Old 01-22-2013, 05:48 AM   #2341
Trader Rating: 39 (100%+)
Hey Zero S Racers. Having some minor rear end issues and have tried the following so far..
For 17.5 blinky on Small tight track
Front:
Hexes = 6mm
I still only have the normal length arms
one step softer than stock springs - 40wt oil
Stock shocks and pistons
Shock outside hole top and 1.4 sway bar
.5 toe out, 1 degree camber 4 Degree caster blocks
Diff - 300,000 wt
alum upper camber link mount in the middle front hole with 2mm of washers under ball stud
a-arm mounts no shims
Ride height 5.5mm Droop +4mm
Rear:
4mm hexes
2 steps softer than stock) - 37.5 wt oil
shocks in one hole on top with 1.5 Sway bar
Rear 3 degree toe in 2 degrees camber
Diff - 80wt
alum upper camber link mount in the most inside hole with 4mm of washers under ball stud
Ride height 5mm Droop +2mm
Much Moore 32 Tires Full rear 3/4 front compound
The reason I went lighter in springs is our track is low on traction. the carpet stays layed out but only gets run once a week and it's old carpet
What I need is the car to be better when going thru a chicane where it's immediate right to left to right steering. the car gets out of shape in the rear really easily. and on power it pushes just a little but too much.
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 01-22-2013, 08:23 AM   #2342
FauxMako's Avatar
Originally Posted by quickershifter View Post
Hi guys, I'm trying to get a FDR of 4.8 or close in my Sak S, changed the center pulley to 21t with stock spur 80t and pinion of 30t. The problem now is the belts (522t front & 171t rear) are so tight. Any compatible belt that I can replace to overcome this problem?
41 or 42/100 64p pinion/spur with the 19t/38t pullies should get you where you want to be.
And, yes, you'll really need to stretch out the belts if you use the 21t pullies as they belts are too tight with the 20t pullies -- which is why everyone runs the 19t pullies
Mike
3 3Racing Sakura Zeros: Mustang Boss VTA // Lexus LFA USGT // MazdaSpeed 6 TC
Mini M03 & M05
Life is better with a soundtrack
FauxMako is offline   Reply With Quote
Old 01-22-2013, 10:41 AM   #2343
Metalsoft's Avatar
Trader Rating: 69 (100%+)
I just want to clarify something.
I am wanting to do the rear shock tower mod and want to get a thumbs up before I purchase the items.
I am going to need the sakura zero S FRONT bulkhead covers....
http://www.hotshothobby.com/Front-Bu...-SAK-34-PK.htm
And this shock tower for the 416
http://www.ebay.com/itm/130436359610...84.m1423.l2649
Is this all I need?
Tamiya TB03 USGT
Metalsoft is offline   Reply With Quote
Old 01-23-2013, 05:21 AM   #2344
X1 tower fits with no mods, i believe the tamiya one needs the holes drilled out a little
thefan is offline   Reply With Quote
Old 01-23-2013, 06:52 AM   #2345
Pro10noob's Avatar
Correct
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 01-23-2013, 02:24 PM   #2346
Jdeadman try reducing rear droop to 4 and softer swaybars 1.3 f/r add more front camber and lean front shocks over one hole, front ride height should be lower than rear, keep your roll centre similar f/r so go back to standard 3mm allround and tune by 0.5mm good luck
Old 01-24-2013, 08:52 AM   #2347
Hi All
I gave up racing around 9 years ago when i raced a mission and AE TC3 things have moved on a bit
I am looking to start back up again and have been looking at the S model as its the only one available in the UK at the moment and the price is amazing
I don't want to spend 360 on a new car
Choices are a second hand 2011 X-Ray or a Sakura S.
