Old 01-27-2013, 06:11 PM   #2371
ta04evah's Avatar
Originally Posted by 6376vette View Post
I just went back and reread some of your posts. are you still using a tamiya spur? If so are you using a tamiya pinion? Tamiya uses a metric pitch to their gears. if you use a standard pinion and a metric spur they will mesh together but it will bind and sound like hell
No, I'm using 48 pitch gears and I made sure both were 48 pitch when I bought new ones. I'm quite familiar of the sound that happens when you try to use a 48dp & .6 gear together. My car sounds similar to that noise but not as bad.
Cheers
Rob.
Castle Hill RC On Road Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 01-27-2013, 06:24 PM   #2372
cannon's Avatar
Trader Rating: 35 (100%+)
Rob
On the very early gear diffs from 3 Racing there was an issue with the pitch of the teeth on the gear diff actually being wrong. That is why they issued a Ver 2 gear diff.
With the original diff you would actually see the belt rise and fall in the gear diff as the belt didnt mesh with the gear. This made an unusual sound as well. Maybe you have one of the original gear diffs
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 01-27-2013, 08:17 PM   #2373
ta04evah's Avatar
Originally Posted by cannon View Post
Rob
Greg,
Thanks, I'll check that out and see if that may be the problem, I believe that they are v2 gear diffs as they came out of my new Zero S kit. Dean said that he had a spare ball diff for the rear that I could try, and I have a spool diff for the front, so when I speak to him next I'll ask him to put them in and try it out.
As I said before I'm not going criticize the car too much, but I am very dissapointed with it because of this issue that is plaguing me, which I shouldn't have to do with a virtually brand new car. Sure, every new car may have an issue or 2 but they are usually easily spotted & rectified.
Anyway, hoping to be able to report some good news on Friday, just also ordered some new parts for the old tamiya to keep it going if the need arisis.
Cheers
Rob.
Old 01-28-2013, 07:14 AM   #2374
buckeye dan's Avatar
Default pain in butt
Anybody else having rouble getting parts ,I see integy making you have 40 dollar minimum order.. I need body post mounts for new zero i bought for usgt.
and what offset rims will i need for usgt ?
Buckeye Dan
buckeye dan is offline   Reply With Quote
Old 01-28-2013, 07:38 AM   #2375
TQ Racing
http://www.tqrcracing.com/
They have Sakura Zero S parts. Get my parts for my Sakura from them when I need them. And at around $2.99 shipping for parts, they are a great choice.
VTA = 3Racing Sakura Zero S
Mini = Tamiya M-04
Off-Road = ECX Ruckus/Torment SCT
Home Track = Jeff's RC Studio,(Fort Myers, Florida)
NewRCSim is offline   Reply With Quote
Old 01-28-2013, 07:42 AM   #2376
FauxMako's Avatar
Also http://hotshothobby.com
For USGT rims you can use 0mm or 3mm for 190mm bodies and 6mm or 9mm for 200mm bodies.
Mike
3 3Racing Sakura Zeros: Mustang Boss VTA // Lexus LFA USGT // MazdaSpeed 6 TC
Mini M03 & M05
Life is better with a soundtrack
FauxMako is offline   Reply With Quote
Old 01-28-2013, 07:44 AM   #2377
Metalsoft's Avatar
Trader Rating: 69 (100%+)
TQ racing
and HotshotRC both in the US and both with a lot of parts inventory.
Tamiya TB03 USGT - Custom Carbon fiber Chassis - Magoo Racing Inc....
Metalsoft is offline   Reply With Quote
Old 01-28-2013, 08:10 AM   #2378
thanks good info and so fast thanks to all that responded
Buckeye Dan
Old 01-29-2013, 01:10 PM   #2379
Just got a few goodies for the zero
Sakuraszero is offline   Reply With Quote
Old 01-29-2013, 01:33 PM   #2380
SteveM's Avatar
Trader Rating: 133 (100%+)
Why did you pick up the extra belts?
SteveM is offline   Reply With Quote
Old 01-29-2013, 09:06 PM   #2381
Got it for free
Old 01-29-2013, 10:20 PM   #2382
azeroth's Avatar
Trader Rating: 20 (100%+)
OK thats a good reason LOL
Nitro is for Racing!!!!!!!!!!!!!!!!!!!!!!!!!
YA SMELL WATTs I BE STEPPIN IN????
Yes I race a Snake, VP, Radiopost,Protek,EDS,Matrix
Team Nitro RC Club Lynwood, IL
azeroth is offline   Reply With Quote
Old 01-30-2013, 04:07 PM   #2383
Talking
Originally Posted by shadowracer24 View Post
Touch a finger to the motor and cout 1001,1002 your okay. If it comes out 1001, OHHH $%#* then the motor is running to hot. Not trying to be a smartass here this actually works. If you can keep your finger on it for a count of a least three seconds the temp on average is around 150* The shorter the count the hoter the motor, but as stated earlier the best way is a good cheap temp sensor.
i see that you race indoors n florida... im in avon park i would love to start really racing.. where is the track? if u dont mind me asking
sonspit is offline   Reply With Quote
Old 01-30-2013, 06:10 PM   #2384
Metalsoft's Avatar
Here is my Sakura S zero with my own prototype sway bar mounts and front bumper.
Running Sway bars that were on my SC10 at one time, they actually work fantastic!
Old 01-31-2013, 03:53 AM   #2385
ta04evah's Avatar
Another update on my Sakura Zero saga...
Gave the car to my friend who originally gave me all the cf & alloy parts.
After several days I was informed by him that he had a bald spot on the side of his head from tearing his hair out over the problem. Even after 3 total strip down & rebuilds the problem continued to exist.
After some brain storming the both of us concluded that there could be a tweak in the lower cf deck. My friend generously then gave me a 75% built new Sakura Zero with a brand new lower cf deck.
Just finished building the remaining components and installed the electrics. Initial testing with new gears & a recently re built motor with ceramic bearings seem promising, but won't know until I give the car a run outside.
I'll more than likely wait until racing tomorrow as the concrete area's around where I live are dusty and have lots of small stones (bad for gears & bearings).
So one would hope that my previous problems will not continue with what basically is a brand new car.
Cheers
Rob.
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
