Old 10-29-2012, 04:03 AM   #2131
Originally Posted by mudunda View Post
thanks for the reply
i took the shafts out and then i looked at the diffs and when i powered on
i noticed it is the diffs that wobble.
they are set in tight with all the screws both front and back wobble.
its never been driven or smashed.
got no idea what it could be. maybe faulty diffs
Make sure the eccentric bearing holders are oriented the same way left and right.
halldor is offline   Reply With Quote
Old 10-29-2012, 04:31 AM   #2132
are those the ajustable things on the outside of the diff i think its the thing that ajusts the tension on the belt..is that what you mean?
thanks
mudunda is offline   Reply With Quote
Old 10-29-2012, 07:56 AM   #2133
shadowracer24's Avatar
Yes that is what he is talking about. If they are not set even on both sides they put a twist in the diff which will bind up bearings, shafts, belts and cause all kinds of problems. If those are not right that may be what is causing all of your problems.
Richard Carpenter
SPEEDZONE Batteries Team Driver
BMI Team Driver
2014 F.E.D.S. Mod Sprint and Sportsman Late Model Champion
2013 FSERA World GT State Champion
shadowracer24 is offline   Reply With Quote
Old 10-29-2012, 09:12 PM   #2134
thanks for the info mate ill give it a go
Old 10-29-2012, 11:28 PM   #2135
so this weekend we ran on a smaller carpet track 17.5 and the back end allways drifted out on the corners.(every corner) I try to lay the shocks down but didnt help. so i used a harder spring and that fail . I guess i should of used softer springs...crap. any way what weight are stock springs? and any help would be great thanks
TeamThibault is offline   Reply With Quote
Old 10-30-2012, 12:49 AM   #2136
more like the rear diff fluid too thick.
Perhaps you accidentally switched front and rear diffs.
nicholasxuu is offline   Reply With Quote
Old 10-30-2012, 04:33 AM   #2137
Perhaps but I would try the softer springs first.
3Racing Sakura XI 17.5 TC
Formula Rabbit (FGX conversion) 21.5
STRC LCG 2WD Slash 17.5
Serpent S120 13.5
6376vette is offline   Reply With Quote
Old 10-30-2012, 04:34 AM   #2138
Corner entry or corner exit? What is your camber droop ride height and toe?
Serpent S120 13.5
Old 10-30-2012, 06:36 AM   #2139
Trader Rating: 39 (100%+)
I'd also look at the front. Could have too much traction and causing the over steer off power. try braking straight harder then enter the corner under accelleration
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 10-30-2012, 03:27 PM   #2140
.... so i used a harder spring and that fail . I guess i should of used softer springs...crap. any way what weight are stock springs? and any help would be great thanks
I think the stock springs are 5.5T (turns of wire). Sakura uses a strange system where they tell you the number of turns, not lbs./in., so larger numbers are softer springs. I measured the springs I have on a cobbled together postal scale rig and got the following numbers (your mileage may vary):
4.25T - 34.1 lbs./in.
4.50T - 29.3
4.75T - 28.1
5.00T - 27.5
5.25T - 26.0
5.50T - 23.1
5.75T - 22.5
6.00T - 21.4
6.50T - 18.3
Kevin Marcy is offline   Reply With Quote
Old 10-30-2012, 06:30 PM   #2141
Odin544's Avatar
Trader Rating: 93 (100%+)
Anyone have a good baseline setup for VTA?
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 10-30-2012, 07:22 PM   #2142
5.5 ride height front and rear
middle shock holes on the towers
30 wt shock oil
6.0 spring up front 6.5 rear
#3 sway bar front #2 rear
Front spool rear diff 80 wt shock oil
Front .5 degrees toe out 1 degree camber
Rear 2 degrees toe in 2 degrees camber
add 1mm shims under the upper inner camber link ball stud on the rear to lower the rear roll center
should get you pretty close to a good carpet setup. This worked for me on a medium to high traction track. if you are traction rolling remove the shims on the rear ball studs and go to 2 degrees of camber up front.
Serpent S120 13.5
Old 10-30-2012, 07:41 PM   #2143
Odin544's Avatar
Thanks! Much appreciated. This saturday will be its maiden voyage and our first onroad race of the year. So traction should be relatively low.
TriCitiesRC.com
Old 10-30-2012, 08:10 PM   #2144
Good luck with it. The sakura is really a great car.
Are your vta tires new? If so give them a quick burn out or some high speed turns on concrete to scuff them in. they will handle better. Start off using traction compound on the entire rear tire and the inner half of the front. if you push then go to a full tire of compound in the front.
Serpent S120 13.5
Old 10-30-2012, 08:26 PM   #2145
Odin544's Avatar
Yup brand new tires. Any tricks or tips to gluing them up? A few locals have complained of having issues getting them glued good. I haven't even glued mine yet.
TriCitiesRC.com
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 05:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 10:21 AM
SEO by vBSEO 3.5.0
