Old 12-26-2012, 12:48 PM   #2251
shadowracer24's Avatar
1: Yes the ssk are a direct replacement on the front and will take some chatter out of the front on hard turns. 2: You do not have two swap out the arm mounts but you will have to get the shorter rear axles. these arms are shorter than the s arms. 3: You could do that but IMO you would be better off getting the aluminum replacement parts. 4: The Sakura s chassis will have a lot more flex than the Xi chassis, It is made from graphite and has different flex characteristics. And HAPPY NEW YEAR!
Richard Carpenter
SPEEDZONE Batteries Team Driver
BMI Team Driver
2014 F.E.D.S. Mod Sprint and Sportsman Late Model Champion
2013 FSERA World GT State Champion
shadowracer24 is offline   Reply With Quote
Old 12-26-2012, 08:45 PM   #2252
[QUOTE=shadowracer24;11592728]Check the clearance on the servo saver and the top deck too. My servo has a long output shaft on it and the linkage was hitting the top deck just enough to hang the steering up. Took a little off the top deck and works just fine now. Drove me nuts for weeks trying to figure that out, looked fine on the bench but under load on the track the chassis would flex and then it would hangup.[/QUOT
i just checked that... thats not it for me.. were u using the stock servo saver? what if i get a servo arm? and as far as it going to the right while its accelerating.... do you yhink it could be the rear diff?
sonspit is offline   Reply With Quote
Old 12-27-2012, 01:56 PM   #2253
Hmmmmm! You got me stumped on that one. I have the stock servo saver on mine and have not had one single problem with it. When you put it together did you use all the springs it came with? I think it had two silvers and a gold, pain in the butt to get them in there but it will go. If you are pulling under accelleration all I can think of is 1: maybe you are getting a heavy amp draw and it is causing the servo to momentarally brown out. 2: there must be something binding in the right front axle or bearing that would make it pull that way. Sorry I can"t be more helpful but without actually seeing what it is doing its hard to diagnose.
Richard Carpenter
BMI Team Driver
Old 12-27-2012, 08:37 PM   #2254
Odin544's Avatar
Trader Rating: 93 (100%+)
It could easily be the diff. The plastic used through out the car is pretty cheap and very soft. If you over tighten the screw into the diff it will deform and bind up the gears internally which could cause it to pull one way or another under acceleration.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 12-30-2012, 04:07 PM   #2255
buckeye dan's Avatar
Default just gotta say
been racing my zero all fall and now I am running in top 5 with my pretty stock zero. starting to get noticed guys asking what it is.gotta love it.someday plan on adding some aluminum parts dont really need to but some of the plastic parts will need replaced some screws dont tighten up... but any how go zero lol
Buckeye Dan
buckeye dan is offline   Reply With Quote
Old 12-31-2012, 05:26 AM   #2256
Default Sakura Zero
Hello guys,
New guy here, just want to ask if 48p spur 80t is working properly with 32t pinion..?
Bobetski is offline   Reply With Quote
Old 12-31-2012, 07:22 AM   #2257
matt*strike's Avatar
Trader Rating: 41 (100%+)
I had to swap over to 64 pitch gear to get the fdr I wanted.
Team Redline O.G.
Alpha Raceway ---Carbondale, IL
matt*strike is offline   Reply With Quote
Old 01-01-2013, 05:49 AM   #2258
Originally Posted by Bobetski View Post
Hello guys,
The motor mount won't allow a 32..i tried the same thing at first. Not sure if the vertical motor mount allows is though.i use a 22t for now, planning on going up 2 teeth at a time... Try ordering a lower tooth spur.i just ordered a72t 3 racing spur on ebay.I'm sure the 32 well fit then.they have a wide selection of different sizes on ebay just search for 3racing spur.their 3.80 plus 4 shipping
Old 01-01-2013, 05:54 AM   #2259
Smile
Nice.post a pic. Or video.i"d love to see
Old 01-01-2013, 01:06 PM   #2260
I used the verticle mount with a 34. That's the biggest I could squeeze.
Team Redline O.G.
Old 01-02-2013, 01:54 PM   #2261
when i hit the throttle from a dead stop it pushes to the right every time.
why is this and how can i correct it?[/QUOTE]
Mine used to pull to the side from a stand still until i balanced the car left to right, my electrics were heavier than my lipo so i moved the lipo over to the very edge of the chassis, got it within 2grams to the other side and now it pulls straight
thefan is offline   Reply With Quote
Old 01-03-2013, 10:24 AM   #2262
Mine used to pull to the side from a stand still until i balanced the car left to right, my electrics were heavier than my lipo so i moved the lipo over to the very edge of the chassis, got it within 2grams to the other side and now it pulls straight[/QUOTE]
thats probably it for me my lipo is very heavy(cheap) how can i balance that? thx
Old 01-03-2013, 11:02 AM   #2263
Hi.
I drive a Zero S with a 3.5T engine. The engine runs a bit hot, even if I am not one of the fastest on the track. I am running a 80 spur and 23 pinion. I also have changed to 19 on the two center pullys.
Should I use a smaller or larger pinion to get the engine to run cooler? The ESC is running cool.
Anthias is offline   Reply With Quote
Old 01-03-2013, 11:08 AM   #2264
Smaller pinion to cool your motor.
By the way a motor is electric. An engine is fuel powered.
Team Redline O.G.
Old 01-03-2013, 11:29 AM   #2265
thats probably it for me my lipo is very heavy(cheap) how can i balance that? thx[/QUOTE]
Chances are your lipo is lighter than the motor esc and reciever usually you use digital scales under each wheel and the weight left to right should be even amount same goes for front to back although mine is not. quick way to check if you dont have scales is to put a small screw driver in each centre hole in the shock towers and lift the car up, i bet it leans toward the electrics side
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
