit is offline   Reply With Quote
Old 03-20-2013, 12:31 AM   #2627
Originally Posted by Speed Passion View Post
The whole front and rear drive shaft that has the pulleys on it should be able to move a hair left and right if you try to move it by hand. If you can't move it, then it's binding. Place a .3mm shim under the bulk head covers. Should raise it .3mm and release it IF that is even the cause to your pulling to one side.
Hope that helps.
i've put a .3mm shims under all 8 places on all 4 bulkhead covers and still have the same problem. and i bought a whole new top deck just to make sure it wasnt the one i modded
Old 03-20-2013, 12:34 AM   #2628
Originally Posted by gerrbear View Post
I am just reminding you to check your bearing carriers to make sure that you have them in the same position side to side?
did this too
Old 03-20-2013, 02:00 AM   #2629
ta04evah's Avatar
Originally Posted by Rozzt_iwa View Post
rob
what motor speedy u using with that gearing
I'm using a Hobbywing Xtreme Stock esc and a Hobbywing Xerun 21.5 motor, with 19 teeth center pulleys I end up with a roll out of around 71. I use this gearing in my touring car, but only when the temps are really cool, when it's a bit warmer I drop it down to a 41 tooth pinon.
I use a similar ratio with my VTA car, but will drop another tooth on the pinon to allow for the larger diameter VTA tires and it's close to the ratio I used with my old VTA car at SMA.
Cheers
Rob.
BSR BT-4 / Turnigy / Hobbywing / Savox / Trackstar
Castle Hill Raceway Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 03-20-2013, 08:55 AM   #2630
no input ? im gonna rebuild my shocks and diffs today to see if it fixes the issue
Old 03-20-2013, 10:16 AM   #2631
Cross weights, alignment, ride heights, loose links, tire rub, tight bearing? Have to be methodical to find that stuff. Good luck.
cygnusx1 is offline   Reply With Quote
Old 03-20-2013, 10:55 AM   #2632
Speed Passion's Avatar
Agreed with all the above. Usually the balance is very common culprit. This is why people spend a lot of time balancing their car. One thing not mentioned is the tires. be sure they are balanced and even. Also make sure your camber is correct and even on both sides.
Hope that helps!
Speed Passion is offline   Reply With Quote
Old 03-20-2013, 03:35 PM   #2633
Cool
i rebuild the shocks and diffs. after i rebuilt the 1st diff in the rear and the shocks. i took it for a go and it seemed better so i went ahead and did the frnt diff but i cant run it right now because wifee always flipping... "you spend too much time on the cars, all i ask is some quality time, blah blah blah"lol but i will let you guys know after i get it outside... and thanks
Old 03-20-2013, 08:46 PM   #2634
ta04evah's Avatar
I was going to say check your diffs, make sure they both turn smoothly, if they feel "notchy" then you have them done up too tight and could be causing your steering issues.
Bwhahaha! Hey you've got something on your forehead, it looks like a deep thumb mark.
Anyway, hope it works good for you when you get the chance to try it again. My wife is awesome, she encourages me to race & buys me stuff for my cars.
Cheers
Rob.
Old 03-20-2013, 11:46 PM   #2635
Can someone help me I thought I blown the motor up in the s so i bought another one installed it and its doing the same thing so not motor lol. What happens is when I press throttle it does nothing but if I hold the throttle and turn the front wheels it will go but when I stop and press the trottle again it wont move unless I turn the front wheels anyone know what it might be?
Sakuraszero is offline   Reply With Quote
Old 03-21-2013, 05:28 AM   #2636
Trader Rating: 40 (100%+)
Bad receiver?
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 03-21-2013, 06:28 AM   #2637
Waflet's Avatar
Trader Rating: 30 (100%+)
Hideeho
What kind motors, receiver, & ESC are you using? Are the motors sensored or sensor less? If sensor less I have run into the problem that the rotor gets into a position that the ESC doesn't think it's in & won't move until it gets bumped, moving the rotor to the proper position. Moving the front wheels will move the car a little, moving the rotor into position. Next time it does it try pushing the car a little while giving it some throttle, if it takes off that's your problem. Unfortunately the only fix for it is a sensored motor & ESC.
If your motor is sensored do the same thing. If it takes off your problem could very well lie in either the sensor cable or the ESC sensor. Try another sensor cable. Then try another ESC, borrow one or install your motor & sensor cable in some else's car.
If its still not fixed try a different receiver.
The concept is to replace 1 component at a time, putting the others back in place as you switch to a new one in, until the problem is rectified. The component that is replaced & fixes the problem is one that needs replacing permanently (& is hopefully still under warranty ).
"Just leave me alone, I know what I'm doing."-Kimi Raikkonen
Mugen MBX7R Eco/Tekin RX8g2/Savox 2274/SMC 1900kv/Aitronics mt-4/promatch
Mugen MSC7(1/10 pro4 sct)/Tekin RX8g2/Savox 2274/Tekin Pro4HD 4300kv/Airtronics mt-4/SMC
Waflet is offline   Reply With Quote
Old 03-21-2013, 08:58 AM   #2638
Cheers
Rob.
they are notchy!!! so they're too tight? i thought they were just damaged and i dint know that could effect steering.. i tighten them up because it seemed like the only way to get them to stop leaking.. thanks i'll try loosening them up now.
and i ran it today and it was better but still doing wierd things. going left some time, going right sometimes and perfect other times... all on power or braking. but not as bad as before. loosened the droop screws so they dont effect droop at all since i dont have a gauge and i feel like they werent equal all around.
Old 03-21-2013, 07:56 PM   #2639
ta04evah's Avatar
Try loosening them a little bit and hopefully they won't leak.
When you build the diffs, check out this guide from 3 Racing http://os.3racing.hk/articles.php?articles_key=133
Follow what they advise and your diffs should not leak and last for a long time.
Also, are you using the servo saver that comes with the kit? If you are then throw it away, it's been mentioned many times how the kit servo saver has caused a lot of problems that are very similar & alike to yours.
Cheers
Rob.
Old 03-21-2013, 08:07 PM   #2640
Default more grip in the rear
ok some where in this thread it said if i add a spacer on the camber i will get more grip in the rear?
is that adding a spacer to rear bulkhead ball stud?
what is the part # to the shorter rear arms? is it SAK-X01
if i used Narrow Suspension Mount would that be the same as changing you arms?
would u used the Narrow Suspension Mount and shorter arms togethwer?
if i change my driveshafts to SAK-X27 do i need any other parts?
what is the diff between SAK-X27 and #SAK-40E
urban is offline   Reply With Quote
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