I really like the idea of going against the grain as I know most members of the indoor clubs i will be attending are running X-rays
I'm rather worried about getting a good carpet setup
By the sounds of things I will be wanting to go in the 17t blinky class
Whats the first hot-ups and whats the setup advice for a neebie
To add to this I am moving from a stick controller to a Wheel
Hope you can help
Andy Redz is offline   Reply With Quote
Old 01-24-2013, 09:11 AM   #2348
SteveM's Avatar
Trader Rating: 128 (100%+)
Originally Posted by Andy Redz View Post
Hi All
Hope you can help
The car is fine box stock, but the belts are a bit on the tight side. Most have purchased the 19T layshaft pulleys along with the pink alloy spur gear adapters.
The stock motor mount is a PITA and access to the rear motor bolt is through the spur gear. I went with the vertical motor mount to eliminate the bolt access issue, but this move involves mods to the upper deck and you also need to flip the belts to the opposite side of the chassis. When you do this the belts rub the battery tray guides and these need to me modified or removed. I posted pics of my mods and you can do a search for those.
I also opted for 64P gears as this allows for finer tuning the FDR. Personal preference really.
SteveM is offline   Reply With Quote
Old 01-24-2013, 10:55 AM   #2349
Hi,
I got a Sakura Zero S with no hop-ups other than pinions/spurs to adjust the gearing. I'm running it in 17.5T as well, also as a newb.
If I got only one hop-up, it would be better turnbuckles than the kit has. The kit turnbuckles have rounded flats and don't work at all.
The motor mount would be nice, but truthfully, once I got my gearing set, I haven't needed to fiddle with the motor screws at all.
I am using the stock 20t pulleys, and although the belts were tight when I first built the car, they loosened up quickly.
The kit screws strip their heads easily. I would invest in a high quality 2mm hex driver before attempting the build. You may also want to pre-thread the holes with a motor screw (3mm screw, 2.5mm head for more torque) or a tap, and use oil or grease on each screw during assembly.
As for setup: I don't have any recommendations other than spending more time driving than tweaking your setup. If you accurately implement the setup in the manual, the car will handle well enough on carpet for you to spend most of your time improving your driving skills.
I hope this helps,
Alan
robindog is offline   Reply With Quote
Old 01-24-2013, 10:59 AM   #2350
Oh yeah!
I also meant to ask: does anyone know where to get more Zero S kits in the US these days? TQRC and Integy are both out of stock. I really hope they don't stop making them.
Thanks,
Alan
Old 01-24-2013, 03:28 PM   #2351
shadowracer24's Avatar
Try hotshot hobbies near atlanta georgia, they carry a full supply of sakura zero parts and cars.
Richard Carpenter
SPEEDZONE Batteries Team Driver
BMI Team Driver
2014 F.E.D.S. Mod Sprint and Sportsman Late Model Champion
2013 FSERA World GT State Champion
shadowracer24 is offline   Reply With Quote
Old 01-24-2013, 05:20 PM   #2352
FauxMako's Avatar
http://hotshothobby.com/
If you don't see what you are looking for on the site, call. Sometimes they have parts in stock that aren't on the site.
Mike
Mini M03 & M05
Old 01-25-2013, 01:05 AM   #2353
Hey just scored a LRP VECTOR X11 3.5 Turns Bruhless Modified engine for free and just ordered a XERUN-120A ESC with a program card. This will be going in my Sakura s zero and its mainly for top speed runs. Will post a video when its finished
Sakuraszero is offline   Reply With Quote
Old 01-25-2013, 08:37 AM   #2354
I
Found the mods TC6 battery clamps FTW
Originally Posted by robindog View Post
Hi,
Alan
Thanks guys
looking at the hop ups that I would consider while building the kit I might go for a XI DH version not sure if it will be more cost affective in the long run.
But either kit looks great value for money
Old 01-25-2013, 01:27 PM   #2355
Lightbulb
Thanks guys
The xi is an awesome car. you may save a few bucks upgrading a zero s but not much. Either way you will have a great car. I run an xi and my son has a fully upgraded zero s with the narrow chassis. We have no problems keeping up with other chassis.
3Racing Sakura XI 17.5 TC
Formula Rabbit (FGX conversion) 21.5
STRC LCG 2WD Slash 17.5
Serpent S120 13.5
6376vette is offline   Reply With Quote
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
