Old 02-16-2013, 09:57 PM   #2431
Im looking at putting the s on a diet i can lose 100grams and still be over min weight, i can save 70 grams by switching from a 5300 to 4000 lipo, can i save any weight by using a spool or ball diff? could someone weigh those items for me please, i already have carbon fibre f/r towers and top deck but not main chassis
thefan is offline   Reply With Quote
Old 02-16-2013, 10:11 PM   #2432
Originally Posted by capnkids View Post
Just getting back into the game after a couple decades hiatus
Found the Zero S refreshing. It is great to not have to drop a ton of cash for a competitive car for the local club scene.
Thread has been a great source of information.
Can someone help me understand the codes on the suspension mounts (ie. RR +20 and RF-5)
RR=rear rear block so RR+20 is 2deg rear toe in RF=rear front block(closest one to the motor) so RF-5 gives you .5 deg of toe in. So if you were to use those two blocks together you would have a total of 2.5deg rear toe in which is what i use
Old 02-17-2013, 05:28 AM   #2433
The ball diff is about 3 grams lighter than the gear diff with aluminum outdrives. even more if your gear diff has steel outdrives. the spool is even lighter but I can't remember how much. if you add the heavy duty spool outdrives you add some weight back but add a lot of durability. You won't break a heavy duty outdrive. you wear them out. I'm going off of memory here because I weighed them when I switched over from the gear diffs. All I can say 100% is that the spool and the ball diff are both lighter than the fluid filled gear diff.
3Racing Sakura XI 17.5 TC
Formula Rabbit (FGX conversion) 21.5
STRC LCG 2WD Slash 17.5
Serpent S120 13.5
6376vette is offline   Reply With Quote
Old 02-17-2013, 07:50 AM   #2434
FauxMako's Avatar
RF-05 takes out .5 deg toe (-.5 deg not +.5 deg). So RR+20 and RF-05 gives you 1.5 deg toe. If you want 2.5 deg to you have to use RR+30 and RF-05.
Mike
3 3Racing Sakura Zeros: Mustang Boss VTA // Lexus LFA USGT // MazdaSpeed 6 TC
Mini M03 & M05
Life is better with a soundtrack
FauxMako is offline   Reply With Quote
Old 02-17-2013, 09:56 AM   #2435
This is not correct as the holes in RF 05 blocks are closer together than RF 0 block which means it will give toe in not out, like i said im using RF 05 and RR 20 and according to the setup gauge 2.5deg toe in
Old 02-17-2013, 10:24 AM   #2436
Vette how do you find the spool on driveshafts and tires? have heard things break easily if you clip a board and front tires wear faster
Old 02-17-2013, 11:13 AM   #2437
Guys thanks for the replies.
The coding refers to the toe not kick up or something else. That makes sense.
I just installed the verticle motor mount version 3. It is the one with the complete aluminum spur gear mount. Very nice. It has plenty of room for pinion mounting/adjustments.
capnkids is offline   Reply With Quote
Old 02-17-2013, 12:32 PM   #2438
There is definitely more pressure on the cv axles at the outdrive cups on the spool. I have broken my share of the plastic outdrive cups. I would highly recommend going with theheavy duty metal outdrive cups. I race almost every weekend and I get about six months out of a set before I consider them to be too worn to use anymore. you will actually see where the pin on the axle is starting to wear out the outdrive. since the outdrives are softer than the steel axle they take the damage and the axle stays in good shape. I have only worn the outdrives and have not had any issues with axles or bearings. The tire wear seems to be ok. Nothing to really complain about. my rears usually wear a little less than the front but that could simply be due to the steering duties of the front wheels too. The wear is always to the point where I don't feel bad about replacing all four tires. In short any increased wear is so small that you shouldn't worry about it. If the fronts wear out a lot faster than the rears there is probably another issue like tire spin under acceleration. Durability overall is at least as good as the gear diff. maybe even better.
Serpent S120 13.5
Old 02-17-2013, 04:02 PM   #2439
So the wear on the steel out drives is better. Is the part number for those out drives sak-65a/v2?
How do you feel about moving the Front drive shaft to the back and using the SSK drive shafts in the front?
Can this be done?
Old 02-17-2013, 04:09 PM   #2440
SteveM's Avatar
Trader Rating: 133 (100%+)
Can this be done?
Yes
SteveM is offline   Reply With Quote
Old 02-17-2013, 05:19 PM   #2441
I am loving this build. If I could post photos, I would. Just something I learned is that tapping all the holes prior to assembly will save your hands, and your screw heads. A few areas that call for 10mm long screws work better with 8mm instead. Also, I am using a standard tapered tap. Don't run it all the way in. I have been putting about 2 to 2.5 turns of tap into the holes so that the screw still gets tight towards the end. This should help screws from loosening too much later on. I am impressed by the quality and especially the precision of the kit and its parts.
cygnusx1 is offline   Reply With Quote
Old 02-17-2013, 05:21 PM   #2442
Metalsoft's Avatar
Trader Rating: 69 (100%+)
Originally Posted by SteveM View Post
I ran a Parma Mohawk body and the car was planted. Worked great.
Indeed they are great bodies...
3Racing Sakura Zero S-img_20130217_194152_215.jpg   3Racing Sakura Zero S-img_20130217_194020_028.jpg
Tamiya TB03 USGT - Custom Carbon fiber Chassis - Magoo Racing Inc....
Metalsoft is offline   Reply With Quote
Old 02-17-2013, 05:34 PM   #2443
If you use the spool heavyduty drive cups do you still need the pink metal rings that come with the plastic cups
Old 02-17-2013, 06:33 PM   #2444
Originally Posted by Sakuraszero View Post
just done a few upgrades on the zero I put front solid axle and some new alloy oil dampers. I have gone 64 mph with a tune and using standard gears gonna try some different gears hopefully will go a bit faster
what motor, battery and esc do you run with?
sonspit is offline   Reply With Quote
Old 02-17-2013, 10:00 PM   #2445
The part number for the outdrives is Sak 09 HD and you will not need the pink cups.
Serpent S120 13.5
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
