Old 03-08-2013, 10:37 PM   #2551
1gdsmracer's Avatar
Trader Rating: 96 (100%+)
What do you have holding the battery on the inside from hitting the belt?
1gdsmracer is offline   Reply With Quote
Old 03-08-2013, 10:58 PM   #2552
Originally Posted by Kevin Marcy View Post
As a general rule, the higher the Kv rating (and lower number of turns), the smaller your pinion gear should be (higher final drive ratio). I race with a 4.5 turn geared at around 8.3 FDR, you're geared at less than half of that (4.05 FDR if you've changed to the 19T pulleys). Your 35C battery could also be limiting you. In fact, I'm surprised it hasn't "puffed", because you seem waaaay over-geared to me.
its a hard case.. what battery do u think would be ideal?
and whats your avg speeds?
sonspit is offline   Reply With Quote
Old 03-09-2013, 04:17 AM   #2553
On-Road-Boy's Avatar
Default Looking for a part number
Hey all just wondering if any one knows the part number for the 8 diff screws or where I can find some ?
Sakura XI HobbyWing-Spektrum-Savox
Sakura F113 HobbyWing-Spektrum-Savox-Venom
Team Pink
On-Road-Boy is offline   Reply With Quote
Old 03-09-2013, 05:41 PM   #2554
Speed Passion's Avatar
I tried to make something that looks factory and is versatile. What I used was two ball cups, and two of the ball studs from the swaybar kit and a small rubber m2.8x1.8 o-ring.
Put the small rubber o-ring over the pink ball stud. Put the ball stud into the ball cup. With the o-ring on it, it will stay put and act as a small shock absorber also. Place the ball cup standing up and screw it in from the bottom of the chassis. It's small, light and easy to make and looks factory.
Hope that helps.
Speed Passion is offline   Reply With Quote
Old 03-09-2013, 07:29 PM   #2555
Hope that helps.
post a pic plz. i just got the vertical motor mount. thx
Old 03-09-2013, 09:45 PM   #2556
To hold my battery away from the belt I just drilled and tapped a small length of aluminum square stock that was 5mm in width and depth. mounted it in pre existing holes through the bottom of the chassis. I used a M3 flat head screw mounted horizontally to hold the battery tight against the outside battery mounts. They work like the car's servo mounts except instead of holding the servo against the mount, I leave the screw sticking out about 6mm and it provides a stand off to push against the battery case. Kind of looks like an upside down capital L.
People like Yeah Racing make aluminum servo mounts you can buy that are exactly the same thing. Somewhere earlier in this forum the idea is shown in pictures.
capnkids is offline   Reply With Quote
Old 03-09-2013, 09:51 PM   #2557
The diff screws that are Titanium are 3 Racing part number TS-FSM2608M. Get the TI ones. You just can't get the steel ones supplied in the kit tight enough in my opinion. They strip out way too easy.
Old 03-09-2013, 09:58 PM   #2558
Ran my first race with the Zero S today. It was my first race in almost 15 years. I have some work to do on my driving, but the car had great speed. The setup for a rough asphalt cold track was fairly dialed. Of course my driving did not allow me to push the car super hard, but I led several laps in both the heats and the main before eventually getting over taken by better drivers. But I think the chassis had the speed needed to place very well.
I am very happy with things. Need to practice, practice practice.
Old 03-10-2013, 12:25 AM   #2559
just ceased the motor in the s lol dont brushless motors last long?
Sakuraszero is offline   Reply With Quote
Old 03-10-2013, 12:49 AM   #2560
sporadicidiocy's Avatar
I'm using the old motor mount "foot" along with two 2mm spacers and a M3X8mm button head screw to act as the battery standoff. Actually using two of these now because for some reason I have another "foot" leftover
Had to raise the rearward one with a 2mm spacer plus some other leftover part (conveniently pink as well) since towards the center pulley the belt is a little higher there. Looks pretty nice... even more pink than before
90% Sakura Zero: Reventon S V3.0 10.5T
Sakura Ultimate: GTB2 17.5T
F104 Pro: SXX V2 Trackstar 21.5T
F103 Chevronmodels 6-wheel conversion
sporadicidiocy is offline   Reply With Quote
Old 03-10-2013, 05:52 AM   #2561
Thanks all sorted
Team Pink
Old 03-10-2013, 06:27 AM   #2562
Have to strongly disagree here. the titanium screws have weak heads and will snap off leaving the thread in the hole. especially the countersunk heads but the button heads do it too. maybe a different titanium screw would work better but I would stay with steel.
3Racing Sakura XI 17.5 TC
Formula Rabbit (FGX conversion) 21.5
STRC LCG 2WD Slash 17.5
Serpent S120 13.5
6376vette is offline   Reply With Quote
Old 03-10-2013, 06:29 AM   #2563
What seized? Bearings stator or rotor? aren't you doing speed runs with your car and a mod motor?
Serpent S120 13.5
Old 03-10-2013, 06:34 AM   #2564
I've had good luck with the Turnigy 6000mAh "Nanotech" batteries which they rate at 65~130C. The track I race at has about a 180' straightaway, and mod cars are probably hitting 50-55mph. I've only put a 3.5T motor in it once, and it hit 56mph (by radar gun) at the halfway point of the straight. Then the rotor exploded and it went from 56 to zero in about 30' (I think the previous owner of the motor may have over-cooked it). Anyway, the gearing I mentioned in the earlier post was for running a 7 minute race with a 4.5T motor. If you're just trying to get top speed and aren't worried about motor temperature after a long run (and have a lot of room to "wind it out"), you might want to start in the 6-7 FDR range. But it's better to start with a higher ratio (smaller pinion) and work your way down to find the performance you want. Pinion gears are much cheaper than motors, ESCs or batteries.
Kevin Marcy is offline   Reply With Quote
Old 03-10-2013, 12:51 PM   #2565
I forgot to mention a 2mm spacer on the bottom. I use the same exact setup on the back also so it looks symmetrical even though in the front the belt is lower, on the rear the belt it higher but this configuration still easily clears it. I don't know what the latest battery dimensions are today; I'm using a 2s that fit's exactly no play. Using a Zippy lightmax 4000mah that is 46mm depth so fits perfectly.
You can probably do different ball cup configurations and screw lenghts to make it perect. The metal ones that come on the kit are longer I believe, so if you have a gap still those work also (where I got the idea with in the first place), but have to use a different ball cup like the ones on the shocks. I use this configuration as need less washers and it's taller. I pop on a large antenna cap (cut to size) to extend the gap more for my 3s which is smaller in width.
Hope that helps.
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
