Old 09-26-2012, 04:08 AM   #2041
I recently updated the firmware to include boost/turbo on a 10.5 even with modest boost levels the damn thing was so fast i couldnt take the first turn after the straight without slowing down significantly but after installing swaybars i can now corner at a faster speed. overall the sakura handles well with more power even though ive noticed most people are using them in the blinky classes
thefan is offline   Reply With Quote
Old 09-26-2012, 10:49 AM   #2042
I want to buy a Sakura XI without waiting a month for it to come in the mail... Anyone know where I can get my hands on one speedily? I have paypal and 100% trader rating... I'll check this forum periodically for pm's and posts. Maybe a gently used one...
Mike
HUCKMAN is offline   Reply With Quote
Old 09-26-2012, 01:45 PM   #2043
Nevermind, I found a sakura xi ver dh at hotshotrc.com They didn't have them one their website, I had to call in my order...770-427-3770 It's in Marietta Georgia, man I love the south!
Old 09-26-2012, 02:00 PM   #2044
FauxMako's Avatar
That's my local track Getting ready to head over there now for the Wicked Wednesday races.
I need to remember to suggest them more often.
tqrcracing.com and hotshothobby.com are about the only places in the US that carry 3Racing on a regular basis that I'd order from.
Mike
3 3Racing Sakura Zeros: Mustang Boss VTA // Lexus LFA USGT // MazdaSpeed 6 TC
Mini M03 & M05
Life is better with a soundtrack
FauxMako is offline   Reply With Quote
Old 09-26-2012, 03:30 PM   #2045
There's also hksrc.com outta California... I order parts there when I can't find them at Tqrcracing.com I will definitely add www.hotshotrc.com to the list, the owner is a great guy. He already shipped it 2 hrs after my purchase
Old 09-26-2012, 04:10 PM   #2046
redbarton's Avatar
Don't forget Integy.com now has S parts as well as a lot of other 3Racing stuff! They are in CA too.
redbarton is offline   Reply With Quote
Old 09-26-2012, 04:49 PM   #2047
Trader Rating: 49 (100%+)
Sakura Zero S for saleFS: Sakura Zero S w/upgrades
SpeedMerchant Rev7
oceanhighz is offline   Reply With Quote
Old 09-27-2012, 05:29 PM   #2048
Paul R's Avatar
I'm going to be starting my build . Whats a good diff oil and shock oil to use i dont want to use the provided ones . thanks in advance .
3Racing Sakura Zero S , REEDY Sonic 17.5
Need a body painted ? hit up frank franksbodies@aol.com
www.tqrcracing.com
Paul R is offline   Reply With Quote
Old 09-28-2012, 05:56 AM   #2049
Associated shock oil is my brand of choice. I always use 30wt shock oil in my rear diff, and I only fill the sak diff HALF of what the book says...As far as the front diff I put eraser putty in the gears to make it solid. No more plastic outdrives breaking for me. It suits my driving style and makes the rear end predictable. Also, Associated recommends shock oil for their gear diff's........ Food for thought
Old 09-28-2012, 08:57 AM   #2050
FYI your plastic outdrives will break easier with a solid front diff although the performance is worth the wear one tear.
3Racing Sakura XI 17.5 TC
Formula Rabbit (FGX conversion) 21.5
STRC LCG 2WD Slash 17.5
Serpent S120 13.5
6376vette is offline   Reply With Quote
Old 09-28-2012, 09:04 AM   #2051
What class are you racing? What is the racing surface? What is the traction level? All of these factors go into fluid selection. I run 40 wt in the shocks and 1000wt in the diff for indoor carpet. Running a 21.5 for usgt. I ran 30wt shock and 80wt diff for vta 25.5.
Serpent S120 13.5
Old 09-28-2012, 11:52 AM   #2052
Odin544's Avatar
Trader Rating: 93 (100%+)
Hey guys. Looking at getting a Zero S for a VTA car. I've started reading the thread from the beginning and am finding contradictory information. Plus its from '10 so not sure if anything has changed since then. I want to keep this car as cheap as possible. So no aluminum unless I HAVE to have it. I saw there were issues with getting the correct gearing for the 25.5 and still being able to tighten down the motor. So what is everyones solution? Do I just need the vertical motor mount? Suggestions on gearing? Any help would be greatly appreciated!
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 09-28-2012, 12:02 PM   #2053
FauxMako's Avatar
19T center pullies and alloy spur gear holder are pretty much required as the front belt is too tight otherwise.
VTA gearing: You should start around 4.0 and adjust from there. I use 93T 64P spur and 46 or 47T pinion to get to close to 4.0 and still be able to move up or down 3-4 teeth on the pinion to adjust for track variables.
Vertial Motor Mount isn't required it's just a PITA to get the motor mounted without one as one of the motor screws will be behind the spur and you'll either need to do a lot of repositioning or make sure your spur has holes big enough to get your driver through them. You can keep the stock FRP top plate you'll just need to dremel out the center some to allow the VMM arm through.
Other than that you can run until something breaks or annoys you enough to change it out -- turnbuckles for example are annoying, but other than being hard to adjust they serve their purpose just fine.
Mike
Mini M03 & M05
Old 09-28-2012, 12:29 PM   #2054
SteveM's Avatar
Trader Rating: 126 (100%+)
+1 on FauxMako's comments above.
SteveM is online now   Reply With Quote
Old 09-28-2012, 12:31 PM   #2055
Odin544's Avatar
Awesome. Thanks for the info.
TriCitiesRC.com
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 05:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 10:21 AM
