Old 02-22-2013, 06:50 PM   #2476
gndprx's Avatar
Trader Rating: 18 (100%+)
Without digging through all of the pages of this thread, are there an US retailers carrying this kit and parts yet?
Carl Fisher
Team Xtreme RC
The Grove Racing Center
gndprx is offline   Reply With Quote
Old 02-22-2013, 06:57 PM   #2477
Integy is in CA. They carry it.
cygnusx1 is offline   Reply With Quote
Old 02-22-2013, 07:07 PM   #2478
Hotshot hobby in Marietta GA.
3Racing Sakura XI 17.5 TC
Formula Rabbit (FGX conversion) 21.5
STRC LCG 2WD Slash 17.5
Serpent S120 13.5
6376vette is offline   Reply With Quote
Old 02-22-2013, 07:10 PM   #2479
Trader Rating: 40 (100%+)
tqrcracing.com
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 02-22-2013, 07:21 PM   #2480
gndprx's Avatar
cool, thanks guys.
Thinking of moving my TC4 to VTA duty and try out the Zero in open.
Carl Fisher
Team Xtreme RC
Old 02-23-2013, 06:06 AM   #2481
tqrcracing and hotshot are both awesome to deal with. Have not tried the others.
capnkids is offline   Reply With Quote
Old 02-23-2013, 12:39 PM   #2482
Metalsoft's Avatar
Trader Rating: 69 (100%+)
Default Metalsoft's Tutorial on how to build Leak proof shocks
Here we go, I figure I would post this up as I was working on this today getting ready for this weekend's race...
Metalsoft's guide to build leak proof shocks!
Here we go
First you need the parts, I shop at TQrcracing.com for my Zero parts. Very fast shipping and the cost is only $2.99! I use the TRF M chassis springs as they are a direct fit to the STOCK sakura S zero
These are how you do it right, TRF bladders and TRF o rings
Next tear them apart and get them really clean...
Start rebuilding them using the TRF parts, and do not forget the plummers tape, wrap some around the bottom threads...
Tighten everything down ( by hand! ) and add plummers tape to the top also...
Fill with quality shock oil ( I use AE ) and boom you have a perfect built shock that will NEVER leak!
Sure does look nice! Getting ready for this weekend.
I still use the stock shocks, and if you build them this way they will last forever and be just as good and any shock you buy on the market. ( with in reasonable price. )
Enjoy, I have to get back to work!
Tamiya TB03 USGT - Custom Carbon fiber Chassis - Magoo Racing Inc....
Metalsoft is offline   Reply With Quote
Old 02-23-2013, 01:26 PM   #2483
Here we go
Nice write up but I have never had the stock shocks leak. they lasted a year of racing almost every weekend before the lower o rings started leaking. I changed the upper bladders at the same time just because but they weren't leaking.
Serpent S120 13.5
Old 02-23-2013, 02:18 PM   #2484
Metalsoft's Avatar
That's cool, I did not have such luck, and the 3 guys I race with didn't either.
I just wanted to write this up so guys getting the kit new, can do it the right way the first time.
Old 02-23-2013, 04:35 PM   #2485
Thumbs up
Thanks for taking the time to share that.
Old 02-23-2013, 07:09 PM   #2486
Wow. can't believe you are having so many problems with the shocks. we have a lot of these cars at our track and I personally have owned four and worked closely with seven or eight. all of the stock shocks and the aluminium upgraded shocks have been great. maybe 3racing went through a bad batch or something. I was using associated green slime on the lower o rings and building the shocks with zero rebound and everything has been great. good to know that the tamiya parts work just in case I'm in a jam one day.
Now that I have said all of this watch my shocks leak next weekend. now where is that oak tree? I need to knock on it for a while.
Serpent S120 13.5
Old 02-24-2013, 08:17 PM   #2487
Thanks for the shock info. I really came to rely on the Tamiya shocks and their parts a decade ago. I learned about them owning several Tamiyas. When I went to Associated I learned how good the Tamiya stuff was (not that Associated stuff was bad, but I really preferred the Tamiya shock products. When I started with Yokomos, I used every Tamiya shock part I could. So, naturally I am stoked to hear that Tamiya shock parts are still well thought out.
Old 02-24-2013, 10:50 PM   #2488
any body ever have a problem with the zero s stock center pully? (20t) today mine just got chewed up somehow( the outer lip which keeps the rear belt in line)......
sonspit is offline   Reply With Quote
Old 02-25-2013, 05:51 AM   #2489
Metalsoft's Avatar
I agree 100%, I have always liked Tamiya shocks. You could go as far as using the Pistons and shock shafts, but for the type of club racing I do, it would be useless to upgrade the stock shocks that far.
But using the Oil seals, springs and bladders really does make a difference, and keeps them cheap also.
Altogether, I spent a extra $15 to make them perform 10x better than they did before.
Old 02-25-2013, 08:16 AM   #2490
sghx60's Avatar
I have a question, has any one tried running differant size gears on the center pulley. example, a 21 tooth spocket for the front tires and a 20 tooth for the rear tires. What would be the pros and cons of do this. Thanks
Xfactory X6/X60/ LOSI TLR22/TLR22T/TLR22SCT
TLR 22SCT Late Model
Factory Team B4/Factory Team T4
Losi Slider Sprint Car
Losi SCTE 4x4
sghx60 is offline   Reply With Quote
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
