Old 12-21-2012, 02:09 PM   #2236
shadowracer24's Avatar
Are you runnin carpet or asphalt. I use Associated oil in mine it seems to be more consistant. You never know what comes in the kit, it may say thirty but acts like 50 at least what I got with mine did.
Richard Carpenter
SPEEDZONE Batteries Team Driver
BMI Team Driver
2014 F.E.D.S. Mod Sprint and Sportsman Late Model Champion
2013 FSERA World GT State Champion
shadowracer24 is offline   Reply With Quote
Old 12-21-2012, 02:52 PM   #2237
im running asphalt... and the 30 i have is associated as well on all 4 shocks, i didt use the kit oil because i dont know what wieight it is. i know its thicker than 30 though.
sonspit is offline   Reply With Quote
Old 12-21-2012, 02:54 PM   #2238
can you guys post some pics of your zeros..
Old 12-21-2012, 05:55 PM   #2239
sporadicidiocy's Avatar
Most have posted theirs pages ago., here's mine for the first time here.
http://imageshack.us/a/img803/1687/90sakura.jpg
90% Sakura Zero: Reventon S V3.0 10.5T
Sakura Ultimate: GTB2 17.5T
F104 Pro: SXX V2 Trackstar 21.5T
F103 Chevronmodels 6-wheel conversion
sporadicidiocy is offline   Reply With Quote
Old 12-21-2012, 10:43 PM   #2240
nice! thats not the s is it? looks like the high end zero
Old 12-21-2012, 11:59 PM   #2241
It started life as a stock zero s, and eventually ended up as 90% zero, cheaper than the full zero kit still. It still retains the FRP chassis since I run on parking lots sometimes.
Old 12-23-2012, 11:22 PM   #2242
Default seasoned rc hobbyist, i need your help
im having 2 problems with my zero s.. any help is appreciated
1. it wont track staight. i set the steering trim, its straight for a while until i make a turn, then its either going to the L or right
second. when i hit the throttle from a dead stop it pushes to the right every time.
why is this and how can i correct it?
Old 12-23-2012, 11:36 PM   #2243
Pro10noob's Avatar
Hmmmmm....Sounds like you using the original servo saver.
Bin it and buy a proper one.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 12-23-2012, 11:37 PM   #2244
azeroth's Avatar
Trader Rating: 20 (100%+)
do you have some dragging or tight ball studs or bind in the steering and replace the oe servo saver with a heavy duty kimbrough or xray unit. as for the right turn on hit could be a tweek in your setup or uneven shock rebound ect.
Nitro is for Racing!!!!!!!!!!!!!!!!!!!!!!!!!
YA SMELL WATTs I BE STEPPIN IN????
Yes I race a Snake, VP, Radiopost,Protek,EDS,Matrix
Team Nitro RC Club Lynwood, IL
azeroth is offline   Reply With Quote
Old 12-24-2012, 09:07 AM   #2245
regards Roy
Thanks.. I am using the stock saver....gotta order one asap
Old 12-24-2012, 09:09 AM   #2246
Thanks for responding. I will rebuild the shocks tonight.. As far as in my set up...what do mean?
I'm new to this bare with me
Old 12-24-2012, 12:12 PM   #2247
He means that after you wrecked or hit the boards the chassis might have tweaked on you. The plastic in the s is notorisally soft and a hard hit could pull the screws out some. Loosen the screws on the top deck then push down on the chassis on a flat surface and tighten the screws back down. That should remove any tweak you would get in the chassis.
Richard Carpenter
BMI Team Driver
Old 12-24-2012, 08:29 PM   #2248
I never hit anything....yet. I only drove the car like 3 times. Still trying to work out these little kinks .
Old 12-25-2012, 06:54 AM   #2249
Check the clearance on the servo saver and the top deck too. My servo has a long output shaft on it and the linkage was hitting the top deck just enough to hang the steering up. Took a little off the top deck and works just fine now. Drove me nuts for weeks trying to figure that out, looked fine on the bench but under load on the track the chassis would flex and then it would hangup.
Richard Carpenter
BMI Team Driver
Old 12-25-2012, 02:30 PM   #2250
I read the entir thread and have some cuestions:
* The new SSK (double) driveshafts are a direct fit?
* To convert the rear end to XI, I may swap rear arms, or the arm holders too?
* Could I use the split arm mounts with the original S chassis. I was thinking on make bigger the small holes on the original holes for the plastic knobs of the original plastic arm mounts.
* Which chassis flex more The XI or the standard fiberglass S chassis
Thanks in advance, and Merry Christmas!!!!!!
prorace is offline   Reply With Quote
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 05:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 10:21 AM
SEO by vBSEO 3.5.0
