Old 12-17-2012, 06:55 PM   #2221
ta04evah's Avatar
Forgot to ask.
Does anyone know if Tamiya belts from a 416/417 fit the Zero or not?
The reason I'd like to know is that the Zero belts are very thick when they are new, and are alot stiffer which is noticeable when they bend around the small pulley's.
This is more evident on the rear belt and adds a degree of friction/resistance to the rear center & diff pulley, which is not good when using a 21.5 motor in blinky class. In the aforementioned class, any friction/resistance that can be removed can make a big difference in both acceleration & top end speed of the car. I have noticed that the Tamiya belts are less "chunky" and are more flexible so I'm curious to see if they will fit the Zero.
Cheers
Rob.
Castle Hill RC On Road Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 12-18-2012, 05:13 PM   #2222
Originally Posted by quickershifter View Post
Hi guys, recently I've damaged my front lower arm and steering knuckle. Anybody know what replacement 'brand' can fit into my Sak Zero S kit besides the official 3racing ones?
I'm sure the t3 front knuckle can be used at sakura. not sure about the lower arm.
I've a used "spare kit" laying around. Try pm me what u want.
jack_lee is offline   Reply With Quote
Old 12-18-2012, 05:49 PM   #2223
Is it safe to run my sakura s with two teeth missing from the spur gear? And what gearing do you think is good Gearing for using the castle creations sv2 w the 6900kv 4 pole motor?
sonspit is offline   Reply With Quote
Old 12-18-2012, 06:30 PM   #2224
Trader Rating: 40 (100%+)
Generally No they will all strip out very shortly.
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 12-18-2012, 06:43 PM   #2225
xray2050's Avatar
Trader Rating: 14 (100%+)
Anyone else find the diffs are not smooth. Anyone have a technique to free them up a bit?
Pete Elphinstone
RC America, HUDY, XRAY, JACO, Performance Hobbies, WERKS RACING, www.speedzoneusa.com, Sweep Racing USA
xray2050 is offline   Reply With Quote
Old 12-18-2012, 06:52 PM   #2226
azeroth's Avatar
Trader Rating: 20 (100%+)
ok you have some dirt or overtightend or something as a burr
Nitro is for Racing!!!!!!!!!!!!!!!!!!!!!!!!!
YA SMELL WATTs I BE STEPPIN IN????
Yes I race a Snake, VP, Radiopost,Protek,EDS,Matrix
Team Nitro RC Club Lynwood, IL
azeroth is offline   Reply With Quote
Old 12-18-2012, 08:16 PM   #2227
I find that over tightening is the biggest problem with these diffs. I have just rebuilt mine with 300K in the front and 80wt in the rear and If I just lightly snug up the screws it's perfect and no leaking
Jason Deadman
Old 12-18-2012, 10:30 PM   #2228
Why? Because the missing teeth or this is the norm for the stock gear in this kit?
Old 12-19-2012, 05:44 AM   #2229
No the missing teeth will put more stress of the other teeth in the area and the stock spur gear is not that strong to begin with. I find that if ones goes the rest go very quickly
Jason Deadman
Old 12-19-2012, 04:04 PM   #2230
xray2050's Avatar
Thanks, I guess I had it too tight.
Working smooth now, just hope it don't leak.
Pete Elphinstone
Old 12-20-2012, 08:17 AM   #2231
Mister Pink's Avatar
Can anyone tell me if all the parts from the Sakura Zero S will fit on to the X1 Ver D.H chassis.
GITZ
Mister Pink is offline   Reply With Quote
Old 12-20-2012, 10:32 PM   #2232
hey guys.. any tps on how to stop the rear end from whippig out during turns? i have 30wt shock oil all around . th front shocks are in the 3rd hole ad the back ones are in the first hole... any tips... any tip period would be appreciated.. this is my first kit build and my first REAL rc car(newbie)....thanks
Old 12-21-2012, 03:44 AM   #2233
Firstly laying shocks over too far can have the opposite effect you wanted so bring the rear shocks back to hole 2 or 3, get softer rear springs 6.0, thicker shock oil in front than rear try 40f 35r, but you really need to tell us whether its loose on or off power
thefan is offline   Reply With Quote
Old 12-21-2012, 07:40 AM   #2234
Originally Posted by ericmaxman View Post
That's your answer.
Get some proper hardcase 2S lipo pack.
yeah.. i just ordered 5000mAh 7.4V 20C lipo..now all i need is to find someone who solders, so i can fit the connecter...and i changed the pinion to a 22t. now i need a new spur.. lost 2 teeth
but everywhere i look thy're out of stock..stripping them or loosing teeth must be common with the stock spur
Old 12-21-2012, 07:42 AM   #2235
its loose on power... while imholding the throttle
and as far as the thicker oil in the front.. the shock oil that came with the kit seems to be thicker than the 30 im using now.. would it be a good idea to use that?(for the front
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
