Old 12-18-2010, 07:38 PM   #211
monkee's Avatar
Trader Rating: 15 (100%+)
Originally Posted by CuLeX View Post
Overgeared how did you install the springs?Its very hard to stretch them apart and put them together. Is there any techniques..
The first two were a breeze..
the last one took some effort.
i started at the solid bottom pushing the ends up with both thumbs..
once it was on, i used a small flathead to try to center the spring.
they are not all center but fairly close
monkee is offline   Reply With Quote
Old 12-18-2010, 07:52 PM   #212
Madulla's Avatar
I found that swearing lots helped. It fit better after I threw it across the room. I stretched that last one a little with a pair of pliers and then used the back of a screw driver.
Madulla is offline   Reply With Quote
Old 12-18-2010, 10:06 PM   #213
monkee's Avatar
Originally Posted by OverGeared View Post
The stock spur is 48pitch as "over gear" had answered.
Your FDR (Final Drive Ratio) should be 4:1 if running a 17.5 Spec motor.
For the 80teeth 48pitch spur you can use a 38teeth 48pitch pinion gear, however, I doubt if the adjustment slots of the motor mount could accommodate the motor with the 38T pinion. That being the case, you might want to change the spur to 76teeth 48pitch and use a pinion of 36teeth to have a perfect gearing of 4:1. If the 76teeth spur is not available you can opt for the 75teeth 48pitch and still pair it with a 36T pinion gear.
Hope this helps.
Im having issues finding a pinion spur combo too w/out upgrading the motor mount.
Could one go 64p? i cant find 48p that has the predrilled holes. and you need the holes to be able to screw in the motor.
I found these two. could I use them?
and would the work fine w/out modifying or buying different part?
http://www.amainhobbies.com/product_...-Spur-Gear-76T
http://www.amainhobbies.com/product_...inion-Gear-36T
Old 12-18-2010, 10:40 PM   #214
Pro10noob's Avatar
Why don't you use the new Xenon gears??
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 12-19-2010, 12:06 AM   #215
OverGeared's Avatar
+1 ... (and on the swearing too) that should do it.
OverGeared is offline   Reply With Quote
Old 12-19-2010, 01:57 AM   #216
monkee's Avatar
regards Roy
where is that available?
Old 12-19-2010, 01:59 AM   #217
monkee's Avatar
xenons are 64pitch?
Old 12-19-2010, 03:37 AM   #218
OverGeared's Avatar
The attached photo has 6 inner holes. The Zero S spur gear holder requires 4 holes, you should at least look for a spur gear with 8 inner holes. The Xenon gears will work also.
3Racing also has the 64p spurs with the "pre-drilled" holes:
http://os.3racing.hk/products_list.p...key=101&page=3
The Zero "S" can only accept the maximum size of 80T 48p (or 106T 64p) spur gear... due to the rear gear diff housing.
"Precision Racing" have their spur gear with outer holes also... but I am not sure if it is compatible with the Zero's spur gear holder. Don't bother with the "XRay" spur gears... it will not fit.
Old 12-19-2010, 08:08 AM   #219
GP40X's Avatar
Have you tried Robinson Racing 48P machined spur gears? I think the Pro Machined Spur gears will work (I'll find out when I get my Zero S after Christmas).
Robinson Racing 48 Pitch Pro Machined Spur Gears
Bill
"I used to be disgusted, now I'm just amused."
Team Qik
CustomWorks Outlaw Sprint Car
Xray T3 2012 USVTA
GP40X is offline   Reply With Quote
Old 12-19-2010, 11:17 AM   #220
Pro10noob's Avatar
At your LHS???
And yes they are in 48DP and 64DP.
regards Roy
l===/o\===l
Old 12-20-2010, 06:32 AM   #221
zipp's Avatar
Originally Posted by zipp View Post
Anyone had problems with the stock servo saver?
I tried my Zero S for the first time today and had problems tracking straight when I accelerated hard. The car would start straight then veer in both directions as i struggled to keep it going straight. I run 11.5T mildly boosted.
I suspect it's the servo saver that's the problem. It's probably flexing too much. The plastic is just not rigid enough.
I've just changed to a Tamiya high torque servo saver, will see if that solves the problem. If not it could be a servo issue.
Just an update on my problem.
I've since swapped out the kit servo saver for a tamiya high torque.
Veering on hard acceleration on the straight is eliminated, and the car now tracks very straight.
Might wanna consider a servo saver in your 'must haves' or 'upgrade' list.
Although I swapped out the whole thing, i believe the problem lies just in the servo saver horn, which flexes too much under load. 3Racing sells just the horn itself, in different shades of aluminium. I think that alone would do, no need to buy a new servo saver.
cheers!
zipp
zipp is offline   Reply With Quote
Old 12-20-2010, 07:01 AM   #222
can someone post more videos...of this car in action @ a race...that would be nice to see how it will do in a field of cars
starrx is offline   Reply With Quote
Old 12-20-2010, 08:44 AM   #223
ahpeq_ong's Avatar
cheers!
zipp
what type of servo saver u using..?
and pic or link..?
thank you..
Sponsor by : Visa, Mastercard, Paypal
ahpeq_ong is offline   Reply With Quote
Old 12-20-2010, 08:58 AM   #224
zipp's Avatar
and pic or link..?
thank you..
I'm using the High Torque Servo Saver from Tamiya:
http://www.tamiyausa.com/product/ite...oduct-id=51000
Since I said it's the horn that flexes, you can get this as well:
3Racing Aluminium Servo Saver Horn
Old 12-20-2010, 04:09 PM   #225
Tunatsol's Avatar
You could just use the XRay gears we have to some moter mount as the Zero. Thats if your layshaft will let you
Josh Youngs
Team Durango: DNX8, Dex8, 408, 210, 410v3,
Sponsored By: Dialed Hobbies
Tunatsol is offline   Reply With Quote
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
