Old 11-17-2012, 11:06 AM   #2161
Trader Rating: 40 (100%+)
Mine is 570g with No battery holders/Velcro with the vertical motor mount installed. No Wheels or tires and no Electronics
I'm going to start installing the electronics and I'll get a base weight in a bit
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 11-18-2012, 05:26 PM   #2162
Does anyone know whether any other rear suspension mount will fit the zero i want to run 2.5deg rear toe without having to change both mounts in case i want to switch back to 3deg
thefan is offline   Reply With Quote
Old 11-18-2012, 10:26 PM   #2163
Odin544's Avatar
Trader Rating: 93 (100%+)
Just buy the RF -.5* and the pivot balls. Use the stock RR plastic 3.0*. With both of those you'd end up with 2.5*.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 11-19-2012, 11:13 PM   #2164
Ok thanks i was under the impression it was +.5deg and then had to swap out the 3deg for the 2 to end up with 2.5
Old 11-21-2012, 08:08 PM   #2165
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
Default gear diffs galore
for anyone looking for a collection of gear diffs ... (like that's real common ) ...
check here.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 11-22-2012, 08:04 AM   #2166
matt*strike's Avatar
Trader Rating: 41 (100%+)
Hey guys just need a starting point for the gear ratio in 17.5 blinky
Team Redline O.G.
Alpha Raceway ---Carbondale, IL
matt*strike is offline   Reply With Quote
Old 11-22-2012, 10:59 AM   #2167
on a tight track I'm running 93/41 with muchmoore 32's
Jason Deadman
Old 11-22-2012, 02:11 PM   #2168
SteveM's Avatar
Trader Rating: 138 (100%+)
Indoors on carpet with a medium sized track I use an FDR of 4.0 to 4.2
SteveM is online now   Reply With Quote
Old 11-22-2012, 05:28 PM   #2169
Hi guys!
What shock oil will be a g good starting point for asphalt medium grip track?
Thank you in advance!
kikoy is offline   Reply With Quote
Old 11-22-2012, 06:57 PM   #2170
Originally Posted by kikoy View Post
Hi guys!
Depends on how bumpy the track is but I would start with 40.
3Racing Sakura XI 17.5 TC
Formula Rabbit (FGX conversion) 21.5
STRC LCG 2WD Slash 17.5
Serpent S120 13.5
6376vette is offline   Reply With Quote
Old 11-23-2012, 09:23 AM   #2171
OK Sakura fans. Just got mine Ready to run and Body painted and I'm sitting at 1398g. That's as light as I can make it.
I am balanced with a fairly light 2s 5000mah pack. I have some room to move a lighter battery out on the chassis before it hangs off of this wide (female dog)
What is everyone else running for batteries and what is the weight difference from the Stock Wide Plastic chassis compared to the narrow Carbon fiber chassis?
Jason Deadman
Old 11-26-2012, 10:39 AM   #2172
I just received my sakura zero s and I must say WHY 3racing did you use phillips instead of hex. Started to put the diffs together and I grabbed a screw and to my surprize was a phillps NOOOOOOOOO!!!! I couldn't believe it. I hate kits with phillips. This is the 21st century and everyone knows small phillips strip worse than hex. I wish I had a giant screw kit so I could change them all out. Oh well ill report later on how the phillips are going.
Team Redline O.G.
Old 11-26-2012, 11:16 AM   #2173
FauxMako's Avatar
The Diffs and the spur gear holder are the only phillips screws. I believe if you search through the thread you can find someone supplied a link or specs for hex screws for those locations.
Mike
3 3Racing Sakura Zeros: Mustang Boss VTA // Lexus LFA USGT // MazdaSpeed 6 TC
Mini M03 & M05
Life is better with a soundtrack
FauxMako is offline   Reply With Quote
Old 11-30-2012, 02:22 AM   #2174
rc-goods's Avatar
Default Zero Force Sakura Bearing Kit Set
Zero Force Sakura Bearing Kit Set (12pcs) (ZF-E13002)
www.rcgoods.com
rc-goods is offline   Reply With Quote
Old 12-02-2012, 06:00 AM   #2175
Do I flip my diffs to get the verticle motor mount in or what I couldn't figure it out so I gave up and put the stock one in.
Team Redline O.G.
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
